1638 connectés
 Page :   1  2  3  4  5  6  7  8  9  10  11  12  13  14  15  16  17  18  19  20
[Topic Unique] WANSVIEW NC-536M/W HD WIFI IP Camera PT + IR-Cut + SD
n°690633
sapi100
Posté le 25-04-2012 à 16:36:12  profilanswer
I've got my new NCH-536W and 2pc NCH-532MW camera. (with 4mm and 8mm lens)
536W has V1.4.0.1.4 firmware.
Where can I find newer firmware?
n°690639
paillassou
Posté le 25-04-2012 à 16:42:19  profilanswer
you can take a look here
http://www.amazon.com/review/R189F [...] FTSW1ZGX1G
be careful
when i have upgraded my NCH536MW v1.4.0.1.4 => to => v1.4.0.1.5
i have lost all my parameters and
i have lost the DDNS manufacturer parameters id and password (xxxx.nvswr.com)
http://www.netge.org/index.php/dow [...] cdownloads
http://www.netge.org/attachments/a [...] 6mP2En.zip
it's not a pb for me because i don't use it
I am not responsible if something goes wrong when flashing
Message édité par paillassou le 25-04-2012 à 16:53:56
n°690671
sapi100
Posté le 26-04-2012 à 00:57:18  profilanswer
Thanks for info.
Maybe the best if I wait to update.
n°690678
paillassou
Posté le 26-04-2012 à 07:21:12  profilanswer
before update:
do a complete "config-backup", thru the system control panel webui "INITIALIZE".
and
you should send that url command to the camera too:
http:///IPaddress:port/cgi-bin/hi3 [...] =getseddns
in order to backup the SmartEye Domain Name (DDNS) of your own camera
id = ?
login = ?
password = ?
=> you should backup the entire line like this:
var seenable="on"; var sesrvtype="www.nwsvr.com"; var seuser="005bhte"; var sepasswd="67438528"; var sehost="005bhte";
Message édité par paillassou le 26-04-2012 à 07:21:25
n°690733
sapi100
Posté le 26-04-2012 à 14:48:28  profilanswer
My seller send me new firmware two 536W.
First
config-backup
Secund
Backup DDNS info
Can you give me all url command I need to make backup ?
n°690746
paillassou
Posté le 26-04-2012 à 15:30:39  profilanswer
i have send you a private message :)
n°690747
paillassou
Posté le 26-04-2012 à 15:32:31  profilanswer
for backup your SEDDNS infos
you should send that url command to the camera :
htttp://local-ip-address:port/cgi-bin/hi3510/param.cgi?cmd=getseddns
remove 1 "t" in http://
local-ip-address:port => according to your own local ip address and port
and you save the result line
i don't know how restore it...
Message édité par paillassou le 26-04-2012 à 15:35:36
n°690749
paillassou
Posté le 26-04-2012 à 15:36:57  profilanswer
config-backup
click on:
backup setting data
https://lh4.googleusercontent.com/-s9ZbJBhFw98/T06MSbMsSBI/AAAAAAAABq4/C0l3hfulbPM/w500-h282-k/ScreenShot019.jpg
https://lh4.googleusercontent.com/- [...] hot019.jpg
and after the upgrade procedure
you have to restore the config-backup
Message édité par paillassou le 26-04-2012 à 15:41:46
n°690754
paillassou
Posté le 26-04-2012 à 16:14:38  profilanswer
here is a simple html script to display the video on a browser
it uses the second mjpeg stream 640x360 ;)
i have used and modded the "mobile.html" original html page from the webui
WARNING => ip address, login & password are present into the source code
Code :
  1. <html>
  2. <head>
  3. <title>NCH536MW</title>
  4. <meta content="text/html; charset=utf-8" http-equiv="content-type">
  5. <script language="javascript">
  6. <!--
  7. var img = new Image();
  8. var imgObj;
  9. function preload()
  10. {
  11. img.src='http://login:password@ipaddress:port/tmpfs/snap.jpg?'+new Date;
  12. }
  13. function changesrc()
  14. {
  15. img1.src=img.src;
  16. preload();
  17. setTimeout(changesrc,3500);
  18. }
  19. function update()
  20. {
  21. imgObj = document.getElementById('img1');
  22. imgObj.src = img.src;
  23. img.src = "http://login:password@ipaddress:port/tmpfs/snap.jpg?" + (new Date()).getTime();
  24. }
  25. function takeError()
  26. {
  27. img.src = "http://login:password@ipaddress:port/tmpfs/snap.jpg?" + (new Date()).getTime();
