3035 connectés
  [Topic Unique] MSI K8N Neo2 Platinum - Athlon 64 socket 939 - nForce 3
 Page :   1  2  3  4  5  ..  107  108  109  110  111  112
Page Précédente
n°3394616
bender007
Posté le 06-08-2004 à 19:32:15  profilanswer
Et voici la MSI K8N Neo2 Platinum, carte mere socket 939 qui va, je pense, bien faire parler d'elle.  :sol:
http://www.msi.com.tw/images/product_img/other/mainboard/pic/nforce3_250gb.gif =>  :love:
http://images.anandtech.com/reviews/chipsets/roundups/2004/socket939roundup/k8n.jpg
Pour ceux créeant des RAID 0 sous NForce 3 :
Unfortunately, Intel, NVIDIA, SiS, and VIA don't agree on a common default stripe size. Intel suggests a 128KB strip size; NVIDIA prefers 32KB; and SiS and VIA default to 64KB. I trust that each company has a firm enough grasp of the unique performance characteristics of its RAID controller to recommend the best stripe size for its chipsets, so we'll be using default stripe sizes throughout.
http://tech-report.com/reviews/200 [...] dex.x?pg=2
Merci lovingbenji
Un ptit guide d'installation du RAID SATA sous NForce3 MSI :
http://forums.pcper.com/showthread.php?t=340514
Encore merci lovingbenji  :sol:
Coté technique :
CPU
  • Supports Socket 939 for AMD® Athlon™ 64FX/64 processor
• Supports 3500+, 3800+ Athlon 64FX 53, or higher CPU   :ange:
Chipset
  • nVIDIA® nForce3 Ultra Chipset   :pt1cable:
- HyperTransport link to the AMD Athlon 64/Athlon 64FX CPU
- HyperTransport supporting speed up to 1GHz (2000MT/s)
- AGP3.0 8X interface at 533MT/s (million transfers per second)
- Two independent SATA controllers, for four drives
- IEEE 802.3 NVIDIA MAC for 1000BASE-T
- Dual Fast ATA-133 IDE controllers
Main Memory
  • Supports dual channel DDR 266/333/400, using four 184-pin DDR DIMMs.
• Supports the memory size up to 4GB
• Supports 2.5v DDR SDRAM DIMM
Due to the High Performance Memory design, motherboards or system configurations may or may not operate smoothly at the JEDEC (Joint Electron Device Engineering Council) standard settings (BIOS Default on the motherboard) such as DDR voltage, memory speeds and memory timing. Please confirm and adjust your memory setting in the BIOS accordingly for better system stability.
Example: Kingston HyperX DDR500 PC4000 operates at 2.65V, 3-4-4-8, CL=3.
For more information about specification of high performance memory modules, please check with your Memory Manufactures for more details.
Slots
  • One AGP (Accelerated Graphics Port) 1.5V 4X/8X slot
• Five 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface).
On-Board IDE/SATA
  • An IDE controller on the nVIDIA nForce3 Ultra chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA133/100/66 operation modes.
- Can connect up to 4 IDE devices
• Supports 4 SATA ports. Transfer rate is up to 150MB/s
• NV RAID (Software)
• Supoprt up to 4 SATA & 4 ATA133 Hard drives
- RAID 0 or 1, 0+1, JBOD is supported
- RAID function work w/ATA133 + SATA H/D
BIOS
  • The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface (DMI) function which records your mainboard specifications.
Audio
  • 7.1 channel audio codec RealTek ALC850.
- Compliance with AC97 v2.3 Spec.
- Meet PC2001 audio performance requirement.
