1958 connectés
  Linux et OS Alternatifs
  Comment interpréter les données SMART de mon HDD ?
n°1305269
Swiss_Knig​ht
600 MeV since 1957.
Posté le 22-02-2012 à 01:48:24  profilanswer
j'ai ça :
=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  3 Spin_Up_Time            0x0027   221   219   063    Pre-fail  Always       -       12222
  4 Start_Stop_Count        0x0032   252   252   000    Old_age   Always       -       2893
  5 Reallocated_Sector_Ct   0x0033   189   189   063    Pre-fail  Always       -       326
  6 Read_Channel_Margin     0x0001   253   253   100    Pre-fail  Offline      -       0
  7 Seek_Error_Rate         0x000a   253   251   000    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0027   251   240   187    Pre-fail  Always       -       63573
  9 Power_On_Minutes        0x0032   226   226   000    Old_age   Always       -       831h+34m
 10 Spin_Retry_Count        0x002b   253   248   157    Pre-fail  Always       -       0
 11 Calibration_Retry_Count 0x002b   253   252   223    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   245   245   000    Old_age   Always       -       3174
192 Power-Off_Retract_Count 0x0032   252   252   000    Old_age   Always       -       1941
193 Load_Cycle_Count        0x0032   252   252   000    Old_age   Always       -       4696
194 Temperature_Celsius     0x0032   253   253   000    Old_age   Always       -       47
195 Hardware_ECC_Recovered  0x000a   253   252   000    Old_age   Always       -       160
196 Reallocated_Event_Count 0x0008   253   253   000    Old_age   Offline      -       0
197 Current_Pending_Sector  0x0008   253   253   000    Old_age   Offline      -       0
198 Offline_Uncorrectable   0x0008   253   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0008   199   199   000    Old_age   Offline      -       0
200 Multi_Zone_Error_Rate   0x000a   253   252   000    Old_age   Always       -       0
201 Soft_Read_Error_Rate    0x000a   253   252   000    Old_age   Always       -       0
202 TA_Increase_Count       0x000a   253   252   000    Old_age   Always       -       0
203 Run_Out_Cancel          0x000b   253   252   180    Pre-fail  Always       -       0
204 Shock_Count_Write_Opern 0x000a   253   252   000    Old_age   Always       -       0
205 Shock_Rate_Write_Opern  0x000a   253   252   000    Old_age   Always       -       0
207 Spin_High_Current       0x002a   253   248   000    Old_age   Always       -       0
208 Spin_Buzz               0x002a   253   252   000    Old_age   Always       -       0
209 Offline_Seek_Performnce 0x0024   188   187   000    Old_age   Offline      -       0
 99 Unknown_Attribute       0x0004   253   253   000    Old_age   Offline      -       0
100 Unknown_Attribute       0x0004   253   253   000    Old_age   Offline      -       0
101 Unknown_Attribute       0x0004   253   253   000    Old_age   Offline      -       0
Mais je ne sais pas trop à quoi correspondent ces chiffres... ni ce que veulent dire "Old_age" et "Pre-fail"...
On dirait que mon disque va mourir avec tout ça.  :sweat:
Hergestellt in der Schweiz.
n°1305272
deK
watching for beerz on the wing
Posté le 22-02-2012 à 05:41:18  profilanswer
Le plus important ici est le Reallocated_Sector_Ct, il est à 326, ce qui est :
-effectivement un peu élevé, signe que des secteurs sont réalloués
-bénin si cette valeur a augmenté à un moment mais ne bouge plus du tout (une zone du disque était pas top, elle a été blacklistée, plus de problème)
Par contre si tu vois que la valeur ne cesse d'augmenter, alarme-toi.
Sinon avec un
smartctl -a /dev/sdX
Tu peux voir si des erreurs au cours du fonctionnement se sont produites.
Regarde aussi ton dmesg si tu as un doute sur le bon fonctionnement du HDD, des erreurs d'I/O y seraient loggées.
Feed HA/V
Forcer l'arrêt d'un HDD et le rallumer sur demande.Changer permissions partition données
Données perso : accès multi OS. Vos solutions merciAcces données de l'hote via linux sous HyperV
Temps estimé pour récupérer des donnéesComment utiliser 2 HDD ?
Recupération de données partition linuxHDD Externe qui ne se monte qu'en lecture seule
[Résolu] Bash - Exporter sans interpréter.Perte de données: Lien du fichier brisé
Plus de sujets relatifs à : Comment interpréter les données SMART de mon HDD ?