  28. }
  29. function startonload()
  30. {
  31. img.src = "http://login:password@ipaddress:port/tmpfs/snap.jpg?" + (new Date()).getTime();
  32. img.onerror=takeError;
  33. img.onload=update;
  34. }
  35. function load()
  36. {
  37. if (navigator.appName.indexOf("Microsoft IE Mobile" ) != -1)
  38. {
  39.  preload();
  40.  changesrc();
  41.  return;
  42. }
  43. startonload();
  44. }
  45. function ptzUpSubmit()
  46. {
  47. form1.action="http://login:password@ipaddress:port/cgi-bin/hi3510/ytup.cgi";
  48. form1.submit();
  49. }
  50. function ptzDownSubmit()
  51. {
  52. form1.action="http://login:password@ipaddress:port/cgi-bin/hi3510/ytdown.cgi";
  53. form1.submit();
  54. }
  55. function ptzLeftSubmit()
  56. {
  57. form1.action="http://login:password@ipaddress:port/cgi-bin/hi3510/ytleft.cgi";
  58. form1.submit();
  59. }
  60. function ptzRightSubmit()
  61. {
  62. form1.action="http://login:password@ipaddress:port/cgi-bin/hi3510/ytright.cgi";
  63. form1.submit();
  64. }
  65. function backtomain()
  66. {
  67. window.location.href='/web/mobileback.html';
  68. }
  69. //-->
  70. </script>
  71. </head>
  72. <body onload="load()">
  73. <form name="form1" method="get" target="test">
  74. </form>
  75. <p><img id="img1" border="0" src="http://login:password@ipaddress:port/tmpfs/snap.jpg"></p>
  76. <p>
  77. <input type="button" value="&#8593;" name="B3" onclick="ptzUpSubmit()">
  78. <input type="button" value="&#8595;" name="B2" onclick="ptzDownSubmit()">
  79. <input type="button" value="&#8592;" name="B1" onclick="ptzLeftSubmit()">
  80. <input type="button" value="&#8594;" name="B0" onclick="ptzRightSubmit()">
  81. <input type="button" value="Refresh" name="B4" onclick="location.reload()">
  82. </p>
  83. <iframe name="test" style="none" width="0" height="0"></iframe>
  84. </body>
  85. </html>
Message édité par paillassou le 02-05-2012 à 11:03:05
n°690867
sapi100
Posté le 27-04-2012 à 11:59:24  profilanswer
With HParams_en software can I be sure that the firmware update be ok and I do not lose the DDNS feature (536W)
n°690883
paillassou
Posté le 27-04-2012 à 12:39:13  profilanswer
Ask to Sabrina to be sure:
here is my question to WANSVIEW:
hello,
NCH536MW
i have successuly upgrade the firmware to the version 1.4.0.1.5
but
the firmware upgrade procedure has removed all the
manufacturer Smart Eye DDNS (SEDDNS)
parameters id, login, password , host...
it's not DynDNS
it's not No-IP
i remember it was something like that
005bhte.nwsvr.com
FYI => id (login) is written on a stamp (bottom of my cam)
005bhte
but:
HOW TO RETRIEVE MY personal PASSWORD for SEDDNS ?
and how to restore that SEDDNS parameters ?
here is the Sabrina's answer (WANSVIEW) by mail
Dear Paillassou,
Yes, I have told you that , after update for the firmware, some parameters will lose. So you need to give the wan ip address for us to re-write it for you.
Thanks and best regards,
Yours sincerely,
wansview---Sabrina
Message édité par paillassou le 27-04-2012 à 12:41:35
n°690884
paillassou
Posté le 27-04-2012 à 12:42:46  profilanswer
here is my new question to WANSVIEW - Sabrina
i'm waiting for the answer...
it's very strange that WANSVIEW wants know my WAN IP ... why... ?
OK...  But my WAN ip is dynamic !!!
Each TIME i restart my router box, my WAN ip change... and
i have to write to you, each time ???
The rule of a Dynamic service (ie SEDDNS) is to do that job:
automaticaly update the WAN IP according to my own
id = 005bhte (with the password that i'm don't know... ), isn't it ?
005bhte.nwsvr.com <=> WAN ip
How could you modify my own internal SEDDNS parameters
(in my own cam) with my WAN IP ?
How do you proceed?
Thanks a lot.
Best regards
Message édité par paillassou le 27-04-2012 à 12:45:53
n°690888
sapi100
Posté le 27-04-2012 à 13:28:27  profilanswer
Interesting development.
But what HParams_en software do?
Maybe I misunderstood the software.
