1378 connectés
  Linux et OS Alternatifs
  Installation
  Problème XGL/COMPIZ et driver ati pour une Mobility FireGl v3200
n°823678
toinou7500​9
Fleuve paisible,rives fleuries
Posté le 30-06-2006 à 23:32:36  profilanswer
je fais ma grande entrée dans UBUNTU,  big_smile
j'ai installé les dernier drivers ati en date, voici se que me donne différente commande:
antoine@antoine-laptop:~$ glxinfo | grep render direct rendering: No
    GLX_ATI_render_texture
OpenGL renderer string: Mesa GLX Indirect
antoine@antoine-laptop:~$ fgl_glxgears Using GLX_SGIX_pbuffer
X Error of failed request:  BadMatch (invalid parameter attributes)
  Major opcode of failed request:  143 (GLX)
  Minor opcode of failed request:  5 (X_GLXMakeCurrent)
  Serial number of failed request:  32
  Current serial number in output stream:  32
antoine@antoine-laptop:~$ fglrxinfo display: :0.0  screen: 0
OpenGL vendor string: Mesa project: www.mesa3d.org
OpenGL version string: 1.2 (1.5 Mesa 6.4.1)
Donc déjà sa me donne des trucs bizarre, quels suggestions me donneriez vous?
Je précise que j'ai respecté à la lettre les tutos, et quand je lance ma session xgl/compiz, déja j'ai des artefacts en diagonale, et je n'ai plus les bordures des fenetres (sa doit etre compiz qui merde), et enfin j'ai le message qui s'affiche:
driver does not provide the fireGl extensions!
Panel components will operate only partially.
voici un copier coller de mon fichier xorg.conf ou cas ou:
# /etc/X11/xorg.conf (xorg X Window System server configuration file)
# This file was generated by dexconf, the Debian X Configuration tool, using
# values from the debconf database.
# Edit this file with caution, and see the /etc/X11/xorg.conf manual page.
# (Type "man /etc/X11/xorg.conf" at the shell prompt.)
# This file is automatically updated on xserver-xorg package upgrades *only*
# if it has not been modified since the last upgrade of the xserver-xorg
# package.
# If you have edited this file but would like it to be automatically updated
# again, run the following command:
#   sudo dpkg-reconfigure -phigh xserver-xorg
Section "ServerLayout"
    Identifier     "Default Layout"
    Screen      0  "aticonfig-Screen[0]" 0 0
    InputDevice    "Generic Keyboard"
    InputDevice    "Configured Mouse"
    InputDevice    "stylus" "SendCoreEvents"
    InputDevice    "cursor" "SendCoreEvents"
    InputDevice    "eraser" "SendCoreEvents"
    InputDevice    "Synaptics Touchpad"
EndSection
Section "Files"
    # path to defoma fonts
    FontPath     "/usr/share/X11/fonts/misc"
    FontPath     "/usr/share/X11/fonts/cyrillic"
    FontPath     "/usr/share/X11/fonts/100dpi/:unscaled"
    FontPath     "/usr/share/X11/fonts/75dpi/:unscaled"
    FontPath     "/usr/share/X11/fonts/Type1"
    FontPath     "/usr/share/X11/fonts/100dpi"
    FontPath     "/usr/share/X11/fonts/75dpi"
    FontPath     "/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType"
EndSection
Section "Module"
    Load  "i2c"
    Load  "bitmap"
    Load  "ddc"
    Load  "dri"
    Load  "extmod"
    Load  "freetype"
    Load  "glx"
    Load  "int10"
    Load  "type1"
    Load  "vbe"
EndSection
Section "InputDevice"
    Identifier  "Generic Keyboard"
    Driver      "kbd"
    Option        "CoreKeyboard"
    Option        "XkbRules" "xorg"
    Option        "XkbModel" "pc105"
    Option        "XkbLayout" "fr"
    Option        "XkbVariant" "latin9"
EndSection
    Identifier  "Configured Mouse"
    Driver      "mouse"
    Option        "CorePointer"
    Option        "Device" "/dev/input/mice"
    Option        "Protocol" "ExplorerPS/2"
    Option        "ZAxisMapping" "4 5"
    Option        "Emulate3Buttons" "true"
EndSection
    Identifier  "Synaptics Touchpad"
    Driver      "synaptics"
    Option        "SendCoreEvents" "true"
    Option        "Device" "/dev/psaux"
    Option        "Protocol" "auto-dev"
    Option        "HorizScrollDelta" "0"
EndSection
                                                      # /dev/input/event
