2457 connectés
  [Topic] DFI Infinity NF Ultra II-M2
n°5155851
zit11
Posté le 09-11-2006 à 10:49:27  profilanswer
Salut à tous,
Cette DFI est a un chipset NVIDIA nForce4 Ultra mais modifié pour pouvoir accueillir de la DDR2voici ces spécifications:
Spécifications:
CPU
 AMD Athlon 64 X2 / Athlon 64 FX / Athlon 64 / Sempron Socket AM2
HyperTransport
 2000MT/s HyperTransport interface
  Chipset
  System Memory
 Four 240-pin DDR2 DIMM sockets
 Supports DDR2 533 and DDR2 667 DIMMs elle accepte aussi de la ddr800/1000/1200...
 Supports dual channel (128-bit wide) memory interface
 Supports up to 4GB system memory
  Expansion Slots
 2 PCI Express x16 slots - PCIE1 slot operates at x16 or x8 bandwidth. - PCIE3 slot operates at x2.
 1 PCI Express x1 slot
 3 PCI slots
  BIOS
 Award BIOS
 CPU/DRAM overclocking
 CPU/DRAM/Chipset overvoltage
 4Mbit flash memory
http://lp.pcmoddingmy.com/albums/userpics/DFI/NFUltraII-M2/bios.jpg
  Power Management
 ACPI STR (Suspend to RAM) function
 Wake-On-PS/2 Keyboard/Mouse
 Wake-On-USB Keyboard/Mouse
 Wake-On-LAN
 Wake-On-Ring
 RTC timer to power-on the system
  Hardware Monitor
 Monitors CPU/system/chipset temperature
 Monitors 12V/5V/3.3V/Vcore/Vbat/5Vsb/Vdimm/Vchip voltages
 Monitors the speed of the cooling fans
 CPU Overheat Protection function monitors CPU temperature during system boot-up
  Audio
Realtek ALC850 8-channel AC’97 audio CODEC
 S/PDIF-in/out interface
  LAN
 Marvell 88E1115 Gigabit LAN
 Fully compliant to IEEE 802.3 (10BASE-T), 802.3u (100BASE-TX) and 802.3ab (1000BASE-T) standards
  IDE
 Supports two IDE connectors that allow connecting up to four UltraDMA 133Mbps hard drives
 NVIDIA RAID allows RAID arrays spanning across Serial ATA and Parallel ATA
 RAID 0, RAID 1, RAID 0+1 and JBOD
  Serial ATA with RAID
 Four Serial ATA ports
 SATA speed up to 3Gb/s
  IEEE 1394
 VIA VT6307
 Supports two 100/200/400 Mb/sec ports
  Rear Panel I/O
 1 mini-DIN-6 PS/2 mouse port
 1 mini-DIN-6 PS/2 keyboard port
 1 optical S/PDIF-out
 1 RCA S/PDIF-out
 1 parallel port
 1 COM port
 1 IEEE 1394 port
 1 RJ45 LAN port
 4 USB 2.0/1.1 ports
 Center/subwoofer, rear R/L and side R/L jacks
 Line-in, line-out (front R/L) and mic-in jacks
  Internal I/O
 3 connectors for 6 additional external USB 2.0/1.1 ports
 1 connector for 1 external IEEE 1394 port
 1 front audio connector for external line-out and mic-in jacks
 1 CD-in internal audio connector
 1 S/PDIF connector for optical cable connection
 1 IrDA connector
 4 Serial ATA connectors
 2 IDE connectors
 1 90 floppy connector
 1 24-pin ATX power connector
 1 4-pin ATX 12V power connector
 1 4-pin 5V/12V power connector (FDD type)
 1 front panel connector
 5 fan connectors
 EZ touch switches (power switch and reset switch)
  PCB
 ATX form factor
 24cm (9.45" ) x 30.5cm (12" )
http://fr.dfi.com.tw/Product/xx_pr [...] TY&SITE=FR
Une tite photo:
http://img220.imageshack.us/img220/7483/infultraiivd9.th.jpg
Bios
http://fr.dfi.com.tw/Support/Downl [...] =A&SITE=FR
Pilotes
Remarques
je l'ai depuis 2 jours, je n'ai pas réussi à faire fonctionner le chipset du son,j'ai installer un carte son externe,je suis toujours entrain de chercher d'où sa peut venir.
Le ventilo du chipset est assez bruyant,dans le bios on peut le régler,je l'ai mi sur 60% et c'est un peu mieux et sa n'affecte pas trop les températures.
J'ai réussi à monter la fréquence de mon X2 3800+ à 4200+,avec la ram en ddr 735 avec ces timings 4.4.4.15.19 CR2,je n'ai pas changer le voltage,j'ai mi le coeff HTT à 3x,c'est stable,8 heures sous OCCT;mais je vais pas en rester là  :D
Je vais bientot mettre à jour le bios,je vous dirai si le probleme du son est résolu
Tests
http://www.pcmoddingmy.com/e107_pl [...] tent.377.1 (en anglais)
Ils expliquent dans ce test qu'il est possible de faire fonctionner cette carte en sli
Forum officiel : http://www.dfi-street.com/forum/sh [...] 794&page=1
voilou,mon premier topic, si manque des choses faites moi signe ;)
Message édité par zit11 le 09-11-2006 à 16:40:49
Je suis pas Superman, je suis Super-vagabond, mais toi t’es Super-pomme. Tu es très gouteuse, tu es très... biologique, très naturelle ! Tu es la pomme de ma vie.
n°5156106
4lex67
Posté le 09-11-2006 à 13:03:26  profilanswer
C'est la carte mère que je veux acheter pour remplacer ma msi K9N neo-f la je vais voir pour la renvoyer en garantie et me fair rembourser pour o/c mon petit x23800+ qui est @2420Mhz actuellement.
n°5156222
kashu
Posté le 09-11-2006 à 13:50:26  profilanswer
J'aurai la mienne demain :)
Quelqu'un sait si il y a une différence entre la INFINITY NF ULTRAII-M2 et la INFINITY NF ULTRAII-M2/G ?
edit : il me semble que les drivers son sont pas intégrés dans les drivers système fournis par DFI. Si tu prends les drivers génériques nforce 4 nvidia, il y a les drivers audio. Peut être que le problème vient de là.
Message édité par kashu le 09-11-2006 à 13:52:07
n°5156270
zit11
Posté le 09-11-2006 à 14:13:52  profilanswer
yes merci kashu,vé essayer pour les drivers audio,
4lex67,j'avais une msi k9n platinum avant,elle etait pas du tout stable,mon ordi rebootait quand je gravais un cd,je sais po si sa te fais ça...
Dans le test en anglais,cette carte permet de faire du SLI, il sufit de bien suivre leur recommandation et sa marche impec,c'est aussi performant qu une vrai carte mere SLi
[Résolu] DFI Lanparty NF-4 Ultra-D, plus de bios :(k7sbx ou 745 ultra
[DFI] Lanparty NF4 Ultra-D Mod SLIConseil achat Alim et Ventilo proc avec DFI Infinity et Antec P180
K8NF-9 ULTRA morte cherche remplaçante tenant la route cette foisProbleme de boot et DFI AD77
K8NF9- Ultra insuffisante. Laquelle en remplacement?Problèmes d'installation de jeux
GeForce 7500 LE plus pourri qu'une GeForce 6800 ultra ?
Plus de sujets relatifs à : [Topic] DFI Infinity NF Ultra II-M2
