1104 connectés
  Linux et OS Alternatifs
  Installation
  [Debian] apt-get install probleme !
n°221199
CtHuLhU50
Posté le 07-02-2003 à 19:49:56  profilanswer
salut a tous !
voila je voudrai developper en curses mais j'ai un pb :
je fais donc :
root@cthulhu:/home/cthulhu# apt-get  install libncurses5-dev
maissss paff erreurrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr
Reading Package Lists... Done
Building Dependency Tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
Sorry, but the following packages have unmet dependencies:
  libncurses5-dev: Depends: libncurses5 (= 5.2.20020112a-8) but 5.3.20021109-2 is to be installed
E: Sorry, broken packages
ke faire ????????????????????
Virtual 3D WorlD
n°221217
udok
La racaille des barbus ©clémen
Posté le 07-02-2003 à 20:16:15  profilanswer
tu as un probleme entre sources testing et source sid
montre ton /etc/apt/sources.list
n°221219
CtHuLhU50
Posté le 07-02-2003 à 20:19:22  profilanswer
deb http://security.debian.org stable/updates main contrib non-free
deb http://security.debian.org testing/updates main contrib non-free
# Stable
deb http://ftp2.de.debian.org/pub/debian stable main contrib non-free
deb http://ftp2.de.debian.org/pub/debian-non-US stable/non-US main contrib non-free
# Sources
deb-src http://ftp2.de.debian.org/pub/debian stable main contrib non-free
deb-src http://ftp2.de.debian.org/pub/debian-non-US stable/non-US main contrib non-free
# Testing
deb http://ftp2.de.debian.org/pub/debian testing main contrib non-free
deb http://ftp2.de.debian.org/pub/debian-non-US testing/non-US main contrib non-free
# Sources
deb-src http://ftp2.de.debian.org/pub/debian testing main contrib non-free
deb-src http://ftp2.de.debian.org/pub/debian-non-US testing/non-US main contrib non-free
# Unstable
deb http://ftp2.de.debian.org/debian unstable main contrib non-free
deb http://ftp2.de.debian.org/debian-non-US unstable/non-US main contrib non-free
# Sources
deb-src http://ftp2.de.debian.org/debian unstable main contrib non-free
deb-src http://ftp2.de.debian.org/debian-non-US unstable/non-US main contrib non-free
# Experimental
deb http://debian.uni-essen.de/debian ../project/experimental main contrib non-free
deb-src http://debian.uni-essen.de/debian ../project/experimental main contrib non-free
Virtual 3D WorlD
n°221240
udok
Posté le 07-02-2003 à 20:56:13  profilanswer
ouai bah voila ... tu as toutes les sources dans ton fichier de conf
tu as trouvé où ce fichier ? tu te l'es fait ?
quand tu as un tel fichier, il faut gérer, je ne sais plus trop comment
et préciser à apt-get avec l'option -t
regarde là :
http://www.teaser.fr/~pbatailler/A [...] .5.fr.html
ou comment toutes les sources sauf la principale
n°221244
udok
Posté le 07-02-2003 à 21:03:50  profilanswer
tiens bah je profite de ce topic :
http://qref.sourceforge.net/Debian [...] tml#s5.2.2
5.2.2 Méthode obsolète de mise à jour avec apt-get
L'utilisation de apt-get décrite ci-dessous est répandue mais n'est pas recommandée pour des mises à jour du système. Si vous devez mettre à jour sans dselect après Woody, considérez l'utilisation d'aptitudes ou d'autres options.
Si un système n'a pas beaucoup de paquets installés ou si l'archive Debian n'a pas de changements majeurs, ce qui suit peut être suffisant (parfois).
keskidilui ??  :??:
un connaisseur de debian pourrait-il m'expliquer ?
n°221246
udok
Posté le 07-02-2003 à 21:09:26  profilanswer
et :
man apt_preferences
  Installation
Pb installation alsa sous debian woodyproblème avec phpMyAdmin
(nouveau) probleme install kde 3.1probleme d'emulation de peripherique ide en scsi sous grub
J'ai un soucis apres l'install de Mandrake 9.0[debian]apt-get (package java)
probleme raid et mandrake 9, la je seche...Probleme install avec debian woody
Gros probleme install Debian[Debian Woody] Probleme d'install
Plus de sujets relatifs à : [Debian] apt-get install probleme !
