1031 connectés
  INTEL DG45FC Flying Creek Socket 775 G45 Mini-Itx
 Page :   1  2  3  4  5
Page Précédente
n°6434964
trucrun
Posté le 16-06-2008 à 17:38:35  profilanswer
http://www.aubonmicro.com/Visuels/Photos/P_BOXDG45FC.jpg
LA PUISSANCE MINI ITX A MOINDRE COUT
Features and benefits
Form factor
Mini-ITX (6.70 inches by 6.70 inches [171.45 millimeters by 171.45 millimeters])
Processor
Click view supported processors for the most current list of compatible processors.
At product launch, this desktop board supports:
    * Support for an Intel® Core™2 Duo processor in an LGA775 socket
    * Support for an Intel® Pentium® Dual-Core processor in an LGA775 socket
    * Support for an Intel® Celeron® Dual-Core processor in an LGA775 socket
    * Support for an Intel® Celeron® processor 400 sequence in an LGA775 socket
Memory
    * Two 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets
    * Support for DDR2 800/667/533 MHz DIMMs
    * Support for up to 4 GB of system memory
Chipset
    * Intel® G45 Express Chipset
Audio
Intel® High Definition Audio subsystem in the following configuration:
    * 8-channel (7.1) audio subsystem with five analog audio outputs and one optical S/PDIF digital audio output using the IDT 92HD73E audio codec
Video
Intel® Graphics Media Accelerator X4500HD onboard graphics subsystem with integrated HDMI + DVI-I display ports
LAN support
Gigabit (10/100/1000 Mbits/sec) LAN subsystem using the Intel® 82567LF Gigabit Ethernet Controller
Peripheral interfaces
    * One serial port via header
    * Up to 10 USB 2.0 ports (6 back ports and 4 via headers)
    * 5 Serial ATA 3.0 Gb/s ports, including 1 eSATA back port with RAID 0, 1, 5, 10 support
    * Consumer IR receiver and emitter (via internal)
Expansion capabilities
One PCI Express* x1 bus add-in card connectors
Related products
Processors
    * Intel® Core™2 Duo processor
    * Intel® Pentium® Dual-Core processor
    * Intel® Celeron® Dual-Core processor
    * Intel® Celeron® processor 400 sequence
Chipsets
A VOS TEST !
n°6448441
docteur_ma​rc
Posté le 21-06-2008 à 16:45:05  profilanswer
bientôt disponible LA
Message édité par docteur_marc le 07-07-2008 à 11:22:31
n°6448448
pvhk
lord Vader
Posté le 21-06-2008 à 16:48:06  profilanswer
c'est du matx et en plus chipset DG31.... rien à voir
Topic unique-monter un PC matx à base de C2D: petit mais costaud
n°6543716
docteur_ma​rc
Posté le 15-08-2008 à 23:53:22  profilanswer
n°6543782
Posté le 16-08-2008 à 00:37:34  answer
La mienne est en chemin depuis hier.  :)
(En Allemagne elle est bcq moins cher, je l'ai eu à 98.70€)
Néanmoins les premiers tests sont mitigés. Le décodage hardware HD fonctionne, mais la qualité est pourrie d'après les bench de qualité video HD elle n'obtient que 30%, alors qu'AMD et Nvidia sont à 100% depuis longtemps. Le point fort actuelle c'est sa consommation.
PS: Si ce topic est destiné à devenir un topic unique il vaudrait mieux rajouter du contenu au premier post, et pas seulement le copier coller des spec en anglais.  :sarcastic:
Message édité par Profil supprimé le 16-08-2008 à 01:03:59
n°6544877
Posté le 16-08-2008 à 21:57:13  answer
Cette carte possède un petit détail intéressant, il gère les récepteur IR, en gros il ne faut qu'une diode+ quelques résistance. C'est donc parfait pour le mod où la place est limité (mon cas) et dont l'utilisation d'un récepteur IR USB n'est pas appréciable.
Par contre je n'ai pas réussi à trouvé le circuit schéma pour concevoir ce recepteur.
Vous avez une idée?
Autre question.
La majorité des carte-mère P45 qui dispose aussi d'un ICH10R ont presque toute un ard sur le Southbridge, Intel non.
L'ICH10R chauffe-t-il ou pas???
Message édité par Profil supprimé le 17-08-2008 à 16:59:03
n°6549075
Badtz_maru
ID PSN : badtz76
Posté le 19-08-2008 à 11:24:27  profilanswer
Salut.
Tu l'as acheté sur quel site stp ?
Merci.
n°6549592
Posté le 19-08-2008 à 16:17:58  answer
Badtz_maru a écrit :
Salut.
Merci.
Hello
En allemagne, en l'occurence ICI:
(les prix ont augmentés depuis, notons que le nom n'est pas correct dans le titre mais c'est bien la bonne carte).
http://geizhals.at/eu/?cat=mb1ppga_ddr&asuch=g45
Bon alors je viens de monter ma carte. Constat:
1. Belle carte et belle boite.
2. Elle consomme autant que mon G33, je suis à 70W durant l'install de Windows avec un E7200, duex Green Power en Raid 1 et une carte réseau uniquement.
3. Pas moyen de toucher au tension dans le bios.
4. Notons également que les prises ventilo sont très mal placés, je n'a pas pu y brancher mes ventilo par la suite.
Quelque photos, d'autres vont suivre si j'ai le temps.
http://img520.imageshack.us/img520/5812/img2693kr3.th.jpghttp://img401.imageshack.us/img401/6654/img2696hn8.th.jpghttp://img520.imageshack.us/img520/5135/img2699fv4.th.jpghttp://img399.imageshack.us/img399/2739/img2700gz9.th.jpg
Message édité par Profil supprimé le 23-08-2008 à 12:58:14
n°6549611
Badtz_maru
ID PSN : badtz76
Posté le 19-08-2008 à 16:29:34  profilanswer
ok, merci :jap:
n°6557029
lobby
ZizouSquad Officer
Posté le 23-08-2008 à 12:23:31  profilanswer
je suis intéressé par cette carte également.
de quelle type d'alimentation elle a besoin ? et quelle puissance ?
