4925 connectés
  [Topic unique] Rampage Extreme
 Page :   1  2  3  4  5  6  7  8  9  10  11  12
Page Précédente
n°6474576
noobzed
Where is Brian ? DTC !
Posté le 04-07-2008 à 00:38:18  profilanswer
La dernière carte mère ROG de chez Asus,
tout droit dérivée de la Pinot Noir, le fameux
proto de chez Asus, la voici en images:
http://images.bit-tech.net/news_images/2008/06/asus-rampage-extreme-niche-new-features/1b.jpg
http://images.bit-tech.net/news_images/2008/06/asus-rampage-extreme-niche-new-features/2b.jpg
http://images.bit-tech.net/news_images/2008/06/asus-rampage-extreme-niche-new-features/4b.jpg
Au menu:
http://img385.imageshack.us/img385/4272/sanstitre1sx3.jpg
X48, DDR3, FSB de dingue => http://www.nordichardware.com/news,7963.html
On the bottom we now have toggle, confirm and a select lever for some on-the-fly overclocking action, apparently even when in Windows and in-game. However reaching into your case while you frag isn’t the easiest thing, but it’s a cool idea that no one else has even remotely come up with yet.
Instead of a line of capacitors or Hi-C caps like MSI use, Asus is now using just one huge Fujitsu low profile 3V-1000uF “bling” capacitor above the memory, under the CPU socket on the back of the board and (we think) for the north bridge under its heatsink too.
The Fusion waterblock is now removable and rocket red in colour, and the PWM heatsink between CPU and rear I/O is heatpiped on its own and is super huge – it’s almost the height of my fist. Again, that’s removable too if you find a cooler incompatibility. The board features the usual EPU and 16-phase CPU power design and even DriveXpert (although we’re not sure why a mainstream solution features on a core enthusiast board), but no ExpressGate.
Message édité par noobzed le 22-07-2008 à 02:27:41
FEEDBACK HFR
n°6474577
noobzed
Posté le 04-07-2008 à 00:38:47  profilanswer
http://img144.imageshack.us/img144/5466/re924ej5.jpg
http://img374.imageshack.us/img374/875/re925kg3.jpg
http://img374.imageshack.us/img374/4493/re926zb3.jpg
Message édité par noobzed le 19-07-2008 à 15:23:02
FEEDBACK HFR
n°6474582
wolfflyter
Posté le 04-07-2008 à 00:40:50  profilanswer
On n'est pas rendu sur le choix  :)
Message édité par wolfflyter le 04-07-2008 à 00:41:16
該反思的是,往往有幫助
n°6474585
noobzed
Posté le 04-07-2008 à 00:41:46  profilanswer
tant mieux tu me diras :D
FEEDBACK HFR
n°6490851
acnoar
Posté le 12-07-2008 à 23:23:04  profilanswer
http://img120.imageshack.us/img120/6051/image3phptm9.jpg
http://img530.imageshack.us/img530/9336/image33tc1.jpg
http://img253.imageshack.us/img253/9421/image32jp9.jpg
http://img120.imageshack.us/img120/3421/image31fr9.jpg
n°6490853
acnoar
Posté le 12-07-2008 à 23:24:35  profilanswer
l'annonce officielle du 8 juillet par Asus :
http://www.asus.com/news_show.aspx?id=12040
reste plus qu'a trouver un moyen pour se la procurer en france ...  :whistle:
Message édité par acnoar le 12-07-2008 à 23:30:17
n°6490877
sentryman
Laton Raveur
Posté le 12-07-2008 à 23:54:16  profilanswer
OMG sur la 3 ème photo le rad rouge de gauche est super grand ( pas le même que sur les autres photo )
Sinon bizzare que ce soit du X48...
n°6490920
- gab
Posté le 13-07-2008 à 00:39:48  profilanswer
Tout dans la démesure (j'ai bloqué sur l'immense rad au-dessus des ports d'E/S)... le prix devrait être à la hauteur.
Il me semblait avoir lu quelque part qu'Asus ne comptait pas la distribuer en Europe, par contre pour retrouver le lien...  :sweat:
n°6490964
acnoar
Posté le 13-07-2008 à 01:40:16  profilanswer
pour le rad, les premières photos sont un proto, alors que les suivantes sont la version commercialisée.
@sentryman : pkoi bizarre que ça soit en X48 ? tu pensais a du P45 ou X58 ?
Le plus haut en gamme en chipset intel pour core 2 duo restera le X48, puisque le X58 sera destiné au Nehalem, et le P45 reste un chipset milieu de gamme.
