2751 connectés
  Linux et OS Alternatifs
  Installation
  Mandrake 9.2 + Ecran plat + GeForce = pas de mode graphique X ?
n°392441
le_duc
PlaTyPuS
Posté le 19-01-2004 à 19:48:30  profilanswer
Hello all!
J'aimerais vraiment faire marcher Linux Mandrake 9.2 en mode graphique.... mais j'y arrive pas!!!
Voilà ma config :
- Ecran Plat Samsung 181T (en DVI)
- GeForce 4 TI 4200
- Mandrake 9.2 installé en mode texte donc
Et voilà la gueule de mon XF86Config-4
Code :
  1. Section "Files"
  2.     # Multiple FontPath entries are allowed (they are concatenated together)
  3.     # By default, Mandrake 6.0 and later now use a font server independent of
  4.     # the X server to render fonts.
  5.     FontPath "unix/:-1"
  6. EndSection
  7. Section "ServerFlags"
  8.     #DontZap # disable <Crtl><Alt><BS> (server abort)
  9.     #DontZoom # disable <Crtl><Alt><KP_+>/<KP_-> (resolution switching)
  10.     AllowMouseOpenFail # allows the server to start up even if the mouse doesn't work
  11. EndSection
  12. Section "Module"
  13.     Load "dbe" # Double-Buffering Extension
  14.     Load "v4l" # Video for Linux
  15.     Load "extmod"
  16.     Load "type1"
  17.     Load "freetype"
  18.     Load "glx" # 3D layer
  19. EndSection
  20. Section "InputDevice"
  21.     Identifier "Keyboard1"
  22.     Driver "Keyboard"
  23.     Option "XkbModel" "pc105"
  24.     Option "XkbLayout" "fr_CH"
  25.     Option "XkbOptions" ""
  26. EndSection
  27. Section "InputDevice"
  28.     Identifier "Mouse1"
  29.     Driver "mouse"
  30.     Option "Protocol" "IMPS/2"
  31.     Option "Device" "/dev/usbmouse"
  32.     Option "ZAxisMapping" "4 5"
  33. EndSection
  34. Section "Monitor"
  35.     Identifier "monitor1"
  36.     VendorName "Samsung"
  37.     ModelName "SyncMaster 181T"
  38.     HorizSync 30.0-81.0
  39.     VertRefresh 56.0-85.0
  40.
  41.     # 1024x480 @ 85.6 Hz, 48 kHz hsync
  42.     ModeLine "1280x1024@60i"     49 1280 1312 1496 1528 1024 1047 1053 1077 interlace
  43. EndSection
  44. Section "Device"
  45.     Identifier "device1"
  46.     VendorName "LeadTek"
  47.     BoardName "LeadTek NVIDIA GeForce4 TI 4200 64MB"
  48.     Driver "nv"
  49.     Option "DPMS"
  50. EndSection
  51. Section "Screen"
  52.     Identifier "screen1"
  53.     Device "device1"
  54.     Monitor "monitor1"
  55.     DefaultColorDepth 24
  56.
  57.     Subsection "Display"
  58.         Depth 16
  59.         Virtual 1280 1024
  60.     EndSubsection
  61.
  62.     Subsection "Display"
  63.         Depth 24
  64.         Virtual 1280 1024
  65.     EndSubsection
  66. EndSection
  67. Section "ServerLayout"
  68.     Identifier "layout1"
  69.     Screen "screen1"
  70.     InputDevice "Keyboard1" "CoreKeyboard"
  71.     InputDevice "Mouse1" "CorePointer"
  72. EndSection
Vous avez une idée du problème???
Merci pour votre aide!
PS: et une autre question au passage, c'est possible de lire les partitions linux (ext3) avec windows ??[cpp]
n°392445
Pizz
Vive les Tomates !