I think the "Get" info and "Set" this but I will not try now.
n°690890
paillassou
Posté le 27-04-2012 à 13:31:47  profilanswer
i understand...
in fact, in think that if you have correctly backup
the informations (GET) i explain you, you should restore (SET)
the SEDDNS parameters with HParams_en ... (i hope)
MANY infos could be found here in that package
"Instructions for the Update of H serials.doc" is more complete
http://netge.org/attachments/artic [...] 6mP2En.zip
it's incredible that WANSVIEW doesn't want to explain more to the customers...
Message édité par paillassou le 27-04-2012 à 13:39:11
n°690897
sapi100
Posté le 27-04-2012 à 14:05:03  profilanswer
I read it yesterday, but I was not sure.
I will not ruin my camera
n°690900
sapi100
Posté le 27-04-2012 à 14:13:41  profilanswer
What changed, what is new in the new firmware? (536W)
Do I upgrade?
Necessity to upgrade?
n°690901
paillassou
Posté le 27-04-2012 à 14:18:56  profilanswer
Ask to Sabrina (WANSVIEW) to be sure :(
she doesn't want to answer me...
Message édité par paillassou le 27-04-2012 à 14:19:26
n°690903
paillassou
Posté le 27-04-2012 à 14:20:21  profilanswer
i can say
i have successuly upgrade the firmware to v1.4.0.4 to the v1.4.0.1.5
but
because anyone says me, anyone prevent me BEFORE
(ie WANSVIEW), i have to do a "specific" backup SEDDNS with a specific tools HParams_en !!!
i was a beta-tester for you :lol:
Message édité par paillassou le 27-04-2012 à 14:25:29
n°690911
paillassou
Posté le 27-04-2012 à 15:27:50  profilanswer
VISUALISATION SUR MOBILE 3G
Compatible ipcamera to display video of WANSVIEW NCH536MW
app "IP CAM VIEWER" on ANDROID
DERICAM H501
WANSVIEW NC530
EASYN HS-691
EasySE H2
ASTAK MOLE
FOSCAM FI8602  :D
FOSCAM FI8620  :D
Message édité par paillassou le 27-04-2012 à 15:29:17
n°691226
cyrnos
Posté le 01-05-2012 à 01:25:12  profilanswer
Hi,
The Dericam H501W and Wansview NCH-536MW are both identical from an hardware standpoint and it looks like that the H501W software (as seen on youtube) might offers more control than the Wansview but I'm not sure if this is the case.
Question is : which one performs better and why?
Message édité par cyrnos le 01-05-2012 à 01:26:51
n°691231
sapi100
Posté le 01-05-2012 à 07:34:04  profilanswer
The same controls from both software only software design different.
n°691316
cyrnos
Posté le 02-05-2012 à 02:00:48  profilanswer
Thanks Sapi100 so there is no specific features distinguishing one from the other and very little difference in price. I guess it boils down to the support but even that might not be a problem as one might be able to flash a unit with both manufacturers firmware down the road.
Message édité par cyrnos le 02-05-2012 à 02:01:26
n°691326
paillassou
Posté le 02-05-2012 à 10:43:29  profilanswer
@sapi100
You know that when i have upgrade v1.4.0.1.4 to v1.4.0.1.5
i've lost my SEDDNS (SmartEye manufacturer) parameters
(ie. xxxxxx.nwsvr.com)
An engineer from WANSVIEW china (sznv.net)
has restore my SEDDNS from remote
with the specific tools "HParams_en.exe"
so, if you have correctly BACKUP all your SEDDNS (SmartEye manufacturer) parameters
you will be able to restore them with the specific tools "HParams_en.exe"
Message édité par paillassou le 02-05-2012 à 10:58:23
n°691339
sapi100
Posté le 02-05-2012 à 12:10:54  profilanswer
I have updated my NCH-536W camera with new firmware v1.4.0.1.5 using "Hparams_en.exe" and everything works like before.
n°691340
snice
Posté le 02-05-2012 à 12:20:36  profilanswer
Salut Pallassou
je viens de lire l'entièreté du thread, je te dis bravo et merci pour tes investigations!!!!
J'ai commandé il a de cela quelques mois, une caméra IP sur le site DealExtreme. Le sku est 81976, bizarrement la page de la camera n'est plus accessible depuis quelques jours/semaines. Elle a été remplacé (?) par le 102259 (http://www.dealextreme.com/p/cmos-wireless-network-security-surveillance-ip-camera-w-10-led-ir-night-vision-102259?item=2). En tout cas elle correspond comme 2 goutes d'eau à celle que j'ai acheté et celle que tu décris dans ce thread... J'ai vu sur leur forum quelqu'un demander la différence mais pas de vrai réponse...