En P45 il y a deja la maximus II fomrula en ddr2, voir la extrem en ddr3 (?)
plus clairement :
X38 : maximus formula/extrem
X48 : rampage  formula/extrem
P45 : maximus II formula / ...
Message édité par acnoar le 13-07-2008 à 01:42:53
n°6490974
Pinto
Posté le 13-07-2008 à 01:57:22  profilanswer
Tu te trompes il y a le rad standard (celui présenté sur la photo avec la boite) et deux rads interchangeables, celui de la 3e photo et un pour remplacer le fuzion block. Les deux sont livrés avec la mobo et le montage est au choix.
n°6490975
Pinto
Posté le 13-07-2008 à 01:59:04  profilanswer
http://img510.imageshack.us/img510/2203/03xi8.jpg
http://img510.imageshack.us/img510/2203/03xi8.39edb43fd0.jpg
Message édité par Pinto le 13-07-2008 à 02:00:20
n°6490979
acnoar
Posté le 13-07-2008 à 02:04:19  profilanswer
oui, c'est ce que je suis en train de voir :
http://www.xfastest.com/viewthread.php?tid=11417#zoom
il y a 2 kit fournis pour remplacer le WB chipset par un rad caloduc, et un autre pour les mofset
Message édité par acnoar le 20-07-2008 à 13:13:48
n°6491550
Benji Tshi
Posté le 13-07-2008 à 16:20:24  profilanswer
Miamiamiam et remiam !
Moi qui était embeté de ne pas pouvoir allier perf du x38/48 et montée en FSB du P45..Meme a 400$ elle m'interesse cette mobo :p
http://valid.x86-secret.com/show_oc.php?id=388382
flick r - 5∞px - Ventes
n°6491569
ANViL
yep...definitely ♫
Posté le 13-07-2008 à 16:32:54  profilanswer
[:spaydar]
Easy Ridin'  ⎝⏠⏝⏠⎠
n°6491641
acnoar
Posté le 13-07-2008 à 17:35:05  profilanswer
faudrait organiser une cgp  :whistle:
quelqu'un connait des shops ricains/canadiens recommandable ?
Message édité par acnoar le 13-07-2008 à 20:57:14
n°6491977
Benji Tshi
Posté le 13-07-2008 à 21:34:36  profilanswer
Une idée de quand ca sort ?
n°6492079
bill'o
one life - one chance
Posté le 13-07-2008 à 22:55:17  profilanswer
le prob cest que la majorite des shops canadiens et ricains n'acceptent que les virements bancaires et c est bien galere depuis la France...
Message édité par bill'o le 13-07-2008 à 22:56:02
n°6492131
Benji Tshi
Posté le 13-07-2008 à 23:44:39  profilanswer
Et ce n'est pas interessant car on a une chance sur deux de se faire controller et de payer les taxes :/
n°6492326
acnoar
Posté le 14-07-2008 à 09:18:16  profilanswer
c'est pas faux  :sweat:
n°6494651
acnoar
Posté le 15-07-2008 à 18:51:17  profilanswer
n°6494765
darckcryst​al
Anima Sana In Corpore Sano
Posté le 15-07-2008 à 20:02:58  profilanswer
n°6494770
drainvac
ici, ici c'est oyonnax!
Posté le 15-07-2008 à 20:06:31  profilanswer
qu'elle est belle!!!!
*mon feed-back*
n°6494825
acnoar
Posté le 15-07-2008 à 20:46:18  profilanswer
 [:aloy2]
Message édité par acnoar le 15-07-2008 à 20:46:33
n°6494942
samix
Posté le 15-07-2008 à 22:34:22  profilanswer
[:drapal]  [:drapal]    :love:  :love:
n°6495036
bazooca1
Jedi de l'octet & ami de Tux
Posté le 15-07-2008 à 23:15:25  profilanswer
Yeah la new mobal de geek !!! (drapal deguised) [:cerveau obawi]
Message édité par bazooca1 le 16-07-2008 à 01:41:01
Feedback
n°6499449
samix
Posté le 18-07-2008 à 17:52:21  profilanswer
up :)
n°6499673
benji77fr
Posté le 18-07-2008 à 19:58:50  profilanswer
je suis aller à surcouf aujourd'hui et je l'ai vu mais au dos de la boite il indique X38/ich9r bizarre , mais miam miam la carte quand même :p .
j'edit ma connerie, j'ai mal lu le post c'est la formula que j'ai vu , faut que j'aille me coucher je crois ^^ .
Message édité par benji77fr le 18-07-2008 à 20:01:00
n°6499675
gogofr
poor lonesome cowboy
Posté le 18-07-2008 à 20:00:23  profilanswer
si elle été en DDR2 elle aurait trouvé sa place dans mon pc :o
Message édité par gogofr le 18-07-2008 à 20:06:20
n°6499774
acnoar
Posté le 18-07-2008 à 21:01:28  profilanswer
 :heink:
la rampage existe en version ddr2 > rampage formula.