LAN
  • Supports dual LAN jacks
- 1 LAN supports 10/100/1000 Fast Ethernet by Marvell 88E1111 PHY
- 1 LAN supports 10/100/1000 Fast Ethernet by Realtek 8110S (1000Mbps)
IEEE1394
  • VIA 6306 chipset
- Supports up to 3 x 1394 ports
- Transfer rate is up to 400Mbps
On-Board Peripherals
  - 1 floppy port supports 1 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
- 1 serial port
- 1 parallel port supports SPP/EPP/ECP mode
- 1 audio jack (5-in-1), coaxial/fibre SPDIF out
- 8 USB 2.0 ports (Rear x 4 / Front x 4)
- 2 RJ45 LAN jack
- 3 IEEE 1394 connectors (Rear x 1/ Front x 2)
Dimension
  30.5cm(L) x 24.5cm(W) ATX Form Factor
Mounting
  6 mounting holes
Tableaux Récapitulatifs :
http://zic3.aurel.free.fr/Forum/tab.jpg http://www.x86-secret.com/pics/cpu/s939/nf3sch.png
Les Testes :
x86-secret (comparatif Asus A8V (K8T800Pro) conter MSI K8N Neo2 Platinium (nForce3 250 Gb) )
Les Awards
http://images.anandtech.com/gold_award.jpg
Elle est sortie gagnante de la "Battle at the Top" faite par AnandTech et opposant 6 cartes-meres socket 939  :sol:
Le lien
Disponibilité
Dispo maintenant un peu partout même si le délais pour la recevoir est long parfois.  :love: A vos port-feuilles  :D
Conseil pour le ventilo :
Zalman 7000B-AlCu ou cu (et ca passe !! :ange: ):
http://nononice.free.fr/Photo%20008.jpg
http://nononice.free.fr/Photo%20031.jpg
http://nononice.free.fr/Photo%20022.jpg
http://nononice.free.fr/Photo%20020.jpg
Message édité par bender007 le 29-08-2004 à 16:07:55
n°3394922
Posté le 06-08-2004 à 22:03:53  answer
Elle est proposée sur materiel.net, mais avec 14 jours de battement :kaola:. C'est dingue que la France réagisse 17 000 000 000 d'années plus tard :sarcastic:.
C'est la carte mère avec la Gigabyte K8NSNXP-939 desquelles j'hésite fortement entre les deux.
Le pb du chipset Via K8T800 Pro, ce n'est pas tant ses performances, vu qu'en 3D elle s'en tire très bien. Mais je vois de très loin le même schéma que l'opposition KT400/nForce 2. Lorsque la KT400 est sortie (avant le nForce 2), c'était sur le papier et dans "certains" tests monts et merveilles, soi-disant :ange:. C'est après qu'on a découvert les mauvaises surprises, notamment le non-support du FSB 200 MHz, les gros pbs avec la plupart des DDR 400 MHz et la très très mauvaise gestion des USB (à cause du chipset southbridge VT8377). Peu de temps après, le nForce 2 sortait : miracle : support du FSB 200 MHz, de la plupart des DDR 400 MHz et bonne gestion des USB.
Je m'aperçois dans pas mal de posts qu'il y a encore des gens pour croire que le K8T800 Pro serait supérieur au nForce 3 250 Ultra. Franchement, je ne vois pas où :??:.
Voici en gros les avantages du nForce 3 250 Ultra par rapport au K8T800 Pro :
Gestion du PCI/AGP lock.
Firewall matériel et Gbit ethernet natif au chipset (ce qui laisse supposer un double Gbit Ethernet avec un second contrôleur ethernet, le cas de la MSI K8N Neo 2).
Gestion du Raid natif au chipset.
Un seul chipset unique, supprimant les latences éventuelles entre un northbridge et un southbridge.
Gestion jusqu'à 4 S-ATA en natif (+ deux par un contrôleur externe au chipset principal).
Interface graphique des pilotes nForce Forceware monumentalement moins sporadiques que les Hyperions de Via.
Overclocking potentiel nettement supérieur grace, entre autre, au PCI/AGP lock.