Posté le 19-01-2004 à 19:52:22  profilanswer
installe les drivers NVidia, ça ira mieux
C'est quand on a le nez dans la tomate qu'on voit mieux la tomate !
n°392461
le_duc
PlaTyPuS
Posté le 19-01-2004 à 20:10:32  profilanswer
ouais... j'vais essayer  ;)
n°392474
napalm57
Posté le 19-01-2004 à 20:26:04  profilanswer
Quels drivers nvidia faut il installer sous linux???
n°392479
le_duc
PlaTyPuS
Posté le 19-01-2004 à 20:39:29  profilanswer
ben ceux disponible sur leur site je suppose :D.
n°392485
le_duc
PlaTyPuS
Posté le 19-01-2004 à 20:41:58  profilanswer
bon, j'ai essayé d'installer ces drivers, mais l'install ne fonctionne pas et me met directement l'erreur suivante :
"Unable to find the security utility 'ld' ; please make sure you have the package binutils installed. If you do have binutils installed then please check taht 'ld' is in your PATH.
Pour info, j'ai lancé l'install depuis /tmp/ . Faudrait copier le driver dans un emplacement spécifique ?? Je n'ai rien lu de tel dans le readme....
Sinon, je peux faire comment pour savoir si le package "binutils" est installé??
Merci.
Message édité par le_duc le 19-01-2004 à 20:46:08
n°392490
leto
Posté le 19-01-2004 à 20:48:12  profilanswer
"please make sure you have the package binutils installed"
Donc moi je dirais un petit "urpmi binutils" .
n°392502
Pizz
Vive les Tomates !
Posté le 19-01-2004 à 21:03:00  profilanswer
oui et il faut les sources du kernel aussi.
n°392505
le_duc
PlaTyPuS
Posté le 19-01-2004 à 21:05:29  profilanswer
ouais, c cool, mais en francais, ca donne koi? :D
Bon pour le message de leto3, je vais aller taper ce qu'il y a entre guillemets dans ma ligne de commande et je verrai ce qu'il me retourne.
Mais pour le message de Pizz, je fais comment pour avoir les sources du kernel et ca me servira à quoi?
Merci!
n°392507
napalm57
Posté le 19-01-2004 à 21:07:04  profilanswer
Ca va etre la joix d'installer et de configurer linux , je vais avoir un beau week end [:joce]
n°392512
ipnoz
Sapé comme jamais !
Posté le 19-01-2004 à 21:12:41  profilanswer
tape su dans une console , puis entre ton mot de passe root .
la fais un #urpmi binutils , puis un urpmi kernel-source
puis retente l'installation de tes drivers nvidia
n°392530
le_duc
PlaTyPuS
Posté le 19-01-2004 à 21:38:50  profilanswer
yes, c bon! j'ai juste du taper "urpmi binutils" puis installer les drivers :).
Ca marche nickel et c'est BEAU ;)
Merci à vous!
n°392550
leto
Posté le 19-01-2004 à 22:19:08  profilanswer
la magie d'urpmi .
Si tu veux installer un quelconque logiciel , tappe d'abord "urpmi nom-du-logiciel" . et pour désinstaller "urpme nom" .
plus d'info : http://linux-wizard.tuxfamily.org/howto_rpm.html#urpmi
http://urpmi.org/easyurpmi/index.php
n°392759
Dark_Schne​ider
Close the World, Open the Net
Posté le 20-01-2004 à 13:47:25  profilanswer
http://linux-wizard.tuxfamily.org/howto_nvidia.html
Mandriva : parce que nous le valons bien ! http://linux-wizard.net/index.php
  Installation
[Mandrake Move] CD bootable qui marche pasnewbie mandrake 9.2 et lecteur cd/rw
[PB] Ecran redimensionné sur un portable.Freebox sous mandrake 9.2
[mandrake move] J'arrive pas à créer une clef usb virtuellechangement de carte graphique bas de gamme, conseils?
mandrake et serveur web d'adminstration type clarckonnect[MDK 9.2] Carte Son & Graphique - probleme
install adsl bewan sur mandrake 9.0Ati radeon 9800pro et Mandrake
Plus de sujets relatifs à : Mandrake 9.2 + Ecran plat + GeForce = pas de mode graphique X ?