Si c'est la gueule de la carte qui te plait, alors c'est la maximus II formula en P45 qui pourrait t'interesser.
n°6499793
gogofr
Posté le 18-07-2008 à 21:18:08  profilanswer
oui le style qui m'intersse,mais le p45 :s non merci
n°6500355
acnoar
Posté le 19-07-2008 à 12:54:14  profilanswer
le P45 est tres bien, mis a part si tu veux mettre un crossfire, le P45 se defend tres tres bien.
n°6501215
Fssabbagh
Satsui no Hado
Posté le 20-07-2008 à 00:03:54  profilanswer
plus de 700mhz de fsb :love:
http://www.puissance-pc.net/cpu-mo [...] ?Itemid=48
je l'adore trop cette Asus :love:  :love:
Dommage qu'on a pas l'équivalent, du genre une Rampage version 790i sli
Message édité par Fssabbagh le 20-07-2008 à 00:04:36
Messatsu !
n°6501244
bazooca1
Posté le 20-07-2008 à 00:32:30  profilanswer
Pas à dire c'est la classe à Dallas cette mobal [:implosion du tibia]
Message édité par bazooca1 le 20-07-2008 à 01:29:36
Feedback
n°6501470
acnoar
Posté le 20-07-2008 à 10:22:28  profilanswer
surtout que c'est sur du X48.  :love:
Les derniers tres gros fsb avaient été fait avec du P45, qui a une bien meilleure aptitude a prendre du fsb,
le X48 n'est (n'etait) pas réputé pour prendre du gros fsb. voilà qui change tout, bravo a l'equipe ROG  [:simonh14]
n°6501598
monsieurto​f
Ah ouais merde 30 ans là...
Posté le 20-07-2008 à 12:05:57  profilanswer
drapal, trop belle cte carte  :ouch:
C'est bien 8 ports sata que je vois ?
n°6501688
acnoar
Posté le 20-07-2008 à 13:10:44  profilanswer
non 6 sata (4 par le southbridge et 2 par la puce marvel) et un e-sata.
Faudrait que noobzed complete le 1er post avec les vraies spécifications asus, et pas juste avec quelques photos issu du computex (proto).
Alley noobzed, au boulot!
edit/ ah non c'est bien 8 ports sata, dont 6 gérés par le south + e-sata
Message édité par acnoar le 20-07-2008 à 13:18:46
n°6501714
ANViL
yep...definitely ♫
Posté le 20-07-2008 à 13:35:24  profilanswer
Osef du look de la CM, ce qui compte c'est l'ergonomie / le layout / les perfs  [:prodigy]
Sinon, futurs possesseurs de cette CM, lisez ceci à tout hasard.
Message édité par ANViL le 20-07-2008 à 13:41:17
Easy Ridin'  ⎝⏠⏝⏠⎠
n°6502017
Fssabbagh
Satsui no Hado
Posté le 20-07-2008 à 16:50:32  profilanswer
et en plus ati reprends du poil de la bête donc là on prends du crossfire. a noter que mettre deux 4870x2 en crossfire X ne fonctionne que sur le 790FX, chipset d'AMD
Message édité par Fssabbagh le 20-07-2008 à 16:51:25
Messatsu !
n°6502044
acnoar
Posté le 20-07-2008 à 17:10:55  profilanswer
c'est pas nouveau, les systemes de caloduc d'asus sont tjrs montés/équilibrés avec les pieds
voir mes tofs ici, là c'etait les SB qui n'etait meme pas en contact :
http://forum.hardware.fr/hfr/Hardw [...] 6459_5.htm
Message édité par acnoar le 20-07-2008 à 17:11:49
n°6502221
Benji Tshi
Posté le 20-07-2008 à 18:55:41  profilanswer
Le P45 est tres bien pour le CF aussi, faut arreter de dire n'importe quoi et faut lire les tests !
Page Précédente
[Topic Unique] Lian-Li PC A-77 Gigantesque !Topic Unique des Alimentations Modulaires
[topic unique]formattage et reinstalation windows 98Question sur la Asus Rampage Formula
[Topic Unique] Référencement Des Ampérages Des Alimentations[Topic Unique] Les boîtiers Aerocool avec des ventilos de 40 cm
Problème Striker II ExtremePb d'ecran noir sur Maximus Extreme
El diablo compatible Ultra 120 Extreme
Plus de sujets relatifs à : [Topic unique] Rampage Extreme
