955 connectés
  Linux et OS Alternatifs
  Installation
  Mon fichier de zone me pose des soucis
quel est le serveur dns le plus utilisé
100.0 %
 4 votes
1.  bind9
0.0 %
        0 vote
2.  djbdns
Total : 8 votes (4 votes blancs)
n°822329
koko_ro
Posté le 26-06-2006 à 13:26:31  profilanswer
Mon serveur dns (bind9) ne marche à cause de mon fichier de zone (je suppose).
named-checkzone sndi.org /var/cache/bind/sndi.org me ramène les erreurs suivantes:
dns_master_load: /var/cache/bind/sndi.org:16: unknown RR type 'sndi.org.'
dns_master_load: /var/cache/bind/sndi.org:18: unknown RR type 'localhost'
dns_master_load: /var/cache/bind/sndi.org:19: unknown RR type 'stage1'
dns_master_load: /var/cache/bind/sndi.org:20: unknown RR type 'sndi-ci.net'
dns_master_load: /var/cache/bind/sndi.org:22: unknown RR type 'www'
dns_master_load: /var/cache/bind/sndi.org:23: unknown RR type 'mailhost'
dns_master_load: /var/cache/bind/sndi.org:24: unknown RR type 'ftp'
dns_master_load: /var/cache/bind/sndi.org:25: unknown RR type 'ntinstall'
dns_master_load: /var/cache/bind/sndi.org:27: unknown RR type 'sndi.org.'
dns_master_load: /var/cache/bind/sndi.org:28: unknown RR type 'sndi.org.'
dns_master_load: /var/cache/bind/sndi.org:29: unknown RR type 'sndi.org.'
zone sndi.org/IN: loading master file /var/cache/bind/sndi.org: unknown class/type
named.conf n'a pas de problème.
Voici le contenu de fichier de zone
$ORIGIN sndi.org.
$TTL 86400
@       IN      SOA     stage1.sndi.org.        root.dns.sndi.org (
        ;Serial
        2006062601
        ; Refresh.
        86400
        ; Retry.
        300
        ; Expire.
        2592000
        ; TTL (Time To Live) minimum.
        86400
        ; ENREGISTREMENTS "NS"
        sndi.org.               IN      NS      stage1
        ;ENREGISTREMENTS "A"
        localhost       IN      A       127.0.0.1
        stage1          IN      A       192.168.201.250
        sndi-ci.net     IN      A       10.6.8.1
        ; ENREGISTREMENTS "CNAME"
        www             IN      CNAME   stage1
        mailhost        IN      CNAME   stage3
        ftp             IN      CNAME   stage4
        ntinstall       IN      CNAME   stage1
        ; ENREGISTREMENTS "MX"
        sndi.org.               IN      MX      250     stage1
        sndi.org.               IN      MX      20      stage3
        sndi.org.               IN      MX      30      stage4
Donnez moi un coup de maison.
n°822417
dreamkille​r
Posté le 26-06-2006 à 16:39:52  profilanswer
@       IN      SOA     stage1.sndi.org.        root.dns.sndi.org.(
manque pas un point la
ensuite il me semble que
sndi.org. est optionnel mais a confirmer
Message édité par dreamkiller le 26-06-2006 à 16:41:55
n°822864
koko_ro
Posté le 28-06-2006 à 14:02:25  profilanswer
Merci, il se comprte bien.
Je nous problème que j'ai est que: sur un poste distant je n'arrive pas à faire la resolution de nom.
C'est peut être parce que j'ai déjà un serveur dns que pour ip 10.6.6.100
Comment resoudre mon problème sans deranger le serveur existant.
n°822879
dreamkille​r
Posté le 28-06-2006 à 14:35:12  profilanswer
a ba le probleme c'est que c'est au serveur qui repond le plus vite
J'avai le meme probleme lors de test et j'ai du m'isole du reseau existant
n°822952
koko_ro
Posté le 28-06-2006 à 16:45:41  profilanswer
J'ai essayé en mettant un cable croisé entre mon poste serveur un un poste client.