                                                      # for USB
    Identifier  "stylus"
    Driver      "wacom"
    Option        "Device" "/dev/wacom"          # Change to
    Option        "Type" "stylus"
    Option        "ForceDevice" "ISDV4"               # Tablet PC ONLY
EndSection
                                                      # /dev/input/event
                                                      # for USB
    Identifier  "eraser"
    Driver      "wacom"
    Option        "Type" "eraser"
EndSection
                                                      # /dev/input/event
                                                      # for USB
    Identifier  "cursor"
    Driver      "wacom"
    Option        "Type" "cursor"
EndSection
Section "Monitor"
    Identifier   "Écran générique"
    Option        "DPMS"
EndSection
Section "Monitor"
    Identifier   "aticonfig-Monitor[0]"
    Option        "VendorName" "ATI Proprietary Driver"
    Option        "ModelName" "Generic Autodetecting Monitor"
    Option        "DPMS" "true"
EndSection
Section "Device"
    Identifier  "ATI Technologies, Inc. M24 1T [FireGL M24 GL]"
    Driver      "ati"
    BusID       "PCI:1:0:0"
EndSection
Section "Device"
    Identifier  "aticonfig-Device[0]"
    Driver      "fglrx"
    Option        "VideoOverlay" "on"
    Option        "OpenGLOverlay" "off"
EndSection
Section "Screen"
    Identifier "Default Screen"
    Device     "ATI Technologies, Inc. M24 1T [FireGL M24 GL]"
    Monitor    "Écran générique"
    DefaultDepth     24
    SubSection "Display"
        Depth     1
        Modes    "1400x1050"
    EndSubSection
        Depth     4
        Modes    "1400x1050"
    EndSubSection
        Depth     8
        Modes    "1400x1050"
    EndSubSection
        Depth     15
        Modes    "1400x1050"
    EndSubSection
        Depth     16
        Modes    "1400x1050"
    EndSubSection
        Depth     24
        Modes    "1400x1050"
    EndSubSection
EndSection
Section "Screen"
    Identifier "aticonfig-Screen[0]"
    Device     "aticonfig-Device[0]"
    Monitor    "aticonfig-Monitor[0]"
    DefaultDepth     24
        Viewport   0 0
        Depth     24
    EndSubSection
EndSection
Section "DRI"
    Mode         0666
EndSection
Merci d'avance pour votre précieuse aide,
Antoine
Le nouveau regard sur le High Tech
n°823702
sebchap
Share the knowledge
Posté le 01-07-2006 à 04:05:20  profilanswer
Tant que tu auras "Mesa" dans le resultat de fglrxinfo, ca ne sera pas bon. Il faut avoir du "ATI" dedans.
Donc le probleme est que le driver proprio ne se charge pas correctement.
Tu peux trouver l'erreur dans le fichier /var/log/Xorg*.log (le plus recent)
Evite toutefois de le poster ici dans sa totalité, car c'est trop gros (met un lien ou poste uniquement les erreurs).
Quels tutos as-tu suivi ? es-tu sur que ta CG est compatible avec les driver proprio d'ATI (toutes ne sont pas supportées) ?
Ca peut t'etre utile si tu ne le connais pas deja:
http://wiki.cchtml.com/index.php/U [...] tion_Guide
BOFH excuse #400:We are Microsoft.  What you are experiencing is not a problem; it is an undocumented feature.
n°823735
toinou7500​9
Posté le 01-07-2006 à 11:42:28  profilanswer
Merci pour ta réponse.
Le liens que j'ai utilisé pour installer les drivers ATI proprio est celui que tu as donner.
Voilà une partie de mon fichier xorg.log (celle qui ma sembler la plus indicative):
(II) fglrx(0): UMM Bus area:     0xc07ad000 (size=0x07833000)
(II) fglrx(0): UMM area:     0xc07ad000 (size=0x07833000)
(II) fglrx(0): driver needs X.org 6.8.x.y with x.y >= 99.8
(II) fglrx(0): detected X.org 7.0.0.0
(II) Loading extension ATIFGLRXDRI
(II) fglrx(0): doing DRIScreenInit
drmOpenDevice: node name is /dev/dri/card0
drmOpenDevice: open result is -1, (No such device or address)
drmOpenDevice: Open failed
[drm] failed to load kernel module "fglrx"
(II) fglrx(0): [drm] drmOpen failed
(EE) fglrx(0): DRIScreenInit failed!
