849 connectés
  [Topic Unique] Gigabyte GA-H61N-USB3 : mini-ITX
 Page :   1  2
Page Précédente
n°8245873
burn2
ça rox du poney
Posté le 15-03-2012 à 20:05:53  profilanswer
Bonjour, n'ayant pas vu de topic unique sur cette carte mère, je me permets d'en créer un.
J'en reçois une cette semaine, donc je vais essayer de faire un petit topic unique.
Donc voici rapidement la description de cette carte mère:
http://www.gigabyte.com/fileupload/product/2/3963/4871.jpg
Et la description de la config:
CPU
Support for an Intel® Core™ i7 series processor/Intel® Core™ i5 series processor/Intel® Core™ i3 series processor/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
L3 cache varies with CPU
 (Some Intel® Core™ processors require a graphic card, please refer "CPU support List" for more information.)
Chipset
Intel® H61 Express Chipset
Memory
2 x 1.5V DDR3 DIMM sockets supporting up to 16 GB of system memory
 * Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
Dual channel memory architecture
Support for DDR3 1333/1066/800 MHz memory modules
Support for non-ECC memory modules
 (Please refer "Memory Support List" for more information.)
Onboard Graphics Integrated in the Chipset:
1 x D-Sub port
1 x DVI-D port, supporting a maximum resolution of 1920x1200
 * The DVI-D port does not support D-Sub connection by adapter.
1 x HDMI port, supporting a maximum resolution of 1920x1200
Audio
Realtek ALC889 codec
High Definition Audio
2/4/5.1/7.1-channel
 * To configure 7.1-channel audio, you have to use an HD front panel audio module and enable the multi-channel audio feature through the audio driver.
Support for S/PDIF Out
LAN
1 x Realtek RTL8111E chip (10/100/1000 Mbit)
Expansion Slots
1 x PCI Express x16 slot, running at x16
 (The PCIEX16 slot conforms to PCI Express 2.0 standard.)
Storage Interface Chipset:
2 x SATA 3Gb/s connectors (SATA2_0, SATA2_1) supporting up to 2 SATA 3Gb/s devices
1 x eSATA 3Gb/s connector on the back panel supporting up to 1 SATA 3Gb/s device
USB Chipset:
Up to 8 USB 2.0/1.1 ports (4 on the back panel, 4 via the USB brackets connected to the internal USB headers)
 Fresco FL1009 chip:
Up to 2 USB 3.0/2.0 ports on the back panel
Internal I/O Connectors
1 x 24-pin ATX main power connector
1 x 4-pin ATX 12V power connector
1 x CPU fan header
1 x system fan header
1 x front panel header
1 x front panel audio header
1 x S/PDIF Out header
2 x USB 2.0/1.1 headers
1 x Trusted Platform Module (TPM) header
1 x clearing CMOS jumper
Back Panel Connectors
1 x optical S/PDIF Out connector
1 x coaxial S/PDIF Out connector
1 x D-Sub port
1 x DVI-D port
1 x HDMI port
4 x USB 2.0/1.1 ports
2 x USB 3.0/2.0 ports
1 x RJ-45 port
3 x audio jacks (Line In/Line Out/Microphone)
I/O Controller
iTE IT8728 chip
H/W Monitoring
System voltage detection
CPU/System temperature detection
CPU/System fan speed detection
CPU fan speed control
 * Whether the CPU fan speed control function is supported will depend on the CPU cooler you install.
BIOS
2 x 32 Mbit flash
Use of licensed AWARD BIOS
Support for DualBIOS™
PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Unique Features Support for @BIOS
Support for Q-Flash
Support for Xpress BIOS Rescue
Support for Download Center
Support for Xpress Install
Support for Xpress Recovery2
Support for EasyTune
 * Available functions in EasyTune may differ by motherboard model.
