2872 connectés
  Linux et OS Alternatifs
  Installation
  [HELP] Probleme avec la gestion des packages sous Debian woody :(
n°214215
aurelboiss
Posté le 21-01-2003 à 08:11:15  profilanswer
J'ai telecharger un le package java sur un ftp soit disant compiler pour la woody mais lorsque j'ai voulu l'installer il ma montrer qu'il y avait des problemes entre les dependances et surtout les versions de glibc et autre donc il ne c'est pas installer. Plus tard j'ai voulu installu galeon (mozilla etant deja installe la veille) en tapant apt-get install galeon et la il me sort des messages de oufffff:
woody:~# apt-get install galeon
Reading Package Lists... Done
Building Dependency Tree... Done
You might want to run `apt-get -f install' to correct these:
Sorry, but the following packages have unmet dependencies:
  galeon: Depends: gdk-imlib1 but it is not going to be installed
          Depends: libart2 (>= 1.2.13-5) but it is not going to be installed
          Depends: libgconf11 (>= 1.0.7) but it is not going to be installed
          Depends: libglade-gnome0 but it is not going to be installed
          Depends: libglade0 but it is not going to be installed
          Depends: libgnome-vfs0 (>= 1.0.3-2) but it is not going to be installed
          Depends: libgnome32 (>= 1.2.13-5) but it is not going to be installed
          Depends: libgnomesupport0 (>= 1.2.13-5) but it is not going to be installed
          Depends: libgnomeui32 (>= 1.2.13-5) but it is not going to be installed
          Depends: liboaf0 (>= 0.6.10) but it is not going to be installed
          Depends: liborbit0 (>= 0.5.16) but it is not going to be installed
          Depends: libxml1 (>= 1:1.8.14-3) but it is not going to be installed
          Depends: oaf (>= 0.6.10) but it is not going to be installed
          Depends: galeon-common (= 1.2.5-0.woody.1) but it is not going to be installed
  j2re1.4: Depends: j2se-common (> 1) but it is not installable
           Depends: gsfonts-x11 but it is not going to be installed
           Depends: libc6 (>= 2.3.1-1) but 2.2.5-11.2 is to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
Je comprends ce que ca veut dire mais je ne vois pas en quoi maintenant galeon ne peut plus s'installer. Si vous pouviez m'aider un petit peut :d parce que la j comprend franchement rien du tout.
Message édité par aurelboiss le 21-01-2003 à 08:11:36
n°214236
aurelboiss
Posté le 21-01-2003 à 10:00:25  profilanswer
non c bon merci je vien de trouver l'erreur je croyais qu'il n'avait pas installe le java parce qu'en tapant dpkg -l | grep j2re alors que ce matin en tapant en desespoir de cause apt-get remove --purge j2re ca la desinstaller comme quoi il etait installer :( enfin maintenant ca marche ;)
Merci JoWiLe
n°214240
s0d4
Je charge des sacs de sable
Posté le 21-01-2003 à 10:01:26  profilanswer
normalement, en faisant apt-get install -f ça devrait résoudre tes problemes
n°214357
aurelboiss
Posté le 21-01-2003 à 14:31:52  profilanswer
ouai c ce que g fait pour installer le java mais regarde le resultat apres il me sortait des conflits a la pelle MDR g pas envie de tout casser sur ma Debian.
n°214446
aurelboiss
Posté le 21-01-2003 à 18:13:07  profilanswer
y'a personne pour m'aider :d
@++ [s]
n°214459
aurelboiss
Posté le 21-01-2003 à 18:48:28  profilanswer
euhhh tu crois que dans ce package y'a le plugin java comme dans le j2re ???
n°214491
aurelboiss
Posté le 21-01-2003 à 19:59:51  profilanswer
c'est bon j'ai installe le "j2re1.1" et ca marche pas trop mal ;) merci pour ta contribution
  Installation
[debian] compil kernel 2.4.20 -> lilo cassé. initrd??[Souris & Debian] Probleme de souris asthmatique
Debian + LILO = démarrage hyper lent de NT2000Nessus 1.3 et source debian/apt ?
DHCP + 2 cartes reseau + debian sidprobleme de memoire sous xp
Mandrake 9 juste installer et KDE pose problèmeinstalle radeon 8500 sur debian en DRM/DRI : pb !!!! ke faire ???
[Samba] Problème d'exploration entre deux sous-réseaux
Plus de sujets relatifs à : [HELP] Probleme avec la gestion des packages sous Debian woody :(