Ma question était de savoir si ma caméra était une WANSVIEW car j'aimerai faire une mise a jour... Je sais que c'est la séries H...
Merci d'avance pour ton éclaircissement
/Snice
n°691345
paillassou
Posté le 02-05-2012 à 12:57:24  profilanswer
Bonjour et merci pour les compliments ;)
alors, c'est simple:
1) donne moi ta version de firmware
2) mets des copies d'écran de l'interface web que possède ta cam
bye ;)
Message édité par paillassou le 02-05-2012 à 13:14:19
n°691365
snice
Posté le 02-05-2012 à 14:57:55  profilanswer
Ok je mettrai ca ce soir car je suis au bureau pour l'instant :-)
Message édité par snice le 02-05-2012 à 14:58:18
n°691415
cyrnos
Posté le 02-05-2012 à 20:30:38  profilanswer
@ Paillassou,
Je te remercie de meme pour c'est excellent reference que tu as creer pour cette camera. J'hesite entre la commender de http://cgi.ebay.fr/ws/eBayISAPI.dl [...] ink:top:fr en croisant les doigts que je ne recoive pas une copy inferieure ou commender une Dericam H501W directement a travers de leur revendeur our tenter DEx. Le plus inquietant et le support (ou manque de) que ces deux companies montre, si seulement il realizer que t'as thread leur fait plus de benefit que leur 2 sites ensemble! Le prix est pratiquement similaire pour toute ces cameras ce qui laisse le support pour faire la difference, est ce que c'est vraiment la seule chose?
n°691426
paillassou
Posté le 02-05-2012 à 21:25:48  profilanswer
malheureusement, moi j'ai pas pu avoir d'aide avant de choisir la mienne... et je me suis lancé ;)
tout ce que je peux dire, d'après mes prospections, c'est qu' "apparemment"
la dericam H501w et la NCH536MW sont EXACTEMENT le même produit.
le firmware système est exactement le même
le firmware WEBUI est visiblement différent.
donc... moi ce que je constate c'est que la dernière version firmware "système" est bien celle de WANSVIEW (v1.4.0.1.5)
donc, le revendeur qui a la primeur du produit, c'est WANSVIEW.
OUI, certes, le support technique WANSVIEW est faiblard..
autant dire que c'est pas à la hauteur de FOSCAM...
pour résumer:
Les 3 choses qui portent préjudice à cette ip caméra WANSVIEW ce sont:
-bug wifi pour les clefs WPA2 > à 32 caractères => contournable par une ligne de commande ;)
-manque de possibilité sous-répertoire FTP
-absence de prise en charge par SYNOLOGY => pour beaucoup d'autres caméras c'est malheureusement la même chose... même par ex. FOSCAM FI8620
pour l'achat
http://goo.gl/R6GxW
c'est exactement chez ce vendeur que j'ai acheté la mienne ;) c'est une WANSVIEW "genuine"
Il y a  bien le logo WANSVIEW estampillé dessus.
=> donc c'est bien un gage de confiance concernant le modèle qui n'est pas pas un clone ;)
voilà, faut choisir ;)
Message édité par paillassou le 02-05-2012 à 21:36:21
n°691444
cyrnos
Posté le 03-05-2012 à 01:47:33  profilanswer
Merci beaucoup pour t'as reponse Paillassou, comme tu l'as fait, il vas falloir que je me jette a l'eau :-) Si je viens a passer une commande a travers jennyzhang0807, si c'est ok avec toi je te donnerais credit pour la vente.
Aussi, J'ai recu un commentaire a propos de cette camera qui disaient que "il faut une carte sd pour que l'upload de vidéo par ftp fonctionne" j'espere que ca peut aider.
n°691451
paillassou
Posté le 03-05-2012 à 07:24:28  profilanswer
OUI Merci pour l'info => mais je l'avais déjà indiqué depuis le début en 1ère page
FTP function
You can upload pictures and videos* into the root directory of an FTP server.
To save videos* (asf file), you must have "Save video on SD card" enabled in the software.
https://lh3.googleusercontent.com/- [...] hot010.jpg
i've tried that function and it works fine.
ASF files are correctly saved on the root of my FTP server.
Message édité par paillassou le 03-05-2012 à 07:25:20
n°691487
sapi100
Posté le 03-05-2012 à 13:25:07  profilanswer
Can you use any SD card or something special, because my 1GB SD card does not work.
It is formatted FAT32.
n°691489
paillassou
Posté le 03-05-2012 à 13:45:00  profilanswer
FYI:
i use a simply 2GB µsdcard into an adapter/converter SDcard.
FAT32 too ;)
for test purpose only...