Support for Dynamic Energy Saver™ 2
Support for Smart 6™
Support for Auto Green
Support for ON/OFF Charge
Support for 3TB+ Unlock
Support for Cloud OC
Support for Q-Share
Bundle Software
Norton Internet Security (OEM version)
Operating System
Support for Microsoft® Windows 7/Vista/XP
Form Factor
Mini-ITX Form Factor; 17.0cm x 17.0cm
Site du constructeur:
http://www.gigabyte.com/products/p [...] id=3963#ov
Message édité par burn2 le 02-11-2012 à 11:30:03
n°8245875
burn2
ça rox du poney
Posté le 15-03-2012 à 20:06:12  profilanswer
Alors carte mère monté, rien à dire c'est du tout bon, ça boot vite, c'est pratique efficace, sobre et ça fait ce qu'on lui demande! :)
Voilà le bundle:
http://img11.hostingpics.net/thumbs/mini_139401DSC00002.jpg
Y a donc 2 cables satas dont un coudé, qui est pratique en temps normal, mais pas dans mon boitier, heureusement j'avais d'autres cables sata que j'ai utilisé à la place...
un manuel et la façade.
Boite sobre mais pratique qui fait boite rien à déchirer ou autre, ça s'ouvre et se referme tout seul.
Une photo plus proche de la carte mère:
http://img11.hostingpics.net/thumbs/mini_676100DSC00003.jpg
la connectique externe:
http://img11.hostingpics.net/thumbs/mini_321016DSC00005.jpg
Voilà la carte mère une fois montée:
http://img11.hostingpics.net/thumbs/mini_984400DSC00014.jpg
Message édité par burn2 le 17-03-2012 à 15:25:55
n°8245884
burn2
ça rox du poney
Posté le 15-03-2012 à 20:13:36  profilanswer
Les plus/moins
Plus:
-Pci expres 16x 2.0 sur une mini itx
-Petit prix (75€ en général)
-USB 3.0 et pas mal de ports
-Dual bios comme d'habitude chez gigabyte
-Sorties vidéos variées: DVI-D/HDMI/VGA on a du choix...
-Bios qui permet pas mal de réglage
Moins:
-Que deux ports sata!
-Un seul ventilateur configurable par PWM (prise 3 Pin pour le sys et pas de régulation du ventilateur)
-Connecteur d'allimentation trop près du bord. Cela m'empêche de mettre un deuxième ventilateur sur mon boitier.
N'hésitez pas à donner votre avis! :)
Message édité par burn2 le 17-03-2012 à 15:12:16
n°8247676
burn2
ça rox du poney
Posté le 17-03-2012 à 15:26:35  profilanswer
Carte mère monté, rajout d'un avis rapide etc.
Donc voilà si vous avez des questions n'hésitez pas. ;)
n°8255922
burn2
ça rox du poney
Posté le 24-03-2012 à 12:02:02  profilanswer
Ben ça n'attire pas les foules ce topic, personne n'a ou n'est intéressé par cette carte mère? :/
n°8275648
Aldaris38
Posté le 12-04-2012 à 20:41:52  profilanswer
Salut Burn2...
Oui moi ca m'intéresse, je prévois justement d'acquérir cette carte mère. Je suis en train de me construire un HTPC et voici ma config:
Boîtier Silverstone ML03B
PSU Seasonic 400w Fanless SS-400FL
Carte-mère Gigabyte GA-H61N-USB3
CPU Intel Core i3-2120
4GB de RAM DDR3 1333
Lecteur Blu-Ray Asus
Disque dur OCZ Vertex Plus 60GB
Windows 7
Bref, quelque chose de convenable qui sera quand même performant. Le tout sera plus tard branché sur un NAS où seront logé mes films. Je viens tout récement d'acheter une télévision DEL 55po alors je veux de quoi de décent pour streamer mes films en HD en parralèle avec mon lecteur Blur-Ray 3D.
Présentement j'ai une vieille tour Thermaltake qui roule avec un bon vieux Core 2 Duo E8400 et 2GB de mémoire DDR2.
Bien hâte de monter ca. Je devrais poster les photos si ca t'intéresse. :)
n°8275984
burn2
ça rox du poney
Posté le 13-04-2012 à 10:22:18  profilanswer
ça reste une très bonne carte mère.
Son seul gros défaut, c'est le fait qu'elle n'est que 2 ports satas.
