1027 connectés
  Linux et OS Alternatifs
  Installation
  probléme installation amule 2.1.0 sur Mandriva 2006
n°780167
linuxnewto​n
Posté le 08-02-2006 à 18:47:13  profilanswer
Je suis débutant sous linux et j'aurais besoin d'un coup de main. J'ai la distribution Mandriva 2006. J'ai télécharger amule-2.1.0.tar.bz2 , ensuite je l'ai décompréssé sans problème. Ensuite j'ai ouvert une console et taper ./configure et voila ce qu'il me balance :
checking build system type... i686-pc-linux-gnu
checking host system type... i686-pc-linux-gnu
checking target system type... i686-pc-linux-gnu
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... no
checking whether to enable maintainer-specific portions of Makefiles... no
checking for g++... g++
checking for C++ compiler default output file name... a.out
checking whether the C++ compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking for style of include used by make... none
checking dependency style of g++... none
checking how to run the C++ preprocessor... g++ -E
checking for gcc... gcc
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking dependency style of gcc... none
checking how to run the C preprocessor... gcc -E
checking whether make sets $(MAKE)... (cached) no
checking for ranlib... ranlib
checking for bison... no
checking for byacc... no
checking for ranlib... (cached) ranlib
checking for strip... strip
checking for ar... ar
checking for ld... ld
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking for zlib >= 1.1.4... yes (version 1.2.3)
checking whether we need the GUI... yes
checking for wx-config... /usr/bin/wx-config
checking for wxWidgets version >= 2.6.0... no (version 2.4.2 is not new enough)
checking that wxWidgets has support for large files... no
configure: error:
                Support for large files in wxWidgets is required by aMule.
                To continue you must recompile wxWidgets with support for
                large files enabled.
Si quelqu'un pouvait m'aider ca serait pas mal , merci d'avance.
n°780170
Joseph Des​ire
Posté le 08-02-2006 à 18:47:59  profilanswer
Personne d'aidera pour ca car c'est interdit sur le forum de parler de p2p.
Ensuite une piste : configure URPMI....... Voila.
Message édité par Joseph Desire le 08-02-2006 à 18:48:08
n°780171
Mjules
Modérateur
Parle dans le vide
Posté le 08-02-2006 à 18:48:45  profilanswer
   * Les sujets concernants les logiciels de partage basés sur des technologies P2P sont interdits. Seules sont autorisées les demandes de liens (e2dk ou torrent) pour des téléchargements légaux. Aucun topic sur l'installation, le fonctionnement ou la configuration des logiciels P2P n'est autorisé.
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
  Installation
Installation internet et diverslinux : problème de passerelle
[HELP] Connexion Internet Freebox + Linux (Mandriva 2006)Probleme format d'impression MAC / OFFICE
[Problème] cool'n quiet avec Athlon X2 3800+ sur A8N Sli premiumprobleme : qmail ne veut plus envoyer mes mails!
Graphisme de mandriva 2006Problème lors de l'installation de freebsd 5.4
Plus de sujets relatifs à : probléme installation amule 2.1.0 sur Mandriva 2006