Message édité par paillassou le 03-05-2012 à 13:45:19
n°691520
snice
Posté le 03-05-2012 à 20:35:31  profilanswer
bye ;)
Salut Paillassou
Je n'ai pas pu t'envoyer ca hier soir car je n'arrivais plus a accéder à la caméra...
Voici le numéro de version: V1.4.0.1.3
http://imageshack.us/photo/my-images/861/photo4t.png/
http://imageshack.us/photo/my-images/207/photo3g.png/
http://imageshack.us/photo/my-images/189/photo2t.png/
http://imageshack.us/photo/my-images/403/photo1n.png/
n°691525
paillassou
Posté le 03-05-2012 à 21:25:02  profilanswer
ON VOIT PAS LES IMAGES...
bon... voilà les infos que je vais te donner qui, je l'espère,
t'aideront à choisir si tu te jetes à l'eau ou non:
1) Quand j'ai acheté la mienne, elle avait le firmware v1.4.0.1.4
c'est une WANSVIEW genuine originale (avec logo WANSVIEW)
2) je l'ai mise à jour avec le firmware WANSVIEW version v1.4.0.1.5
3) certains, sur d'autres topic, possèdent également la même version firmware que toi...
http://www.amazon.com/Wansview-NCH [...] ewpoints=1
donc, sans trop se tromper et vu l'incrément des versions successives
v1.4.0.1.3
v1.4.0.1.4
v1.4.0.1.5
on peut se dire que c'est OK pour flasher la tienne...
si tu te lances...
AVANT toute mise à jour je te conseille vivement de lancer
http://dl.free.fr/d3J5QaO01 (à renommer en .exe)
afin de récupérer les infos très importantes contenues dans TON firmware
comme les paramètres SEDDNS (SmartEye DDNS)
lance HParams_en.exe
(il n'y a pas de virus c'est un soft dédié au caméras IP H.264)
=> ne clique surtout pas sur "SET"
sur le côté gauche indique les infos pour accéder à ta cam
clique sur "GET" et dis moi si tu récupères des choses
Message édité par paillassou le 03-05-2012 à 21:27:46
n°691527
snice
Posté le 03-05-2012 à 21:47:13  profilanswer
Désolé pour les images je ne sais pas pourquoi il ne les affiches pas mais voici les liens
Je vais tenter le coup, je te tiens au courant, en espérant ne pas la griller lool :-)
Message édité par snice le 03-05-2012 à 21:47:37
n°691528
snice
Posté le 03-05-2012 à 21:51:43  profilanswer
je n'arrive pas a télécharger le fichier HParams_en.exe. Il me demande de taper les mots du captcha mais c'est vide quand je click sur nouveau challenge ou audio j'ai une erreur: input error...
n°691530
snice
Posté le 03-05-2012 à 22:24:37  profilanswer
Finalement je l'ai trouvé ailleurs avec le firmware 1.4.0.1.5. J'ai fais la mise a jour et ca c'est bien passé :-)
Dois faire un set avec les information que j'avais avant ou inutile (je n'utilise pas la fonction ddns du vendeur)?
n°691531
paillassou
Posté le 03-05-2012 à 22:28:37  profilanswer
OK...
mais bon, si tu n'as pas fait tes backup SEDDNS
HParams_en.exe, avant de flasher pour éviter de les perdre...
ce sera pas de ma faute...
n°691532
snice
Posté le 03-05-2012 à 22:29:40  profilanswer
Sisi j'ai fais le backup avec mes access ddns :-)
n°691533
paillassou
Posté le 03-05-2012 à 22:29:59  profilanswer
attention je ne te parle pas des DynDNS ou no-ip.org ou 3222.org...
je parle bien du dynamic DNS de WANSVIEW qui est implémenté dans chaque cam.
à savoir SEDDNS
xxxxxxx.nwsvr.com
ou xxxxxx est l'id de la caméra
Message édité par paillassou le 03-05-2012 à 22:33:55
Est ce que ça existe un adaptateur WIFI/USB pour disque dur USB ?camera ip Heden V5.5 PAS DE SON
Webcam IP/ DCS 5230/ récupération d'images (analogie autres webcams)Problème de connexion entre PC et Imprimante Wifi
Quel soft utiliser (java) pour afficher caméra IP ?AVIS SUR HEDEN - Caméra IP extérieure - CAMH04IPWE
Quel nas Choisir pour enregistrement cameraHD 5450 512MO et 27' ?
Plus de sujets relatifs à : [Topic Unique] WANSVIEW NC-536M/W HD WIFI IP Camera PT + IR-Cut + SD