(WW) fglrx(0): ***********************************************
(WW) fglrx(0): * DRI initialization failed!                  *
(WW) fglrx(0): * (maybe driver kernel module missing or bad) *
(WW) fglrx(0): * 2D acceleraton available (MMIO)             *
(WW) fglrx(0): * no 3D acceleration available                *
(WW) fglrx(0): ********************************************* *
(II) fglrx(0): FBADPhys: 0xc0000000 FBMappedSize: 0x07fe0000
(II) fglrx(0): FBMM initialized for area (0,0)-(1408,8191)
(II) fglrx(0): FBMM auto alloc for area (0,0)-(1408,1050) (front color buffer - assumption)
(==) fglrx(0): Backing store disabled
(==) fglrx(0): Silken mouse enabled
(**) fglrx(0): DPMS enabled
(WW) fglrx(0): Option "VendorName" is not used
(WW) fglrx(0): Option "ModelName" is not used
(II) fglrx(0): Using XFree86 Acceleration Architecture (XAA)
n°823737
toinou7500​9
Posté le 01-07-2006 à 11:44:47  profilanswer
Ah je précise aussi que ma carte est bien supporté par les drivers et que aussi lors de l'installation des drivers, en suivant le tuto ya manip qui ne fonctionner pas:
Compile the kernel module:
sudo module-assistant prepare,update
sudo module-assistant build,install fglrx
sudo depmod -a
EDIT: finalement "Compile the kernel module" fonctionne aller savoir pourquoi!
Message édité par toinou75009 le 01-07-2006 à 11:48:40
n°823745
toinou7500​9
Posté le 01-07-2006 à 12:04:26  profilanswer
YESSSSSSSSSSSSS sa fonctione!!!!!!!!!!!!!!!
Lors de ma première install, bizarrement "compile the kernel module" ne fonctionner pas, donc j'avais sauter l'étape!
Et là sà à bien compilé, et sa marche nickel!!!!!!!!!
Par contre quand je lance le panneau de control ati sous XGL/Compiz:
Driver does not  provide the fireGL X11 extensions!
Panel components will operate partially
De plus, je ne trouve pas le panneau de control XGL sous UBUNTU, pour régler mes différents paramètres 3D?
n°823746
toinou7500​9
Posté le 01-07-2006 à 12:23:42  profilanswer
Re question, je trouve sà bizarre:
antoine@antoine-laptop:~$ glxinfo | grep render Xlib:  extension "XFree86-DRI" missing on display ":1.0".
OpenGL renderer string: MOBILITY FireGL V3200 Pentium 4 (SSE2) (FireGL) (GNU_ICD)
OpenGL vendor string: ATI Technologies Inc.
OpenGL version string: 2.0.5879 (8.26.18)
Je précise que pourtant XGL marche nickel!!
n°823761
limax
Posté le 01-07-2006 à 13:15:32  profilanswer
une erreur
Message édité par limax le 01-07-2006 à 13:37:53
n°823827
sebchap
Share the knowledge
Posté le 01-07-2006 à 19:31:17  profilanswer
Il n'y a aucun souci pour le direct rendering: il n'est tout simplement pas supporté par Xgl :)
L'etape que tu avais sauté etait effectivemeent la plus importante puisque c'est elle qui créait le module fglrx (le driver en fait). Donc sans driver, tu ne pouvais pas le charger, evidemment :D
Pour configurer Compiz, tu as gconf-editor dans la rubrique apps/compiz ou alors tu as un outil appelé gset-compiz que tu peux installer (ou que tu as deja en installant compiz, je ne sais plus).
n°825306
Patrice_67
Posté le 06-07-2006 à 17:25:47  profilanswer
J'ai également installé XGL+KDE+DAPPER+ATI, sans trop de probleme.......
Il y a juste une chose que je ne comprend pas c'est l'option :1 de Xgl -fullscreen :1 -ac -accel glx:pbuffer -accel xv:pbuffer
J'ai essayer avec :0 mais cela ne marche pas.....
D'ailleurs toinou75009 si je fais un glxinfo | grep render j'obtient également :
OpenGL renderer string: RADEON 9800 XT Generic
Alors que si je fait export DISPLAY=:0 && glxinfo | grep render j'obtient
direct rendering: Yes
Et XGL marche sans probleme.....
Si quelqu'un a une idée sur cette option ???
Message édité par Patrice_67 le 06-07-2006 à 17:26:32
n°825381
sebchap
Share the knowledge
Posté le 06-07-2006 à 21:10:04  profilanswer
Avec ATI, Xgl est lancé sur le display :1 car le :0 ne marche pas (mystere de fglrx). En revanche, sur :0, c'est Xorg qui est lancé (par gdm) qui est est en fait le support de Xgl pour les drivers. Et sous Xorg, le direct rendering marche sans souci (contrairement a Xgl, où, je me repete, il n'existe pas)
Donc tout est normal :D
n°825398
Patrice_67
Posté le 06-07-2006 à 21:52:05  profilanswer
Euh dsl mais Xgl marche également sur le display :0 .....