Les avantages du K8T800 Pro par rapport au nForce 3 250 Ultra : cochez la bonne réponse :
– Je ne fais pas dire ce que je ne fais pas
– Je respecte les spécifications que j'avance
– Je me suis fais jeter par Intel, alors je tente le tout pour le tout sur AMD :whistle:
n°3394968
bender007
Posté le 06-08-2004 à 22:31:21  profilanswer
Effectivement elle est dispo sur materiel.net mais bon, elle est cher  :(  200€ ca comment a faire pour un carte mere  :sweat:
merci pour les infos Childerik  ;)
(mis e a jour prix et lieu d'achat)
n°3394976
Nakis
Posté le 06-08-2004 à 22:35:45  profilanswer
Salut
Quelcun sais ou je pourrai la trouver en Suisse ?
Parce que Via j'en ai de très mauvais souvenirs :sweat:
n°3394985
bender007
Posté le 06-08-2004 à 22:38:54  profilanswer
Comment l'a dis Childerik,la Disponibilité est de 14 jours env. :(
Pour la suisse j'en ai aucune idée :/
n°3394987
krixoff
chaos
Posté le 06-08-2004 à 22:39:18  profilanswer
franchement je souhaite pas qu'elle ait les mêmes problemes que la K8N, c'est à dire la capacité à gerer 2 mêmes barettes ddr ( inutile de dire que differentes barettes pose encore plus de problemes )
Message édité par krixoff le 06-08-2004 à 22:39:57
n°3394993
bender007
Posté le 06-08-2004 à 22:42:16  profilanswer
Je vien de voir sur materiel.net qu'il y a ecris
Mémoire :
4 connecteurs Dimm 184 pins
Supporte la DDR-SDRAM (ECC) PC3200 jusqu'à 4Go
Cela veut-il dire qu'il faut obligatoirement mettre de la mémoire ECC Registered ?  :??:
n°3394997
Nakis
Posté le 06-08-2004 à 22:44:23  profilanswer
non non !!
ça veux dire qu'elle accepte autant de la mémoire ddr normale que de la Ecc :jap:
n°3394998
bender007
Posté le 06-08-2004 à 22:45:51  profilanswer
nakis a écrit :
non non !!
 :whistle: oufff  :lol:
je me suis fait peur tout seul  :pt1cable:
n°3395013
Nakis
Posté le 06-08-2004 à 22:57:35  profilanswer
Heu opui :lol:
Dit a part natériel .net y at'il un autre mag ( français ) qui la vendrai ??
Et mis à part cette carte  y a t'il un autre model avec ce chipset qui est plus répendue ??
 :D  :D  :D
n°3395032
bender007
Posté le 06-08-2004 à 23:08:43  profilanswer
nakis a écrit :
Heu opui :lol:
 :D  :D  :D
A ma connaissance les carte mere a base de nForce3 250 Gb ne sont pas encore présente en france (pour socket 939 car pour socket 754 on en trouve plein  :jap: )
J'ai fait quelques recherches mais je n'est trouvé aucun magasin qui la vende :S
Message édité par bender007 le 06-08-2004 à 23:10:15
n°3395036
Posté le 06-08-2004 à 23:10:09  answer
nakis a écrit :
Heu opui :lol:
 :D  :D  :D
En fait, le nForce 3 Ultra fait tout juste son entrée dans le socket 939. Je pense que fin Août, la dispo va exploser d'un coup. Il y a pleins de magasins allemands qui vendent, parfois sous dispo immédiate, la K8NSNXP-939 basée sur le NF3 Ultra. Ca ne va pas tarder pour la France (espérons-le :ange:)
n°3395037
Anakin Sky​walker
Ubuntu user
Posté le 06-08-2004 à 23:10:32  profilanswer
Bender007 a écrit :
A ma connaissance les carte mere a base de nForce3 250 Gb ne sont pas encore présente en france (pour socket 939 car pour socket 740 on en trouve plein  :jap: )
Socket 754  [:aloy]
(bon tu me diras sur le topic K8N, il y a bien un forumeur qui tourne en socket 753  :whistle: )
n°3395045
Posté le 06-08-2004 à 23:16:29  answer
Anakin Skywalker a écrit :
Socket 754  [:aloy]
Mouarffffffffff, décidément :D. Bientôt, on va voir qq'un dire du socket 747 (comme Boeing, koi :lol:)
n°3395076
bender007
Posté le 06-08-2004 à 23:33:18  profilanswer
J'ai remarquer, j'ai d'ailleur éditer des que je me suis rendu compte  :pt1cable:
--Message édité par Bender007 le 06-08-2004 à 23:10:15--
2min apres  :D
 :kaola:    :D
n°3395086
Anakin Sky​walker
Ubuntu user
Posté le 06-08-2004 à 23:37:42  profilanswer
Euh oui ben c'est pas moi qui prendrai un proc sur ce socket alors :whistle:
J'ai envie d'avoir un systeme stable moi  :o  :D
n°3396534
Anh
Posté le 07-08-2004 à 20:01:36  profilanswer
Près de bordeaux, deux magasins ont annoncé la version classique à 169 EUR.
