1049 connectés
  Linux et OS Alternatifs
  Installation
  Debian et X server
Debian et X server
n°793933
Dreossk
Posté le 19-03-2006 à 18:18:43  profilanswer
J'ai installé Debian sur Virtual PC v5.3 mais je n'arrive pas à installer le X server pour avoir l'interface graphique.  J'ai fait la commande dpkg-reconfigure xserver-xfree86 pour tout configurer mais lorsque je démarre le X ça me met un message comme quoi ça ne fonctionne pas ainsi que:
XFree86 Version 4.3.0.1 (Debian 4.3.0.dfsg.1-14sarge1 20050901212727  st.localdomain)
Release Date: 15 August 2003
X Protocol Version 11, Revision 0, Release 6.6
Build Operating System: Linux 2.6.8-16.0508-2 i686 [ELF]
Build Date: 02 September 2005
This version of XFree86 has been extensively modified by the Debian
Project, and is not supported by the XFree86 Project, Inc., in any
way.  Bugs should be reported to the Debian Bug Tracking System; see
<URL: http://www.debian.org/Bugs/Reporting >.
We strongly encourage the use of the "reportbug" package and command
to ensure that bug reports contain as much useful information as
possible.
Si je vais voir le fichier /etc/X11/XF86Config-4 ça me donne:
Section "Files"
        FontPath        "unix/:7100"                    # local font server
        # if the local font server has problems, we can fall back on these
        FontPath        "/usr/lib/X11/fonts/misc"
        FontPath        "/usr/lib/X11/fonts/cyrillic"
        FontPath        "/usr/lib/X11/fonts/100dpi/:unscaled"
        FontPath        "/usr/lib/X11/fonts/75dpi/:unscaled"
        FontPath        "/usr/lib/X11/fonts/Type1"
        FontPath        "/usr/lib/X11/fonts/CID"
        FontPath        "/usr/lib/X11/fonts/Speedo"
        FontPath        "/usr/lib/X11/fonts/100dpi"
        FontPath        "/usr/lib/X11/fonts/75dpi"
EndSection
Section "Module"
        Load    "bitmap"
        Load    "dbe"
        Load    "ddc"
        Load    "extmod"
        Load    "freetype"
        Load    "int10"
        Load    "record"
        Load    "speedo"
        Load    "type1"
        Load    "vbe"
EndSection
Section "InputDevice"
        Identifier      "Generic Keyboard"
        Driver          "keyboard"
        Option          "CoreKeyboard"
        Option          "XkbRules"      "xfree86"
        Option          "XkbModel"      "pc104"
        Option          "XkbLayout"     "us"
EndSection
        Identifier      "Configured Mouse"
        Driver          "mouse"
        Option          "CorePointer"
        Option          "Device"                "/dev/psaux"
        Option          "Protocol"              "ImPS/2"
        Option          "ZAxisMapping"          "4 5"
EndSection
        Identifier      "Generic Mouse"
        Driver          "mouse"
        Option          "SendCoreEvents"        "true"
        Option          "Device"                "/dev/input/mice"
EndSection
Section "Device"
        Identifier      "ATI Radeon X800 XL"
        Driver          "ati"
EndSection
Section "Monitor"
        Identifier      "Samsung 915N"
        HorizSync       30-60
        VertRefresh     50-75
        Option          "DPMS"
EndSection
Section "Screen"
        Identifier      "Default Screen"
        Device          "ATI Radeon X800 XL"
        Monitor         "Samsung 915N"
        DefaultDepth    24
        SubSection "Display"
                Depth           1
                Modes           "1280x1024" "800x600" "640x480"
        EndSubSection
                Depth           4
        EndSubSection
                Depth           8
        EndSubSection
                Depth           15
        EndSubSection
                Depth           16
        EndSubSection
                Depth           24
        EndSubSection
EndSection
Section "ServerLayout"
        Identifier      "Default Layout"
        Screen          "Default Screen"
        InputDevice     "Generic Keyboard"
        InputDevice     "Configured Mouse"
        InputDevice     "Generic Mouse"
EndSection
Et pour terminer les specs de mon PC:
Carte mère : ASUS P5ND2-SLI Deluxe : Nvidia Nforce4 SLI
Processeur : Intel P4 640 - ATX - 3.2GHz - LGA775 - 2MB Cache
Mémoire : Corsair TWIN2X1024-5400C4 - DDR2-675 - 2 X 512MB - 4-4-4-12
Carte vidéo : ATI Radeon X800XL - 256MB - PCI-E - DVI/VGA
Disque dur : 2x Western Digital Caviar 200GB - SATA II - 7200RPM
Lecteur DVD : Pioneer DVR-109BK 16X Dual Layer DVD+RW/-RW
Écran : Samsung 915N II - 8ms - 700:1 - 19" - 1280x1024 - VGA
n°794013
Fork Bomb
Obsédé textuel
Posté le 19-03-2006 à 20:18:37  profilanswer
Passes a 16 en profondeur...
C'est peut-etre aussi simple que ca...
(et changes ton clavier au passage (tu as vraiment un qwerty americain ?))
Décentralisons Internet-Bépo-Troll Bingo - "Pour adoucir le mélange, pressez trois quartiers d’orange !"
n°794015
mirtouf
Light is right !
Posté le 19-03-2006 à 20:21:42  profilanswer
essaye avec le driver vesa.
n°794018
python
Posté le 19-03-2006 à 20:25:45  profilanswer
Il a une ATI, c'est peut-être pour ça
moi j'essaieraie une distrib récente avec un Xorg récent, l'install passerait mieux
une suggestion [:spamafote]
Message édité par python le 19-03-2006 à 20:25:59
n°794041
ccp6128
Syntax error
Posté le 19-03-2006 à 21:56:11  profilanswer
en meme temps c'est du virtual pc, pas sur que son matos soit celui de l'emu.
Effectivement teste avec le driver vesa, pis copie le message d'erreur ca pourrait servir.
n°794346
Dreossk
Posté le 20-03-2006 à 23:47:46  profilanswer
J'ai pris le driver vesa puis j'ai ajouté 1024x768 et ça fonctionne !
Merci !
  Installation
  Debian et X server
menu XFCE sous debian (et autres WM au passage)[Debian AMD64] avec quoi ouvrir des .doc ?
mandriva reconnait plextor en SATA mais pas debianSSH et DEBIAN HELP PLEASE
Probleme vlc sous debian[Debian] Donner tous les droits dans un repertoire? : Proftpd
Ajouter une autre carte réseau sur une debian : configurationDebian et Boot Personnalisé
install debian sarge r1aTV-Out en noir et blanc (Debian testing, nvidia 6600GT)
Plus de sujets relatifs à : Debian et X server
