2333 connectés
  Linux et OS Alternatifs
  Codes et scripts
  Script bash et RRDTOOL -> Probleme
n°512341
sharlaan
Posté le 29-06-2004 à 16:57:26  profilanswer
Voila ma fonction :
Code :
  1. memoire ()
  2. {
  3.         rrdtool graph $GRAPHS/$1 -s $2 -e $3 -a GIF \
  4.         -t "Utilisation de la mémoire pour le serveur $4" \
  5.         -l 0 -r \
  6.         DEF:utilise=/var/db/rrdtool/memoire.rrd:utilise:AVERAGE CDEF:utilise_mem=utilise,4096,* AREA:utilise_mem#ff8080:"Utilisé$        DEF:active=/var/db/rrdtool/memoire.rrd:active:AVERAGE CDEF:active_mem=active,4096,* STACK:active_mem#ff80ff:"Active" \
  7.         DEF:inactive=/var/db/rrdtool/memoire.rrd:inactive:AVERAGE CDEF:inactive_mem=inactive,4096,* STACK:inactive_mem#8080ff:"I$        DEF:cache=/var/db/rrdtool/memoire.rrd:cache:AVERAGE CDEF:cache_mem=cache,4096,* STACK:cache_mem#808080:"Cache" \
  8.         DEF:libre=/var/db/rrdtool/memoire.rrd:libre:AVERAGE CDEF:libre_mem=libre,4096,* STACK:libre_mem#80ff80:"Libre" \
  9.         DEF:utilise2=/var/db/rrdtool/memoire.rrd:utilise:AVERAGE CDEF:utilise_mem2=utilise2,4096,* LINE1:utilise_mem2#ff0000 \
  10.         DEF:active2=/var/db/rrdtool/memoire.rrd:active:AVERAGE CDEF:active_mem2=active2,4096,* STACK:active_mem2#ff00ff \
  11.         DEF:inactive2=/var/db/rrdtool/memoire.rrd:inactive:AVERAGE CDEF:inactive_mem2=inactive2,4096,* STACK:inactive_mem2#0000f$        DEF:cache2=/var/db/rrdtool/memoire.rrd:cache:AVERAGE CDEF:cache_mem2=cache2,4096,* STACK:cache_mem2#000000 \
  12.         DEF:libre2=/var/db/rrdtool/memoire.rrd:libre:AVERAGE CDEF:libre_mem2=libre2,4096,* STACK:libre_mem2#00ff00 \
  13.         COMMENT:"\n" \
  14.         COMMENT:"$5\n"
  15. }
Et quand j'execute le script, toutes les autres fonctions marchent, sauf celle là.
Voila le message d'erreur :
Code :
  1. ERROR: can't parse '    '
  2. graphs.sh: DEF:utilise2=/var/db/rrdtool/memoire.rrd:utilise:AVERAGE: not found
  3. ERROR: can't parse '    '
  4. graphs.sh: DEF:utilise2=/var/db/rrdtool/memoire.rrd:utilise:AVERAGE: not found
  5. ERROR: can't parse '    '
  6. graphs.sh: DEF:utilise2=/var/db/rrdtool/memoire.rrd:utilise:AVERAGE: not found
  7. ERROR: can't parse '    '
  8. graphs.sh: DEF:utilise2=/var/db/rrdtool/memoire.rrd:utilise:AVERAGE: not found
Une idée ?
n°512347
Sly Angel
Architecte / Développeur principal
Posté le 29-06-2004 à 17:03:03  profilanswer
Hum à priori un problème de \ non mis en fin d'une ligne ou alors il y a un caractère espace/tab encore derrière qui ne devrait pas être là ?
n°512349
sharlaan
Posté le 29-06-2004 à 17:06:28  profilanswer
exact, un espace baladeur.
  Codes et scripts
[Bash] Probleme pour déclarer une fonctionPetit probléme d'installation de Linux 10.0
Probleme de fermeture d'un logiciel[Webmin - Debian] Problème certificat Webmin
[debian] problème de démarrageProblème d'affichage de noms sur Rhythmbox 0.8.5
problème d'utilisation de transcode (je l'ai compilé sous debian)Problème avec Overnet sous linux....
probleme d'affichage avec un powerbook sous linux
Plus de sujets relatifs à : Script bash et RRDTOOL -> Probleme
