1169 connectés
  Linux et OS Alternatifs
  Installation
  [KDE] Kde + Sid = pb
n°249409
impulse
Posté le 15-04-2003 à 01:55:09  profilanswer
apres avoir teste la Knoppix (vraiment excellente cette "distro"!) j'ai envie d'installer KDE 3.1 sur ma Debian (Sid) pour voir ce que ca donne par rapport a mon bon vieux fluxbox. Malheureusement il y a un pb qd j'essaye de l'"apt-getiser"...
Code :
  1. luffy:/home/domi# apt-get install kde
  2. Reading Package Lists... Done
  3. Building Dependency Tree... Done
  4. Some packages could not be installed. This may mean that you have
  5. requested an impossible situation or if you are using the unstable
  6. distribution that some required packages have not yet been created
  7. or been moved out of Incoming.
  8. Since you only requested a single operation it is extremely likely that
  9. the package is simply not installable and a bug report against
  10. that package should be filed.
  11. The following information may help to resolve the situation:
  12. Sorry, but the following packages have unmet dependencies:
  13.   kde: Depends: kdelibs3 but it is not installable
  14.        Depends: libarts but it is not installable or
  15.                 libarts-alsa but it is not installable or
  16.                 libarts-bin but it is not installable
  17.        Depends: libkmid but it is not installable or
  18.                 libkmid-alsa but it is not installable or
  19.                 libkmid-bin but it is not installable
  20.        Depends: kdebase-audiolibs but it is not installable or
  21.                 kdebase3-audiolibs but it is not installable
  22.        Depends: kdebase-libs but it is not installable or
  23.                 kdebase3-libs but it is not installable
  24.        Depends: kdebase-doc but it is not installable or
  25.                 kdebase3-doc but it is not installable
  26.        Depends: kdewallpapers but it is not installable or
  27.                 kdewallpapers3 but it is not installable
  28.        Depends: kab but it is not installable
  29.        Depends: kpm but it is not installable
  30.        Depends: kfract but it is not installable
  31. E: Sorry, broken packages
Je suis passe il y a seulement qques semaines a la Sid et je n'ai pas eu de pb de ce genre avt. Est ce que c'est frequent? Qu'y a-t-il a faire? Attendre que le pb soit resolu? Pas d'autre solution?
Merci de m'eclairer, vous les users de Sid! :D
n°249411
udok
La racaille des barbus ©clémen
Posté le 15-04-2003 à 02:02:24  profilanswer
çaa déjà été dit ça  :o
:~$ apt-cache show kde
Package: kde
Priority: optional
Section: kde
Installed-Size: 48
Maintainer: Debian QA Group <packages@qa.debian.org>
Architecture: all
Source: meta-kde
Version: 4:2.2.25
Depends: kdelibs3, libarts | libarts-alsa | libarts-bin, libkmid | libkmid-alsa | libkmid-bin, kdebase | kdebase3, kdebase-audiolibs | kdebase3-audiolibs, kdebase-libs | kdebase3-libs, libkonq3 | libkonq4, konqueror | konqueror3, kate | kate3, konsole | konsole3, kdebase-doc | kdebase3-doc, kscreensaver | kscreensaver3, kdewallpapers | kdewallpapers3, kuser, ksysv, kcron, kpackage, secpolicy, kghostview, kview, kmail, korn, ark, kab, karm, kcalc, kcharselect, kdepasswd, kdf, kedit, kfind, khexedit, kjots, knotes, kpm, kpaint, kiconedit, kfract, ksnapshot, kruler, kdict, kdm | x-display-manager, kit, knode, ksirc, koffice, knewsticker, ktimer, kcoloredit
Suggests: aktion, kde-i18n, kde-games, kde-extras, kde-devel, anti-aliasing-howto, kdessh, artsbuilder | artsbuilder3, kmix | kmix3, kscd | kscd3, noatun | noatun3, libarts-mpeglib | libarts3-mpeglib, korganizer, kdepim-libs
Filename: pool/main/m/meta-kde/kde_2.2.25_all.deb
MD5sum: 4029e970ffd3e6f06946c91000afb856
Description: The K Desktop Environment
 A metapackage containing dependencies for the core suite of KDE including
 kdelibs, kdebase, kdeadmin, kdegraphics, kdemultimedia, kdenetwork, kdepim,
 koffice, and kdeutils.  Provides Suggests and Recommends for all other
 KDE based packages.
 Does not contain depends for Toys, Games, or Development packages.
Task: desktop
regarde la version, le métapackage est pas encore passé à 3.1
par contre tu peux quazi tout installé à la main avec les "sous-métapackage"
à savoir kdelibs, kdebase, kdenetwork, etc ... (regarde les dépendences du métapackage "kde" et instal ;) )
Non au projet de loi DADVSI ! (droits d'auteurs)
n°249412
lucaramel
Posté le 15-04-2003 à 02:05:22  profilanswer
apt-get install arts kdelibs kdebase devrait suffire.
n°249414
impulse
Posté le 15-04-2003 à 02:18:56  profilanswer
:p
Oki, merci.
  Installation
(KDE) transparence !Grosses Updates pour Mandrake 9.1 NEW : KDE 3.1.1a
KDE disparu suite à mise à jour Gentoocomment lancer une tache au login sous KDE ....
[MDK 9.0] Mise à jour de KDE[KDE 3.1] Comment changer l'icone de la corbeille ?
Comment virer KDE au demarrage ?[Debian]De l'intérêt de passer en Sarge ou en Sid
REDHAT8 + KDE sur P100 40Mo 4Go?Mozilla 1.3 de Debian SID déconne? (topic récurrent)
Plus de sujets relatifs à : [KDE] Kde + Sid = pb
