Forum |  HardWare.fr | News | Articles | PC | Prix | S'identifier | S'inscrire | Aide | Shop Recherche
2351 connectés
  Linux et OS Alternatifs
  Installation
  OpenVPN: Lan accessible mais Internet pas accessible
n°1281539
boobax
il BuongiornoSiVedeDalTacchino
Posté le 10-06-2011 à 09:50:54  profilanswer
Ca fait 8h que je galere mais je ne parviens pas a acceder a internet depuis le VPN.
J'accede a tout mon LAN sans pbm.
(MOI)192.168.0.11--->192.168.0.0||--->INTERNET--->||192.168.1.1--->192.168.1.11(VPN)
Voici mon /etc/openvpn/server.conf
# main configuration #
mode server
local 192.168.1.11
port 1194
proto udp
script-security 2
# bridging directive - this is needed to use the br0
dev tap0
# script to attach the tap0 interface to the bridge
up "/etc/openvpn/up.sh br0 tap0 1500"
down "/etc/openvpn/down.sh br0 tap0"
persist-key
persist-tun
#certificates and encryption
ca keys/ca.crt
cert keys/server.crt
key keys/server.key  # This file should be kept secret
dh keys/dh1024.pem
cipher BF-CBC   # Blowfish (default)
comp-lzo        # compression
# enable communication between vpn clients
client-to-client
# enable multiple access from the same client certificate
duplicate-cn
# DHCP configuration #
# ipp.txt saves the status of the dhcp leases
ifconfig-pool-persist ipp.txt
# pool of addresses available for VPN leases
# format: <server IP> <netmask> <pool start IP> <pool end IP>
server-bridge 192.168.1.11 255.255.255.0 192.168.1.220 192.168.1.229
# additional option to give to dhcp clients
push "dhcp-option DNS 192.168.1.1"
push "redirect-gateway def1"
push "route 192.168.1.0 255.255.255.0 192.168.1.1"
# maximium number of clients connected at a time
max-clients 10
# log and security #
user nobody
group nogroup
keepalive 10 120
status openvpn-status.log
verb 3
ifconfig
br0       Link encap:Ethernet  HWaddr x
          inet adr:192.168.1.11  Bcast:192.168.1.255  Masque:255.255.255.0
          adr inet6: x/64 Scope:Lien
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:10109 errors:0 dropped:0 overruns:0 frame:0
          TX packets:6529 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:0
          RX bytes:1073505 (1.0 MiB)  TX bytes:936947 (914.9 KiB)
eth1      Link encap:Ethernet  HWaddr x
          RX packets:9828 errors:0 dropped:0 overruns:0 frame:0
          TX packets:7252 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 lg file transmission:1000
          RX bytes:1212885 (1.1 MiB)  TX bytes:1006940 (983.3 KiB)
          Interruption:19 Adresse de base:0x6000
lo        Link encap:Boucle locale
          inet adr:127.0.0.1  Masque:255.0.0.0
          adr inet6: ::1/128 Scope:Hôte
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:268 errors:0 dropped:0 overruns:0 frame:0
          TX packets:268 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:18552 (18.1 KiB)  TX bytes:18552 (18.1 KiB)
tap0      Link encap:Ethernet  HWaddr 66:d4:35:cd:a6:8f
          UP BROADCAST RUNNING PROMISC MULTICAST  MTU:1500  Metric:1
          RX packets:113 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1048 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:9245 (9.0 KiB)  TX bytes:86083 (84.0 KiB)
/etc/openvpn/up.sh
#!/bin/sh
BR=$1
DEV=$2
MTU=$3
/sbin/ifconfig $DEV mtu $MTU promisc up
/usr/sbin/brctl addif $BR $DEV
#!/bin/sh
BR=$1
DEV=$2
/usr/sbin/brctl delif $BR $DEV
/sbin/ifconfig $DEV down
route -n
Table de routage IP du noyau
Destination     Passerelle      Genmask         Indic Metric Ref    Use Iface
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 br0
192.168.1.0     0.0.0.0         255.255.255.0   U     0      0        0 eth1
0.0.0.0         192.168.1.1     0.0.0.0         UG    0      0        0 eth1
0.0.0.0         192.168.1.1     0.0.0.0         UG    0      0        0 br0
brctl show
bridge name bridge id  STP enabled interfaces
br0  8000.003018a62792 no  eth1
                            tap0
J'ai mis net.ipv4.ip_forward=1 dans /etc/sysctl.conf pour activer le routage
Dans Iptables j'ai essayé tous types de configuration. Voici les dernieres commandes :
iptables -t nat -A POSTROUTING -o eth1 -j SNAT --to 192.168.1.1
iptables -A FORWARD -i tap0 -j ACCEPT
iptables -A INPUT -i tap+ -j ACCEPT
iptables -A FORWARD -i tap+ -j ACCEPT
iptables -t nat -A POSTROUTING -s 192.168.1.1/24 -o eth1 -j MASQUERADE
iptables -A INPUT -i tap0 -j ACCEPT
iptables -A INPUT -i br0 -j ACCEPT
iptables -A FORWARD -i br0 -j ACCEPT
Qui donnent :
Chain INPUT (policy ACCEPT)
target     prot opt source               destination
ACCEPT     all  --  anywhere             anywhere
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Chain PREROUTING (policy ACCEPT)
Chain POSTROUTING (policy ACCEPT)
SNAT       all  --  anywhere             anywhere            to:192.168.1.1
MASQUERADE  all  --  192.168.1.0/24       anywhere
Sur le client connecté au VPN :
C:\Documents and Settings\Administrateur>ping 192.168.1.1
Envoi d'une requête 'ping' sur 192.168.1.1 avec 32 octets de données :
Réponse de 192.168.1.1 : octets=32 temps=56 ms TTL=64
C:\Documents and Settings\Administrateur>ping google.fr
Envoi d'une requête 'ping' sur google.fr [209.85.147.103] avec 32 octe
ées :
Réponse de 192.168.1.11 : Impossible de joindre l'hôte de destination.
