1726 connectés
  Linux et OS Alternatifs
  Installation
  comment installer des fonts pour mplayer/gmplayer ??
n°227899
Tomate
Posté le 24-02-2003 à 18:38:27  profilanswer
salut,
kan je lance gmplayer j ai ce msg d erreur :
Code :
  1. gmplayer
  2. Using GNU internationalization
  3. Original domain: messages
  4. Original dirname: /usr/share/locale
  5. Current domain: mplayer
  6. Current dirname: /usr/local/share/locale
  7. MPlayer 0.90rc4-2.95.4 (C) 2000-2003 Arpad Gereoffy (see DOCS)
  8. CPU: Advanced Micro Devices Duron MG Morgan (Family: 6, Stepping: 1)
  9. Detected cache-line size is 64 bytes
  10. CPUflags:  MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
  11. Compiled for x86 CPU with extensions: MMX MMX2 3DNow 3DNowEx SSE
  12. Reading config file /usr/local/etc/mplayer/mplayer.conf: No such file or directory
  13. Reading config file /home/tomate/.mplayer/config
  14. [cfg] read config file: /home/tomate/.mplayer/gui.conf
  15. Reading config file /home/tomate/.mplayer/gui.conf
  16. vo: X11 running at 1280x1024 with depth 16 and 16 bpp (":0.0" => local display)
  17. Reading /home/tomate/.mplayer/codecs.conf: can't open '/home/tomate/.mplayer/codecs.conf': No such file or directory
  18. Reading /usr/local/etc/mplayer/codecs.conf: 50 audio & 135 video codecs
  19. font: can't open file: /usr/local/share/mplayer/font/font.desc
  20. Cannot load font: /usr/local/share/mplayer/font/font.desc
  21. Failed to open /dev/rtc: Permission denied (mplayer should be setuid root or /dev/rtc should be readable by the user.)
  22. Using usleep() timing
  23. Can't open input config file /home/tomate/.mplayer/input.conf : No such file or directory
  24. Can't open input config file /usr/local/etc/mplayer/input.conf : No such file or directory
  25. Falling back on default (hardcoded) input config
  26. SKIN dir 1: '/home/tomate/.mplayer/Skin'
  27. SKIN dir 2: '/usr/local/share/mplayer/Skin'
  28. font: can't open file: /usr/local/share/mplayer/font/font.desc
  29. Cannot load font: /usr/local/share/mplayer/font/font.desc
donc je dois installer des fonts  :ange:
bon je suis allee sur le site de mplayer; j ai dl un .tar.bz2 de font, et apres je le fou ou :??:
je dois creer un sous rep fonts ds /usr/... ou ds /hotm/tomate/.mplayer/.. ???
bref, help :D
sinon, comment en regle general installer des nouvelles fonts, et particulierement les fonts truetype, car wine me fait chier avec  :hello:
n°227921
Mjules
Modérateur
Parle dans le vide
Posté le 24-02-2003 à 19:11:00  profilanswer
chez moi, elles sont dans :
/usr/share/mplayer/fonts
Celui qui pose une question est idiot 5 minutes. Celui qui n'en pose pas le reste toute sa vie. |  Membre du grand complot pharmaceutico-médico-scientifico-judéo-maçonnique.
n°227924
Tomate
Posté le 24-02-2003 à 19:11:46  profilanswer
ok et pour le fichier fonts.desc, je fe comment ??
n°227926
Mjules
Modérateur
Parle dans le vide
Posté le 24-02-2003 à 19:13:49  profilanswer
je sais pas, perso j'ai juste fait urpmi mplayer-fonts et il a installé tout ce qu'il fallait.  [:spamafote]
n°227927
Tomate
Posté le 24-02-2003 à 19:15:35  profilanswer
arf mplayer n est pas en deb (pb avec la team debian je crois) :(
n°228101
chaos0007
Posté le 25-02-2003 à 00:03:42  profilanswer
pour la debian : va sur le site de marillat.free.fr
n°228106
zeb_
Posté le 25-02-2003 à 00:24:14  profilanswer
Le mieux ce sont les truetype : j'ai tout expliqué dans le topic avec jotenakis sur tuxrip, partie installation, installation de mplayer. Un petit copier coller  (je te recommande la méthode 1, celle avec les truetype)
Méthode 1 : avec freetype>=2.0.9 et des polices truetype (ttf) installées.
 1) Compiler MPlayer avec
 ./configure --enable-freetype
--->  Vérifier que mplayer indique au minimum: Enabled optional drivers: Codecs: libavcodec libvorbis
 make && make install
 2) Créer un lien symbolique appelé subfont.ttf vers une fonte ttf installée
 - soit en global dans /usr/local/share/mplayer (en root)
exemple :
cd /usr/local/share/mplayer
ln -s /usr/X11R6/lib/X11/fonts/drakfont/ttf/times.ttf ./subfont.ttf
 - soit en local dans $HOME/.mplayer (en user)
exemple :
cd $HOME/.mplayer
 3) Utilisation
 - directement
 mplayer -osdlevel 2
 - lors de la lecture
 appuyer sur "o" pour changer le mode OSD (rien, symboles, symboles et chronomètre)
Méthode 2 : sans freetype et/ou sans fontes ttf
Voir la doc de mplayer points 1.4.2 et 1.4.3
 ./configure --enable-menu
 2) Il faut installer des fontes non ttf (celles-ci sont nécessaires pour les sous-titres également)
 Des polices sont disponibles sur le site de mplayer : ftp://ftp.mplayerhq.hu/MPlayer/releases/fonts/
 Les installer dans /usr/local/share/mplayer/font/ (en root)
 Exemple :
 copier le fichier mp-arial-iso-8859-1.zip dans /usr/local/share/mplayer/font
 3) Les décompresser (en root) :
 cd /usr/local/share/mplayer/font
 unzip ./mp-arial-iso-8859-1.zip
 Note : la décompression n'est PAS nécessaire pour les sous-titres, mais elle l'est pour l'osd.
 4) Copier le fichier menu.conf du répertoire /etc/ contenu dans les sources de MPlayer en global (dans /etc) ou en local (dans $HOME/.mplayer)
 Exemple :
 cp /usr/local/src/MPlayer-xxx/etc/menu.conf $HOME/.mplayer/
 5) Créer un lien symbolique dans $HOME/.mplayer vers l'un des répertoires contenant des polices.
 Exemple :
 ln -s /usr/local/share/mplayer/font/iso-8859-1/arial-24 font
 6) Utilisation
 Identique à la méthode 1
n°228107
zeb_
Posté le 25-02-2003 à 00:25:37  profilanswer
Evidemment tu rajouteras --enable-gui si tu veux le GUI avec --enable-freetype.
n°228215
Tomate
Posté le 25-02-2003 à 11:16:24  profilanswer
thx a lot  :jap:
  Installation
Installer Lindowspb a la con : GMplayer dans mon menu click droit de wmaker
puis-je installer XP malgré ce rapport d'incompatibilité ?[Debian Sid] Dépendances et packages sources de mplayer
Comment installer un src.RPM pour le transformer en binaire ?Quoi installer sur un 486 SX 33 avec 12Mo de ram ?
[Topik Unik] Mandrake 9.1OUT!!! A télécharger et à installer!!!(mandrake9.0) installer une carte son isa (je suis newbie)
Télécharger et installer RedHat sans graveurComment installer Direct X sous Linux avec Wine ?
Plus de sujets relatifs à : comment installer des fonts pour mplayer/gmplayer ??
