jerem4579 | Bonjour,
Ayant installé un owncloud j'ai voulut installer Fail2ban sur ce même serveur mais j'ai toujours la même erreur et j'arrive pas à savoir d'où ça vient Job for fail2ban.service failed because the control process exited with error code. See "systemctl status fail2ban.service" and "journalctl -xe" for details.
● fail2ban.service - Fail2Ban Service
Loaded: loaded (/lib/systemd/system/fail2ban.service; enabled; vendor preset: enabled)
Active: inactive (dead) (Result: exit-code) since mer. 2017-05-03 09:13:38 CEST; 1h 2min ago
Docs: man:fail2ban(1)
Process: 4024 ExecStop=/usr/bin/fail2ban-client stop (code=exited, status=0/SUCCESS)
Process: 4046 ExecStart=/usr/bin/fail2ban-client -x start (code=exited, status=255)
Main PID: 2819 (code=killed, signal=TERM)
mai 03 09:13:38 FHISV024 systemd[1]: fail2ban.service: Control process exited, code=exited status=255
mai 03 09:13:38 FHISV024 systemd[1]: Failed to start Fail2Ban Service.
mai 03 09:13:38 FHISV024 systemd[1]: fail2ban.service: Unit entered failed state.
mai 03 09:13:38 FHISV024 systemd[1]: fail2ban.service: Failed with result 'exit-code'.
mai 03 09:13:38 FHISV024 systemd[1]: fail2ban.service: Service hold-off time over, scheduling restart.
mai 03 09:13:38 FHISV024 systemd[1]: Stopped Fail2Ban Service.
mai 03 09:13:38 FHISV024 systemd[1]: fail2ban.service: Start request repeated too quickly.
sudo journalctl -xe
-- L'unité (unit) fail2ban.service a terminé son arrêt.
-- Subject: L'unité (unit) fail2ban.service a échoué
-- Defined-By: systemd
-- Support: http://lists.freedesktop.org/mailm [...] temd-devel
-- L'unité (unit) fail2ban.service a échoué, avec le résultat failed.
mai 03 09:17:01 FHISV024 CRON[4050]: pam_unix(cron:session): session opened for user root by (uid=0)
mai 03 09:17:01 FHISV024 CRON[4051]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly)
mai 03 09:17:01 FHISV024 CRON[4050]: pam_unix(cron:session): session closed for user root
mai 03 09:20:15 FHISV024 systemd[1]: Starting Cleanup of Temporary Directories...
-- Subject: L'unité (unit) systemd-tmpfiles-clean.service a commencé à démarrer
-- L'unité (unit) systemd-tmpfiles-clean.service a commencé à démarrer.
mai 03 09:20:15 FHISV024 systemd-tmpfiles[4054]: [/usr/lib/tmpfiles.d/var.conf:14] Duplicate line for path "/var/lo
mai 03 09:20:15 FHISV024 systemd[1]: Started Cleanup of Temporary Directories.
-- Subject: L'unité (unit) systemd-tmpfiles-clean.service a terminé son démarrage
-- L'unité (unit) systemd-tmpfiles-clean.service a terminé son démarrage, avec le résultat done.
mai 03 09:39:01 FHISV024 CRON[4058]: pam_unix(cron:session): session opened for user root by (uid=0)
mai 03 09:39:01 FHISV024 CRON[4059]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && /usr/lib/php/sessionclean)
mai 03 09:39:01 FHISV024 CRON[4058]: pam_unix(cron:session): session closed for user root
mai 03 10:09:01 FHISV024 CRON[4103]: pam_unix(cron:session): session opened for user root by (uid=0)
mai 03 10:09:01 FHISV024 CRON[4104]: (root) CMD ( [ -x /usr/lib/php/sessionclean ] && /usr/lib/php/sessionclean)
mai 03 10:09:02 FHISV024 CRON[4103]: pam_unix(cron:session): session closed for user root
mai 03 10:16:03 FHISV024 sudo[4146]: root : TTY=pts/0 ; PWD=/home/admlocal ; USER=root ; COMMAND=/bin/systemctl
mai 03 10:16:03 FHISV024 sudo[4146]: pam_unix(sudo:session): session opened for user root by admlocal(uid=0)
mai 03 10:16:03 FHISV024 sudo[4146]: pam_unix(sudo:session): session closed for user root
mai 03 10:16:29 FHISV024 sudo[4149]: root : TTY=pts/0 ; PWD=/home/admlocal ; USER=root ; COMMAND=/bin/journalct
mai 03 10:16:29 FHISV024 sudo[4149]: pam_unix(sudo:session): session opened for user root by admlocal(uid=0)
Enfaite erreur de conf dans dans les fichiers c'est ok maintenant Message édité par jerem4579 le 03-05-2017 à 11:00:45 ---------------
- Cosmos RC-1000 avec fenêtre,Corsair AX 850W,Asus maximus IV Extreme Z,2600K,Corsair H100,Full Noctua P12,8 Go RAM,SLI GTX470,AsusD2X,Vertex 2 120Go