La resolution de nom est toujours impossible.
n°822956
dreamkille​r
Posté le 28-06-2006 à 16:50:46  profilanswer
tien jette un oeuil des fois que sa puisse t aider
named.conf
//zone test
zone "test.fr" {
 type master;
 file "db.test.fr";
//zone test reverse
zone "0.0.10.in-addr.arpa" {
 type master;
 file "db.0.0.10";
db.test.fr:
$TTL 86400 ;1 Day
@ IN SOA server-test-1.test.fr. root.server-test-1.test.fr.(
  2006050201 ;serial
  14400  ;refesh (4H)
  7200  ;retry (2H)
  28800  ;expire (8H)
  14400  ;minimum (4H)
 IN NS server-test-1.test.fr.
floportlinux IN A 10.0.0.102
server-test-1 IN A 10.0.0.101
Fichier db.0.0.10:
$TTL 86400 ;1 Day
  2006050201 ;serial
  14400  ;refresh (4H)
  7200   ;retry (2H)
  28800  ;expire (8H)
  14400  ;minimum (4H)
101 PTR server-test-1.test.fr.
102 PTR floportlinux.test.fr.
n°822970
koko_ro
Posté le 28-06-2006 à 17:28:23  profilanswer
Nos config sont identics sauf que dans ton db.0.0.10, à la derniere partie je mettrai:
101  IN PTR server-test-..test.fr.
Est-ce que cela pose un problème.
n°823115
dreamkille​r
Posté le 29-06-2006 à 09:57:48  profilanswer
j'ai pas mon referentiel bind sous la main donc je peux pas te repondre mais ma conf fonctionne quand le serveur est totalement isole du reste du reseau ainsi que le client
n°823291
koko_ro
Posté le 29-06-2006 à 17:30:50  profilanswer
Merci, c'est coul.
J'ai refait les tests.
Il fonctionne parfaitement quant je deconnecte l'autre serveur.
Mon objectif final de d'installer un serveur de teledistribution d'application.
J'avais donc besoin d'un serveur DHCP
d'un serveur PXE
D'un serveur DNS et
d'un serveur TFTP.
Tous ces serveurs sont maintenant bien configurer, mais quand je liance le client il me dit
Mapping Z: to \\ntinstall\install...
Error 53: The computer name specified in the network path cannot be located/
Failed.  Retrying ....
Et a ce niveau il fait une boucle sans fin.
tu as une idée ?
n°823292
koko_ro
Posté le 29-06-2006 à 17:32:57  profilanswer
J'ai configuré aussi un serveur samba, qui tourne bien.
n°823407
dreamkille​r
Posté le 30-06-2006 à 09:37:26  profilanswer
c'est quoi ton client?? J'ai pas tout suivit a se niveau la
n°823415
koko_ro
Posté le 30-06-2006 à 10:07:58  profilanswer
Mon problème se pose sur 2 ordinateurs: 1 serveur et un client.
Le serveur de teledistribution contient 5 services (dhcp, dns, samba, pxe et atftp)
Le client est le poste sur qui je doit teledistribuer (c'est à dire faire une nouvelle installation de windows). Et c'est lui qui me ramène cette erreur.
n°826395
dreamkille​r
Posté le 11-07-2006 à 14:44:20  profilanswer
oups j'avais pas vu le message
ben on dirai que c'est ton dns qui deconne il arrive pas a resoudre le nom de machine
t as essaye de pinge depuis le client ton serveur en utilisant son nom
  Installation
Konqueror et fichier avec mauvaise extensions.Creer un fichier pdf ( word----> pdf)
Proftpd l'admin impossible de copier un fichier[DEBIAN] fichier resolv.conf qui se modifie tout seul
ou est mon fichier mysqlPetit soucis avec PHP et phpmyadmin
[Problème avec Ccleaner, récupérer un fichier ]ouvrir un fichier .bin
Gdm : configurer l'autologin via fichier confsoucis xorg
Plus de sujets relatifs à : Mon fichier de zone me pose des soucis