Dispo à partir de la semaine prochaine.
n°3396552
bender007
Posté le 07-08-2004 à 20:09:32  profilanswer
http://forum.hardware.fr/icones/icon10.gifhttp://forum.hardware.fr/icones/icon10.gifhttp://forum.hardware.fr/icones/icon10.gif
 :bounce:
Message édité par bender007 le 07-08-2004 à 20:14:19
n°3396553
Nakis
Posté le 07-08-2004 à 20:09:34  profilanswer
C'est du tout bon ça  :)
Ves 2 magasins ont un site web :??:  ;)
n°3398394
Anh
Posté le 08-08-2004 à 18:57:07  profilanswer
Un seul a un site web pour le moment :
http://www.centre-informatique.fr/ [...] M_pour_amd
n°3398404
Nakis
Posté le 08-08-2004 à 19:02:04  profilanswer
petite question le Nforce 3 Supporte t'il le PCI Express 16x ??
n°3398601
le passant
Posté le 08-08-2004 à 20:17:09  profilanswer
Nope, je crois pas, c'est pas le nforce4 ???
n°3398613
zimonex
Posté le 08-08-2004 à 20:25:27  profilanswer
mmm elle a l'air appétissante cette tite mobo
n°3398619
le passant
Posté le 08-08-2004 à 20:28:09  profilanswer
M'ouaih, en fin de compte se sera du 939 avec MSI pour moi ...  :jap:
Mais bon faut sousous avant   :sweat:
Message édité par le passant le 08-08-2004 à 20:28:38
n°3399854
bender007
Posté le 09-08-2004 à 12:54:27  profilanswer
Mise a jour des prix, je vais essayer de trouver plus de sites dans l'aprème :)
n°3400643
doohan974
Posté le 09-08-2004 à 17:15:09  profilanswer
je me vois bien aussi avec cette carte mère à la rentrée. Bizarre sur le net français j'avais vu aucune disponibilité, j'ai juste trouvé des magazins en blegique ou allemagne. Vivement la rentrée! héhé
n°3400953
Posté le 09-08-2004 à 18:51:09  answer
Apparement dispo chez 1000ordi (3/4 jours), mais chez Materiel.net, dispo pas avant 15 jours.
n°3401098
Nakis
Posté le 09-08-2004 à 19:39:06  profilanswer
CHEZ 1000 ORDI !!!!  :)
J'y cours !!!!  :hello:  ;)
n°3401163
Cantafan
Posté le 09-08-2004 à 19:53:41  profilanswer
Plusieurs magasins que j'ai repéré et qui ont cette carte en référence:
E-soph
1000 Ordi
Materiel.net
Banouma
n°3401726
fatal_bazo​oka
Aucun rapport avec M.Youn!!!!!
Posté le 09-08-2004 à 22:29:51  profilanswer
je sui allé o magasin centre informatique, il en ont po encore et il doivent po en recevoir avant vendredi (probablement vendredi ds 2 semaines) = ca sert a rien de commandé!! ;)
n°3401727
fatal_bazo​oka
Posté le 09-08-2004 à 22:30:22  profilanswer
c koi l'otre magasin ki propose le la mobo pres de Bordeaux?
n°3401741
noelemac
Posté le 09-08-2004 à 22:34:10  profilanswer
Je compte prendre aussi cette carte mere, mais en lisant le test je sait plus ou, ou en regardant la photo, le design a était fait avec les pieds...