Pour les photos tu peux toujours les poster ça fera vivre le topic. :D Vu que ça n'attire pas les foules. :p
n°8281556
tabb
Posté le 18-04-2012 à 20:07:39  profilanswer
Qq questions :
- Suporte-elle le Wake On Lan  ?
- Quel est ton boitier ?
- As-tu ajouté une carte graphique, si oui, quelles sont les dimensions max ? J'ai peur d'acheter une CG qui ne rentre pas ;)
- Est-ce difficile à monter ? (par rapport à une ATX)
- Sur quel site l'as-tu acheté ?
Message édité par tabb le 18-04-2012 à 20:10:36
n°8282033
burn2
ça rox du poney
Posté le 19-04-2012 à 09:03:02  profilanswer
1) oui comme toutes les cartes mères depuis un bon moment
2) Antec ISK300: pour les infos du montage voir là:
http://forum.hardware.fr/forum2.ph [...] 0#t8247685
3) Non pas rajouté. Je ne sais pas trop la taille maximale qui rentre, de toute façon il faut du lowprofile, et avec un rad qui ne dépasse pas des deux côté, un truc qui fait la taille d'un port pci express quoi. Pour l'instant je n'ai pas besoin de gpu sup, l'igp intel fait bien son job pour l'accélération graphique
4) Tout dépend la taille du boitier. Sinon c'est pareil. Y a juste un peu moins de place, et le plus dur c'est de ranger. De mon côté dans mon antec ça c'est fait sans pb. Plus facile que prévu. :)
5) Sur le site de matériel.net
Voilà. :)
Sinon il y a le bios F7 qui est sorti, je dois être au bios F5 et pas d'info sur un hypothétique bios F6, donc je sais pas trop s'il y a d'autres changements que ceux mentionnés, je ferais la maj quand même.
(le faire depuis une clef usb c'est bien pratique. :) )
Message édité par burn2 le 19-04-2012 à 09:04:21
n°8293201
tweety26
Posté le 29-04-2012 à 01:26:47  profilanswer
merci pour ce Topic  ;) l'ami  :jap:
j'ai longuement hésité   :ange: je vais la tester  :jap: cette CM  :jap:
ont verra bien ma ZOTAC 9300 gt IE est tombée en panne mon Pico Psu :kaola:  150 WATTS a chauffé   :D IL A TENU 6 HEURES  :kaola:
= mobo HS + Hdd HS grillé  :cry:
plus d'information sur cette carte mère ici  :hello:
http://forums.bit-tech.net/showthread.php?t=215362
http://www.twcarpc.com/photo/wwm/2011/IPG/IPG11.jpg
6.2 en 3d avec 1 G850
http://www.twcarpc.com/photo/wwm/2011/IPG/IPG850WIND7.png
Message édité par tweety26 le 29-04-2012 à 01:32:41
n°8293202
tweety26
Posté le 29-04-2012 à 01:30:22  profilanswer
il U tourné mon boitier ITX   :hello:
http://img841.imageshack.us/img841/7759/1000369y.jpg
le Pico  Psu m'a tout fait grillé  :kaola:
http://img27.imageshack.us/img27/1886/1000379a.jpg :hello:
Message édité par tweety26 le 29-04-2012 à 01:35:58
n°8413017
noobzed
Where is Brian ? DTC !
Posté le 12-08-2012 à 18:59:59  profilanswer
Je vais bientôt la recevoir ; i3-2100, 4 Go de RipJawsX, HD5670
Je vous dirai si ça déboite ( en regard du prix :o ) !?
