jerryone3 Gamer | Bonjour,
J'essaie en vain de mettre à jour portage. J'ai tout d'abord effectué un emerge --sync, qui m'a renvoyé le message suivant à la fin :
Code :
- >>> Updating Portage cache:
- Invalid ebuild name: /usr/portage/app-admin/389-admin-console/389-admin-console-1.1.8.ebuild
- Invalid ebuild name: /usr/portage/app-admin/389-admin-console/389-admin-console-1.1.7.ebuild
- Invalid ebuild name: /usr/portage/app-admin/389-console/389-console-1.1.6.ebuild
- Invalid ebuild name: /usr/portage/app-admin/389-console/389-console-1.1.7.ebuild
- Invalid ebuild name: /usr/portage/app-admin/389-ds-console/389-ds-console-1.2.6.ebuild
- Invalid ebuild name: /usr/portage/app-admin/389-ds-console/389-ds-console-1.2.3-r1.ebuild 23%
- Invalid ebuild name: /usr/portage/dev-libs/389-adminutil/389-adminutil-1.1.13.ebuild
- Invalid ebuild name: /usr/portage/dev-libs/389-adminutil/389-adminutil-1.1.14.ebuild
- Invalid ebuild name: /usr/portage/dev-libs/389-adminutil/389-adminutil-1.1.10.ebuild 50%
- Invalid ebuild name: /usr/portage/games-rpg/eschalon-book-1-demo/eschalon-book-1-demo-105.ebuild
- Invalid ebuild name: /usr/portage/games-rpg/eschalon-book-1-demo/eschalon-book-1-demo-106.ebuild 74%
- Invalid ebuild name: /usr/portage/net-nds/389-admin/389-admin-1.1.16.ebuild
- Invalid ebuild name: /usr/portage/net-nds/389-admin/389-admin-1.1.23.ebuild
- Invalid ebuild name: /usr/portage/net-nds/389-ds-base/389-ds-base-1.2.8.3.ebuild
- Invalid ebuild name: /usr/portage/net-nds/389-ds-base/389-ds-base-1.2.9.6.ebuild 91%
- Invalid ebuild name: /usr/portage/www-apps/389-dsgw/389-dsgw-1.1.5.ebuild
- Invalid ebuild name: /usr/portage/www-apps/389-dsgw/389-dsgw-1.1.6.ebuild
- Invalid ebuild name: /usr/portage/www-apps/389-dsgw/389-dsgw-1.1.7.ebuild 100%
- * An update to portage is available. It is _highly_ recommended
- * that you update portage now, before any other packages are updated.
- * To update portage, run 'emerge portage' now.
J'ai donc fait un 'emerge portage', qui m'a donné le résultat suivant :
Code :
- !!! /etc/make.profile is not a symlink and will probably prevent most merges.
- !!! It should point into a profile within /usr/portage/profiles/
- !!! (You can safely ignore this message when syncing. It's harmless.)
- Calculating dependencies /
- !!! All ebuilds that could satisfy "sys-apps/portage" have been masked.
- !!! One of the following masked packages is required to complete your request:
- - sys-apps/portage-9999 (masked by: EAPI 2)
- - sys-apps/portage-2.2.0_alpha59 (masked by: EAPI 2)
- - sys-apps/portage-2.2.0_alpha58 (masked by: EAPI 2)
- - sys-apps/portage-2.2.0_alpha51 (masked by: EAPI 2)
- - sys-apps/portage-2.1.10.19 (masked by: EAPI 2)
- - sys-apps/portage-2.1.10.18 (masked by: EAPI 2)
- - sys-apps/portage-2.1.10.11 (masked by: EAPI 2)
- - sys-apps/portage-2.1.10.3 (masked by: EAPI 2)
- - sys-apps/portage-2.1.9.42 (masked by: EAPI 2)
- - sys-apps/portage-2.1.6.13 (masked by: missing keyword)
- - sys-apps/portage-2.1.6.7 (masked by: missing keyword)
- - sys-apps/portage-2.1.4.4 (masked by: )
- The current version of portage supports EAPI '1'. You must upgrade to a
- newer version of portage before EAPI masked packages can be installed.
- For more information, see MASKED PACKAGES section in the emerge man page or
- refer to the Gentoo Handbook.
Pour information, 'emerge --info' donne ceci :
Code :
- Portage 2.1.4.4 (unavailable, gcc-3.4.5, glibc-2.3.6-r3, 2.6.34.6-xxxx-grs-ipv6-64 x86_64)
- System uname: 2.6.34.6-xxxx-grs-ipv6-64 x86_64 Intel(R) Core(TM)2 Quad CPU Q6700 @ 2.66GHz
- Timestamp of tree: Tue, 20 Sep 2011 08:00:01 +0000
- app-shells/bash: 3.2_p17
- dev-lang/python: 2.4.4-r6
- dev-util/pkgconfig: 0.20
- sys-apps/baselayout: 1.11.14-r8
- sys-apps/sandbox: 1.2.18.1-r2
- sys-devel/autoconf: 2.13, 2.61-r1
- sys-devel/automake: 1.4_p6, 1.5, 1.6.3, 1.7.9-r1, 1.8.5-r3, 1.9.6-r1, 1.10
- sys-devel/binutils: 2.16.1-r2
- sys-devel/gcc: 3.4.5
- sys-devel/gcc-config: 1.3.13-r2
- sys-devel/libtool: 1.5.22
- sys-devel/make: 3.80-r4
- sys-kernel/linux-headers: 2.6.11-r2
- sys-libs/glibc: 2.3.6-r3
- virtual/os-headers: 2.6.11-r2
- CBUILD="x86_64-pc-linux-gnu"
- CFLAGS="-O2 -pipe -march=nocona"
- CHOST="x86_64-pc-linux-gnu"
- CONFIG_PROTECT="/etc /usr/local/apache/conf /usr/local/lib/php4 /usr/local/lib/php5 /var/bind"
- CONFIG_PROTECT_MASK="/etc/env.d /etc/terminfo"
- CXXFLAGS="-O2 -pipe -march=nocona"
- DISTDIR="/usr/portage/distfiles"
- FEATURES="distlocks metadata-transfer sfperms strict unmerge-orphans userfetch"
- GENTOO_MIRRORS="http://mirror.ovh.net/gentoo-distfiles/ ftp://mirror.ovh.net/gentoo-distfiles/"
- LANG="fr_FR@euro"
- MAKEOPTS="-j2"
- PKGDIR="/usr/portage/packages"
- PORTAGE_CONFIGROOT="/"
- PORTAGE_RSYNC_OPTS="--recursive --links --safe-links --perms --times --compress --force --whole-file --delete --stats --timeout=180 --exclude=/distfiles --exclude=/local --exclude=/packages"
- PORTAGE_TMPDIR="/var/tmp"
- PORTDIR="/usr/portage"
- PORTDIR_OVERLAY="/usr/local/portage-ovh"
- SYNC="rsync://rsync.gentoo.org/gentoo-portage"
- USE="mmx multilib netboot sse sse2"
- Unset: ACCEPT_KEYWORDS, CPPFLAGS, CTARGET, EMERGE_DEFAULT_OPTS, FFLAGS, INSTALL_MASK, LC_ALL, LDFLAGS, LINGUAS, PORTAGE_COMPRESS, PORTAGE_COMPRESS_FLAGS, PORTAGE_RSYNC_EXTRA_OPTS
Merci d'avance pour votre aide ! ---------------
Fear leads to anger, anger leads to hate, hate leads to suffuring and suffering leads to the Dark Side...