Alimentation mal placé, emplacement mémoire au dessus du processeur, et d'autre truc du genre un condo qui touche avec certain rentirad... qui lui ont valu le terme de design massacré...
J'essaye de retrouver le test.
Message édité par noelemac le 09-08-2004 à 22:39:28
n°3402327
Nakis
Posté le 10-08-2004 à 08:55:03  profilanswer
ça est je l'aie commandée !!!  :)
Je l'aurai ce vendredi
n°3402335
- Fred -
007 Agent
Posté le 10-08-2004 à 09:03:53  profilanswer
Avec quel proc nakis ? Tu as pensé à prendre un rad chipset Zalman ?
Sinon, pour la CM même pourquoi est-ce que le contrôleur réseau nForce n'est pas inclu ? Est-ce qu'on peut tout de même profiter du firewall matériel ?
Message édité par - Fred - le 10-08-2004 à 09:06:08
"You know the name, You know the number..."
n°3402608
Nakis
Posté le 10-08-2004 à 11:27:50  profilanswer
Je l'ai commandée hier soir chez Pctop
J'ai commandé ça
MSI K8N Neo2 Platinum ( nForce3 Ultra - Socket 939 )
AMD Athlon 64 3800+ [ Socket 939 - 512KB - 2.4GHz ] + Ventilateur
2 barrettes DDR 512MB DDR400 (PC3200) Corsair XMS CL2.0
MSI NX6800 Ultra-T2D256 ( NX6800 Ultra 256DDR TV DVI )
Pour le Rad Zalman je verrai au magasin avec le vendeur
Pour le Firewall Je ne sais pas ?? je verrai au moment de l'instal
Je metterai les pièces de ma config actuelle dedant  pour compléter
Maintenant.....l'attente  :jap:
n°3402611
HappyHarry
Posté le 10-08-2004 à 11:29:10  profilanswer
J'ai commandé ça
(envie)
ca sera surement un truc comme ca que je me ferai, mais pas tout en meme temps, ca fait un peu cher quand meme :sweat:
Message édité par HappyHarry le 10-08-2004 à 11:29:59
n°3402656
Nakis
Posté le 10-08-2004 à 11:39:32  profilanswer
HappyHarry a écrit :
(envie)
Dommage que tu habite pas en suisse :sweat:  le matos info n'est pas trop cher chez nous ( Qu'il me semble.... )
Message édité par Nakis le 10-08-2004 à 11:40:00
n°3402707
HappyHarry
Posté le 10-08-2004 à 11:54:36  profilanswer
150 bornes et je suis a bale :ange:
mais faut voir si ca passe la douane facilement ....
j'ai fait le total avec les prix francais, ta config dépasse les 1700€ (2500 CHF a la louche) :sweat:
n°3402717
Nakis
Posté le 10-08-2004 à 11:56:49  profilanswer
non non moins
2100Frs  !!!
n°3402723
HappyHarry
Posté le 10-08-2004 à 11:57:50  profilanswer
t'as un site avec des prix en suisse, que je jette un coup d'oeil ?
Page Précédente
Athlon Xp "classique" à la place d'un Athlon XP-MProbleme de température Athlon XP 2500+
qq un aurai t il une adresse ou commander une K8N neo 2 plat ?[AVIS] msi k8t neo fis2r ou asus k8v se deluxe ?
problème démarrage CM MSI KT4 Ultra SR + Bios Award trois bips longstempérature sur msi 5900xt?
Mobo MSI KT3 Ultra 2 lockée ou cramée?Athlon thunderbird 1400MHz
Carte mere msi !Athlon 64 3200+ a 70°
Plus de sujets relatifs à : [Topic Unique] MSI K8N Neo2 Platinum - Athlon 64 socket 939 - nForce 3
Hit-Parade