FEEDBACK HFR
n°8413133
lepiaf37
Posté le 12-08-2012 à 21:27:21  profilanswer
en ma possession depuis décembre, ras, petite carte simple
http://reparationsonosplay5.free.fr/
n°8419267
burn2
ça rox du poney
Posté le 18-08-2012 à 14:03:00  profilanswer
idem depuis la création de ce topic. elle joue parfaitement son rôle.
n°8433958
lepiaf37
Posté le 30-08-2012 à 22:40:43  profilanswer
http://img267.imageshack.us/img267/5214/img0895av.jpg
Message édité par lepiaf37 le 30-08-2012 à 22:40:57
n°8434210
burn2
ça rox du poney
Posté le 31-08-2012 à 09:48:45  profilanswer
n°8436463
noobzed
Posté le 02-09-2012 à 23:39:04  profilanswer
moi j'ai un probleme insoluble ... l'usb 3, le driver veut pas marcher en fait j'ai un point d'exclamation et pas moyen d'avoir l'usb  3 ..... ca me fait suer et j'ai demandé un numéro de retour a topachat
FEEDBACK HFR
n°8436606
burn2
ça rox du poney
Posté le 03-09-2012 à 09:48:04  profilanswer
Sous linux RAS. N'ayant rien en usb3, je ne peux dire si ça marche, mais en tout cas les ports USB3 fonctionnent en USB2 sans pb.
n°8450727
lepiaf37
Posté le 15-09-2012 à 22:58:04  profilanswer
n°8450728
lepiaf37
Posté le 15-09-2012 à 22:58:57  profilanswer
n°8490551
raphdasout​h
Eplucheur de jujubes...
Posté le 26-10-2012 à 16:18:18  profilanswer
 Je viens d'installer cette cm en remplacement de la cm d'origine d'un PB imedia grillé qu'on m'a filé.
 Tout fonctionne nickel, mais est-ce qu'il y a une astuce pour modifier la vitesse de rotation du ventilateur système ?!!!   :heink:
 L'option "Current system Fan speed" est grisé et affiche bien la vitesse de rotation (5000 et quelques rpm), mais il n'y a pas d'option "System Smart fan control".....
 Car là il tourne à fond tout le temps et ca fait un sacré bruit  :sweat:
 Est-ce que cette option figure dans la dernière mise à jour du BIOS?
"I do what I do best, I take scores.You do what you do best, try to stop guys like me."
n°8490720
burn2
ça rox du poney
Posté le 26-10-2012 à 18:31:16  profilanswer
oui il y a une option. heureusement. ça a toujours été présent chez moi. je ne sais plus précisément ou.
n°8491078
raphdasout​h
Posté le 26-10-2012 à 23:30:39  profilanswer
J'ai bien la dernière version du Bios.
Je vais y regarder de plus près demain mais franchement c'est mal fait leur truc.... :/
n°8491131
burn2
ça rox du poney
Posté le 27-10-2012 à 00:08:31  profilanswer
ça ne m'a pas choqué perso. je n'ai eu aucun pb à le configurer.
n°8491964
raphdasout​h
Posté le 27-10-2012 à 20:16:21  profilanswer
 Si tu peux me retrouver le chemin pour y accéder je ne dis pas non car tout est grisé sur la page ad-hoc....  :sweat:
 edit: Dans ton post du 15/03 tu dis toi-même
  "Moins:
-Un seul ventilateur configurable par PWM (prise 3 Pin pour le sys et pas de régulation du ventilateur) "
   [:spamafote]
Message édité par raphdasouth le 27-10-2012 à 22:07:40
n°8492213
burn2
ça rox du poney
Posté le 27-10-2012 à 23:19:05  profilanswer
je dis donc justement qu'on peut configurer un seul ventilo. celui du cpu en gros. on peut en mettre deux via un adaptateur. c'est ce que j'ai. tout bouge celon la temp cpu du coup.
n°8492343
raphdasout​h
Posté le 28-10-2012 à 07:32:14  profilanswer
C'est bien ce que je dis il n'y a pas de "System Smart fan  control" !!!!  :o
Je pensais aussi faire cette bidouille en alimentant le ventilo boîtier via l'alim du ventilo cpu  :)
n°8492415
burn2
ça rox du poney
Posté le 28-10-2012 à 09:57:32  profilanswer
ah oui je n'avais pas compris désolé.
n°8492447
raphdasout​h
Posté le 28-10-2012 à 10:29:56  profilanswer
 Pas de souci  :jap:
 L'adaptateur tu l'as bricolé toi-même ou tu l'as acheté?
n°8492460
burn2
ça rox du poney
Posté le 28-10-2012 à 10:49:44  profilanswer
je l'ai acheté, j'ai un doute s'il était fournit avec mon ventilo ou pas mais ça se trouve.
n°8498136
-Ebola-
Class 4
Posté le 02-11-2012 à 11:21:12  profilanswer
Hello
Petite question, qu'apporte le révision B3 ?
