GUG | j'ai du via, j'ai essayé avec uhci et echi. Ca ne peut etre ohci
Par contre truc con je vois pas de usb la dedans
euh peut etre je n'ai pas devfs ni son remplaceant, je tourne sur un 2.6.1-mm5, ni hotplug ...
Code :
- WKS02:~# lspci -v
- 00:00.0 Host bridge: VIA Technologies, Inc. VT8363/8365 [KT133/KM133] (rev 03)
- Subsystem: ABIT Computer Corp. KT7/KT7-RAID/KT7A/KT7A-RAID Mainboard
- Flags: bus master, medium devsel, latency 0
- Memory at d8000000 (32-bit, prefetchable) [size=64M]
- Capabilities: [a0] AGP version 2.0
- Capabilities: [c0] Power Management version 2
- 00:01.0 PCI bridge: VIA Technologies, Inc. VT8363/8365 [KT133/KM133 AGP] (prog-if 00 [Normal decode])
- Flags: bus master, 66Mhz, medium devsel, latency 0
- Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
- Memory behind bridge: dc000000-ddffffff
- Prefetchable memory behind bridge: d0000000-d7ffffff
- 00:07.0 ISA bridge: VIA Technologies, Inc. VT82C686 [Apollo Super South] (rev 40)
- Subsystem: VIA Technologies, Inc. VT82C686/A PCI to ISA Bridge
- Flags: bus master, stepping, medium devsel, latency 0
- 00:07.1 IDE interface: VIA Technologies, Inc. VT82C586A/B/VT82C686/A/B/VT8233/A/C/VT8235 PIPC Bus Master IDE (rev 06) (prog-if 8a [Master SecP PriP])
- Flags: bus master, medium devsel, latency 32
- I/O ports at d000 [size=16]
- 00:07.4 Host bridge: VIA Technologies, Inc. VT82C686 [Apollo Super ACPI] (rev 40)
- Flags: medium devsel, IRQ 9
- Capabilities: [68] Power Management version 2
- 00:09.0 Network controller: Texas Instruments ACX 100 22Mbps Wireless Interface
- Subsystem: D-Link System Inc: Unknown device 3b01
- Flags: bus master, medium devsel, latency 32, IRQ 10
- I/O ports at dc00 [size=32]
- Memory at df011000 (32-bit, non-prefetchable) [size=4K]
- Memory at df000000 (32-bit, non-prefetchable) [size=64K]
- Capabilities: [40] Power Management version 2
- 00:0f.0 Ethernet controller: Lite-On Communications Inc LNE100TX (rev 20)
- Subsystem: Netgear FA310TX
- Flags: bus master, medium devsel, latency 32, IRQ 11
- I/O ports at e000 [size=256]
- Memory at df010000 (32-bit, non-prefetchable) [size=256]
- Expansion ROM at <unassigned> [disabled] [size=256K]
- 01:00.0 VGA compatible controller: nVidia Corporation NV11DDR [GeForce2 MX 100 DDR/200 DDR] (rev b2) (prog-if 00 [VGA])
- Subsystem: Micro-Star International Co., Ltd.: Unknown device 8590
- Flags: bus master, 66Mhz, medium devsel, latency 248, IRQ 5
- Memory at dc000000 (32-bit, non-prefetchable) [size=16M]
- Memory at d0000000 (32-bit, prefetchable) [size=128M]
- Expansion ROM at <unassigned> [disabled] [size=64K]
- Capabilities: [60] Power Management version 2
- Capabilities: [44] AGP version 2.0
- WKS02:~#
Message édité par GUG le 29-01-2004 à 15:38:19