En effet, j'ai essayé de lancer automatique Xgl au démarrage et pour cela j'ai modifier le fichier /etc/kde3/kdm/kdmrc (je suis sous KDE) comme suis :
[General]
ConfigVersion=2.3
ConsoleTTYs=tty1,tty2,tty3,tty4,tty5,tty6
PidFile=/var/run/kdm.pid
ReserveServers=:1,:2,:3
ServerVTs=-7
StaticServers=:0
[Shutdown]
BootManager=Grub
HaltCmd=/sbin/halt
RebootCmd=/sbin/reboot
[X-*-Core]
AllowNullPasswd=false
AllowRootLogin=false
AllowShutdown=Root
AutoReLogin=false
ClientLogFile=.xsession-errors-%s
Reset=/etc/kde3/kdm/Xreset
Session=/etc/kde3/kdm/Xsession
Setup=/etc/kde3/kdm/Xsetup
Startup=/etc/kde3/kdm/Xstartup
[X-*-Greeter]
AntiAliasing=true
ColorScheme=kubuntuColours
EchoMode=OneStar
FaceSource=AdminOnly
FailFont=Sans Serif,10,-1,5,75,0,0,0,0,0
GUIStyle=
GreetFont=Serif,20,-1,5,50,0,0,0,0,0
GreetString=Bienvenue sur la Kubuntu de %n
GreeterPos=50,50
HiddenUsers=
Language=fr
LogoArea=Logo
LogoPixmap=/usr/share/apps/kdm/pics/kdelogo.png
MaxShowUID=29999
MinShowUID=1000
Preloader=/usr/bin/preloadkde
SelectedUsers=
ShowUsers=NotHidden
SortUsers=true
StdFont=Sans Serif,10,-1,5,50,0,0,0,0,0
Theme=/usr/share/apps/kdm/themes/revolution_kdm_theme
Themes=/usr/share/apps/kdm/themes/revolution_kdm_theme,/usr/share/apps/kdm/themes/login-scan-fusion,/usr/share/apps/kdm/themes/Tux-Mania
UseBackground=true
UseTheme=true
UserCompletion=false
UserList=true
[X-:*-Core]
AllowNullPasswd=true
AllowShutdown=All
NoPassEnable=false
NoPassUsers=
ServerArgsLocal=-nolisten tcp
#ServerCmd=/usr/bin/X -br
ServerCmd=/usr/bin/Xgl -fullscreen :0 -ac -accel glx: pbuffer -accel xv: pbuffer
#Xgl extra lines
OpenRepeat=5
OpenDelay=15
OpenTimeout=2000
ServerTimeout=60
[X-:*-Greeter]
AllowClose=true
DefaultUser=pp
FocusPasswd=true
LoginMode=DefaultLocal
PreselectUser=Default
[X-:0-Core]
AutoLoginAgain=false
AutoLoginDelay=0
AutoLoginEnable=false
AutoLoginLocked=false
AutoLoginUser=pp
[Xdmcp]
Enable=false
Willing=/etc/kde3/kdm/Xwilling
Cependant cela pose un autre probleme, en lancant xgl sur le display :0 je ne peux plus faire tourne d'application 3D (i.e ET) alors qu'en utilisant la méthode ou j'ai le choix au demarrage entre XGL et Xorg il me suffissait de taper "export DISPLAY=:0 && XXXXXX "
Par contre, le seul avantage de cette maniere est l'acces au menu demarrer avec les 3 options (terminer session, redemarrer et arreter) ; option indisponible sur display :1 !!!!!
A moins que quelqu'un sache active cette fonction sur le display :1 ????  (je ne souhaite pas utiliser les raccourci kdesu halt et kdesu reboot.....il faut taper le mots de passe root....c'est long  :sarcastic:  :sarcastic: )
Peut-etre en modifiant le fichier kdmrc ci-dessus ???
Voila .... si quelqu'un a une idée......( ce n'ai pas qu'un grande importance mais c'est juste pour satisfaire ma curiosité :pt1cable:  :pt1cable:  :pt1cable:)
Message édité par Patrice_67 le 06-07-2006 à 22:20:05
n°825443
toinou7500​9
Posté le 07-07-2006 à 01:10:27  profilanswer
Juste pour info quand j'ai installé le couple XGL/Compiz, j'ai choisi la technique ou je peux choisir au moment du login, quelle session je veux utilisé, j'ai le choix par exemple entre XGL et celle par défaut (gnome).
Et quand je suis sous XGL, le bouton arretter me donne le choix entre fermer la session, hiberner, et l'autre je me souvient plus.
  Installation
msn live probleme...???Problème : Cygwin + ssh+ OpenGL
probleme install mandriva 2006 error 17Problème reconnaissance carte TV sous Fedora 5
[Réglé]Problème d'affichage au démarrage de suse 10.1[ OpenSuse ] [ Gnome ] [ kdeTV & all ] problème de son
problème switch hp procurve 2424mProblème DLL
problème image webcam sous kopete et autres applis utilisant v4linstall opensuse : problème de catalogue (résolu)
Plus de sujets relatifs à : Problème XGL/COMPIZ et driver ati pour une Mobility FireGl v3200
