2685 connectés
  Linux et OS Alternatifs
  Installation
  kernel source de fc3
n°652015
tomtom41
It's not a bug, it's a feature
Posté le 19-03-2005 à 14:31:20  profilanswer
voila j'aimerais installer le kernel-source de ma fedora 3 mais je n'y arrive pas...:(
tout d'abord je suis surpris de ne pas le trouver sur un des 4 cds mais bon...:??:
ensuite après une rapide recherche je suis allé sur kernel.org mais je n'arrive pas à trouver une version rpm du kernel source...
où puis je le trouver sous forme de rpm ?
merci pour votre aide.
Code :
  1. [root@localhost RPMS]# uname -r
  2. 2.6.9-1.667
n°652017
Mjules
Modérateur
Parle dans le vide
Posté le 19-03-2005 à 14:36:19  profilanswer
In order to eliminate the redundancy inherent in providing a separate package for the kernel source code when that source code already exists in the kernel's .src.rpm file, Fedora Core 3 no longer includes the kernel-source package. Users that require access to the kernel sources can find them in the kernel .src.rpm file. To create an exploded source tree from this file, perform the following steps (note that <version>  refers to the version specification for your currently-running kernel):
   1.
      Obtain the kernel-<version>.src.rpm file from one of the following sources:
            The SRPMS directory on the appropriate "SRPMS" CD iso image
            The FTP site where you got the kernel package
            By running the following command:
            up2date --get-source kernel
   2.
      Install kernel-<version>.src.rpm (given the default RPM configuration, the files this package contains will be written to /usr/src/redhat/)
   3.
      Change directory to /usr/src/redhat/SPECS/, and issue the following command:
      rpmbuild -bp --target=<arch> kernel.spec
      (Where <arch> is the desired target architecture.)
      On a default RPM configuration, the kernel tree will be located in /usr/src/redhat/BUILD/
http://wftp.tu-chemnitz.de/pub/lin [...] ES-en.html
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°652020
tomtom41
Posté le 19-03-2005 à 14:39:49  profilanswer
merci :)
  Installation
Bind & FC3[Debian] Quel kernel?
[non résolu mais clos] reboot sauvage après plantage => kernel panicFedora 2 update du kernel
mise à jour mdk 10.0 à 10.1 avec ancien kernelKernel 2.6.x => Pas de Plug&Play
Compilation Kernel 2.6.11 patché nitro0 equivalent d'outlook en open source?
soundcard cmi8738 sur kernel 2.6.8.1-10mdkkernel panic après retaille de partition sous win
Plus de sujets relatifs à : kernel source de fc3