Carte Ethernet Connexion réseau sans fil:
        Suffixe DNS propre à la connexion :
        Description . . . . . . . . . . . : Carte Mini de réseau local sans fil
1397 de Dell
        Adresse physique . . . . . . . . .: x
        DHCP activé. . . . . . . . . . . : Oui
        Configuration automatique activée . . . . : Oui
        Adresse IP. . . . . . . . . . . . : 192.168.0.11
        Masque de sous-réseau . . . . . . : 255.255.255.0
        Passerelle par défaut . . . . . . : 192.168.0.254
        Serveur DHCP. . . . . . . . . . . : 192.168.0.254
        Serveurs DNS . . . . . . . . . .  : 212.27.40.240
                                            212.27.40.241
        Bail obtenu . . . . . . . . . . . : vendredi 10 juin 2011 05:25:39
        Bail expirant . . . . . . . . . . : lundi 20 juin 2011 05:25:39
Carte Ethernet Connexion au réseau local 2:
        Description . . . . . . . . . . . : TAP-Win32 Adapter V8
        Adresse IP. . . . . . . . . . . . : 192.168.1.220
        Passerelle par défaut . . . . . . : 192.168.1.11
        Serveur DHCP. . . . . . . . . . . : 192.168.1.0
        Serveurs DNS . . . . . . . . . .  : 192.168.1.1
        Bail obtenu . . . . . . . . . . . : vendredi 10 juin 2011 09:43:53
        Bail expirant . . . . . . . . . . : samedi 9 juin 2012 09:43:53
C:\Documents and Settings\Administrateur>route print
Liste d'Interfaces
0x1 ........................... MS TCP Loopback interface
0x2 ...x ...... Realtek PCIe GBE Family Controller - Miniport d'
ordonnancement de paquets
0x3 ...x ...... Carte Mini de rÚseau local sans fil 1397 de Dell
 - Miniport d'ordonnancement de paquets
0x20005 ...x...... TAP-Win32 Adapter V8 - Miniport d'ordonnance
ment de paquets
Itinéraires actifs :
Destination réseau    Masque réseau  Adr. passerelle   Adr. interface Métrique
          0.0.0.0          0.0.0.0    192.168.0.254    192.168.0.11       25
          0.0.0.0        128.0.0.0     192.168.1.11   192.168.1.220       1
     XXX.XXX.XXX.XXX  255.255.255.255    192.168.0.254    192.168.0.11       1
        127.0.0.0        255.0.0.0        127.0.0.1       127.0.0.1       1
        128.0.0.0        128.0.0.0     192.168.1.11   192.168.1.220       1
      192.168.0.0    255.255.255.0     192.168.0.11    192.168.0.11       25
     192.168.0.11  255.255.255.255        127.0.0.1       127.0.0.1       25
    192.168.0.255  255.255.255.255     192.168.0.11    192.168.0.11       25
      192.168.1.0    255.255.255.0    192.168.1.220   192.168.1.220       30
      192.168.1.0    255.255.255.0      192.168.1.1   192.168.1.220       1
    192.168.1.220  255.255.255.255        127.0.0.1       127.0.0.1       30
    192.168.1.255  255.255.255.255    192.168.1.220   192.168.1.220       30
        224.0.0.0        240.0.0.0     192.168.0.11    192.168.0.11       25
        224.0.0.0        240.0.0.0    192.168.1.220   192.168.1.220       30
  255.255.255.255  255.255.255.255     192.168.0.11               2       1
  255.255.255.255  255.255.255.255     192.168.0.11    192.168.0.11       1
  255.255.255.255  255.255.255.255    192.168.1.220   192.168.1.220       1
Passerelle par défaut :      192.168.1.11
Itinéraires persistants :
  Aucun
Je vois toujours pas ce qui cloche ! Je pense que c'est iptables.
Vous pouvez m'aider s'il vous plait.
Message édité par boobax le 10-06-2011 à 09:57:56
  Installation
[Iptables] Routage de l'IP Wan vers une autre IP Internetmonter une solution libre de VPN : openvpn ou autre ?
Démarrer PC sans OS (internet)mediatomb pas accessible au démarrage
OpenVpn sur HP-UX, possible ?Ipcop: pas d'accès à internet
Installer the gimp sans internetProbleme de firewall et serveur openvpn
[Résolu] Détecter une nouvelle adresse Mac sur un réseau LAN
Plus de sujets relatifs à : OpenVPN: Lan accessible mais Internet pas accessible
Copyright © 1997-2016 Hardware.fr SARL (Signaler un contenu illicite) / Groupe LDLC / Shop HFR
