2473 connectés
  Hardware - Périphériques
  Ecran
  Viewsonic VX2450wm-LED
n°636936
Juicy
Oui je suis un con.. et?
Posté le 07-02-2011 à 19:56:25  profilanswer
Bonjour
http://www.viewsonic.com/products/ [...] 0wmled.htm
Je cherche des infos sur le Viewsonic VX2450wm-LED.
il semble avoir assez bonne presse/avis : http://www.testfreaks.fr/moniteurs/viewsonic-vx2450wm/
Rétroéclairage LED, faible consommation, design sympa, 5ms et pas cher du tout.
Quelqu'un aurait plus d'infos?
 Type  24" (23.6" viewable) Wide Color TFT Active Matrix LCD
 Display Area  20.5" horizontal x 11.5" vertical; 23.6" diagonal
 Resolution  1920x1080
 Contrast Ratio  1000:1 (typ); 20,000,000:1 (dynamic)
 Viewing Angles  170º horizontal, 160º vertical @ contrast ratio > 10:1
 Response Time  5ms (typ)
 Light Source  Long life, 30,000 hrs. (typ)
 Brightness  300 cd/m2 (typ)
 Panel Surface  Anti-glare, hard-coating (3H)
VIDEO INPUT
 Analog  RGB analog (75 ohms, 0.7/1.0 Vp-p)
 Digital  DVI-D (TMDS, 100 ohms)
 Frequency  Fh: 24~83kHz, Fv: 50~76Hz
 Sync  Separate Sync/Composite Sync/SOG
COMPATIBILITY
 PC  VGA up to 1920x1080 non-interlaced
 Mac®  Power Mac™ up to 1920x1080
CONNECTOR
 Analog  15-pin mini D-sub (VGA)
 Digital  DVI-D
 Power  3-pin plug (CEE22)
 Audio  3.5 mm audio in / 3.5 mm audio out
AUDIO
 Speakers  2x2.5-watt
POWER
 Voltage  AC 100–240V (universal), 50/60Hz
 Consumption  23W (typ)
ERGONOMICS
  Tilt: Down 5º, Up 20º
CONTROLS
 Basic  Power, 1, up, down, 2
 OSD  Auto Image Adjust, Contrast/Brightness, Input Select (D-SUB, DVI), Audio Adjust (Volume, mute), Color Adjust (sRGB, 9300K, 7500K, 6500K, 5000K, User Color [R, G, B]), Information, Manual Image Adjust (H/V Position, Horizontal Size, Fine Tune, Sharpness, Dynamic Contrast, Aspect Ratio, Display Mode, ECO Mode ), Setup Menu (Language, Resolution Notice, OSD Position, OSD Timeout, OSD Background, Auto Power Off, Sleep), Memory Recall
OPERATING CONDITIONS
 Temperature  32–104º F (0–40º C)
 Humidity  20–90% (non-condensing)
DIMENSIONS (WxHxD)
 Physical With Stand  22.3" x 17.4" x 8.4" (566.2mm x 443.2mm x 214.5mm)
 Physical Without Stand  22.3" x 14.5" x 2.0" (566.2mm x 369.5mm x 49.9mm)
 Packaging  25.6" x 20.4" x 5.2" (651mm x 518mm x 133mm)
WEIGHT
 Gross  13.7 lb. (6.2 kg)
 Net With Stand  9.9 lb. (4.5 kg)
 Net Without Stand  8.9 lb. (4.0 kg)
REGULATIONS
  BSMI, CCC, PSB, C-Tick, KC, e-standby, CE, Ergo, Gost-R/Hygienic, Ukraine, SASO, UL/cUL, FCC-B, ICES-B,TUV-S/UL-AR S Mark, NOM, WEEE, RoHS
WALL MOUNT
  VESA® 100mm x 100mm
POWER MANAGEMENT
  ENERGY STAR® standards
PACKAGE CONTENTS
  LCD Display, power cable, audio cable, VGA cable, Quick Start Guide, ViewSonic Wizard CD (User Guide and drivers)
WARRANTY
  Three-year limited warranty on parts, labor and backlight
Message édité par Juicy le 07-02-2011 à 19:57:16
Notre loi se résume en ces mots : faites ce que vous avez à faire. La satisfaction s'obtient en utilisant le pouvoir pour changer le monde. Les moyens justifient la fin. Seul l'echec est inacceptable.
  Ecran
IPS 23pouces : viewsonic VP2365wb ou Nec EA231WmiQuel rendu avec une HD5870 sur TV LED 37" ?
Quel ecran Viewsonic 22" pour remplacer le VX2255wmbEcran Viewsonic HDMI changement de mode AV > PC
[Aide]Avis sur Ecran ViewSonic V3D241wm-LEDProbleme LED samsung BX2331
LCD/Led 23/24 poucesChoix ecran PC LED 23/24 pouces
Ecran ordi TFT ou écran TV LED
Plus de sujets relatifs à : Viewsonic VX2450wm-LED
Hit-Parade