Waterchiller & Cascade by Learn|9800Pro-3DM05(110) WR:3676|6200-3DM03/05 WR:8753/WR:3946|X800 GTO²-3DM03/05/06 WR:16472/WR:8051/WR:2923
n°8498139
burn2
ça rox du poney
Posté le 02-11-2012 à 11:23:07  profilanswer
Aucune idée, elle était directement dans cette version là. Le support de certains processeurs? A voir sur le site de gigabyte si on trouve l'info.
EDIT: d'ailleurs je ne sais pas si je suis en bios F8. Bon vu que tout est ok j'hésites toujours à faire les maj sachant qu'il faut à nouveau tout rerégler dans le bios...
EDIT2: vu les infos je dois être en bios F7 visiblement si j'en crois ce topic. :D
Message édité par burn2 le 02-11-2012 à 11:27:00
n°8498143
burn2
ça rox du poney
Posté le 02-11-2012 à 11:28:36  profilanswer
Bon en fait, ce n'est pas la révision B3, vu le site il n'y a qu'une seule révision (1.0). B3 n'est pas la révision, c'est juste USB3 qui veut donc dire USB 3.0. :D
n°8498144
-Ebola-
Class 4
Posté le 02-11-2012 à 11:30:44  profilanswer
Ok, merci pour cettre précision extrèmement rapide, je pense en devenir possesseur sous peu et donnerai mon rex à ton topic ;)
n°8612572
yomyomsan
Posté le 06-02-2013 à 16:47:53  profilanswer
Que vaut le chipset graphique sur cette carte ?
ai je un interet à y mettre ma Sapphire Radeon HD 4650 ?
n°8612585
burn2
ça rox du poney
Posté le 06-02-2013 à 17:00:02  profilanswer
Il n'y a pas de "chipset graphique" sur cette carte.
Le chipset graphique, c'est le cpu qui l'intègre. Donc les performances seront celles du cpu.
Donc après à toi de voir les tests, mais je pense qu'en 3D il n'y a pas photo sur le fait qu'une 4650 soit plus performante. Pour la 2D/Vidéo l'igp doit être suffisant.
n°8637225
rob60
Posté le 25-02-2013 à 19:51:17  profilanswer
Pour ce qui est de la RAM DDR3 elle est donnée comme "dual channel". La carte-mère peux-t-elle fonctionner en single avec une seule barette ?
Message édité par rob60 le 25-02-2013 à 23:31:11
n°8652525
lepiaf37
Posté le 10-03-2013 à 00:28:25  profilanswer
n°8950079
Elven Rinq​uest
Posté le 25-11-2013 à 16:45:59  profilanswer
Bonjour à tous ;
Pensez--vous que cette carte réseau sans fil : Gigabyte GC-WB300D passerait sur le port PCI Express ?
C'est du mini PCI Express.
Merci d'avance
Elven
n°9141679
SnowBear
Posté le 06-05-2014 à 20:52:24  profilanswer
Bonsoir tout le monde,
J'hésite à acheter cette carte mère.
Je me pose une petite question :
- à quoi sert le connecteur interne noir situé au dessus des 2 ports SATA ?
 Page :   1  2
Page Précédente
Radeon HD5850 sur Gigabyte GA-M68MT-S2 : non reconnuecomment connaitre la revision d'une P8P67?
quelle carte mere 1155 z68 ? (usb3 )[RECH] photo/vidéo GTX580 gigabyte avec windforce
[HFR] Actu : Gigabyte GA-X79S-UD5, LGA 2011 avec C606[HFR] Actu : Z77 Express : 10 cartes pour Gigabyte aussi
Gigabyte H67N-USB3-B3 boot en boucle
Plus de sujets relatifs à : [Topic Unique] Gigabyte GA-H61N-USB3 : mini-ITX