Merci pour vos réponses  :)
n°6557098
Posté le 23-08-2008 à 12:57:17  answer
Ben écoute c'est une MiniItx mais ca consomme tout autant qu'une ATX, normal sur le fond.
Donc l'alimentation est à calculer en fonction de ce que tu branchera dessus.
n°6557101
docteur_ma​rc
Posté le 23-08-2008 à 12:59:56  profilanswer
cette carte intel DG45FC ( qui est d'ailleurs dispo en france )
contrairement a la plupart des carte itx
cette carte mère  doit utiliser  une alimentation avec  un connecteur atx 12 V 4 broche
donc une alimentation standard
sinon  il lui faut CE Kit et trouver un connecteur ATX12V
Message édité par docteur_marc le 23-08-2008 à 13:01:05
n°6557408
Posté le 23-08-2008 à 16:45:13  answer
Faux, toutes les cartes MiniITX à base d'Intel ou Athlon en disposent. (Même les Celeron et Atom...)
Cette alim est largement insuffisante, je peux t'assurer que s'il l'utilise elle cramera même avant d'arriver au boot...
EDIT:
Moi j'ai l'impression que tu bosses pour aubonmicro  :heink:   :sarcastic: , t'arrives à caser 3 fois le lien vers ce magasin en 2 postes.
Message édité par Profil supprimé le 23-08-2008 à 20:43:24
n°6558915
Badtz_maru
ID PSN : badtz76
Posté le 24-08-2008 à 18:26:18  profilanswer
Tu es sur de toi ? Parce que je viens de commander la carte avec un boitier Icaricio IC-ITX100P et je pense que je vais avoir cet alim avec ....
n°6558951
Posté le 24-08-2008 à 18:47:11  answer
Sur à 100%.
Ces alim indique 80W, mais 80W pic combiner sur toutes les tensions. Au démarrage la consommation monte allègrement au dessus de 80W avec un simple E7200 qui est le cpu le plus économe pour cette platforme.
En plus cette alim n'a même pas de connecteur 4pin pour le cpu, la carte-mère va même pas démarrer...
Message édité par Profil supprimé le 24-08-2008 à 18:49:07
n°6558963
Posté le 24-08-2008 à 18:51:57  answer
Le fait est que les gens pense que c'est parce que c'est une miniITXque ca consomme peu, ben non ca consomme tout autant que les ATX, si le constructeur ne fait pas d'effort sur els composants (autre que chipset).
n°6558974
Badtz_maru
ID PSN : badtz76
Posté le 24-08-2008 à 18:58:06  profilanswer
ok, bon ah j'ai plus qu'a annuler ma commande ...
Merci :jap:
n°6559739
lobby
ZizouSquad Officer
Posté le 25-08-2008 à 10:34:51  profilanswer
si je résume bien. il lui faut une alim ATX classique, avec le meme connecteur que pour les Pentium 4 (4 broches + le classique 10 ou 12 broches)
si c'est bien ca, le côté "mini pc en prend un coup dans la tronche :D
n°6559741
lobby
ZizouSquad Officer
Posté le 25-08-2008 à 10:36:29  profilanswer
as tu les liens de ces tests stp ?
n°6559743
Badtz_maru
ID PSN : badtz76
Posté le 25-08-2008 à 10:37:13  profilanswer
J'ai trouvé le morex venus 669 qui a l'air pas mal comme boîtier, je crois que je vais partir la dessus ...
Message édité par Badtz_maru le 25-08-2008 à 10:44:02
n°6564258
tugs
m'enfin ?!!
Posté le 27-08-2008 à 14:37:11  profilanswer
hello all , on s'incruste on était sur le topic d'a coté :p
Retrogamer
n°6564262
tugs
m'enfin ?!!
Posté le 27-08-2008 à 14:38:26  profilanswer
Est ce que quelqu'un a testé un rad avec cette carte ? je compte l'intégrer dans un Morex 3777 :)
Retrogamer
n°6564400
azubal
Posté le 27-08-2008 à 15:43:38  profilanswer
Bonjour tout le monde.
Je suis très intéressé par cette Mini ITX pour me faire un HTPC.
J'avais repéré deux boitiers (à refroidissement passif) me plaisant le HFX(R) micro et le HeatSync(R) 2500 Mini-Client.
Malheureusement après un échange de mails avec HFX, cette carte ne rentrera pas dans ce boitier a cause de l'emplacement de son connecteur d'alim :
unfortunately this mainboard cannot be used in any of our HFX micro cases (neither in M1 nor in M2).the ATX 24 pin power Plug is placed at the far end of the mainboard and therefore you cannot use a pico PSU because the Pico PSu will be too high and will be on the way of the DVD drive cage.
J'attends la réponse concernant le boitier HeatSync (pour lequel j'ai une petite préférence).
Reste la question de l'alim :
Une Pico PSU DC/DC 120watt avec le transfo 220/12v 120watt serait il suffisant ?!
D'après ce topic http://www.car-pc.info/reviews/intel-dg45fc-review la carte ne dépasserai pas les 70Watt (avec un E8500).
J'aimerai savoir quelles sont vos configs/alim/boitiers ?
Message édité par azubal le 27-08-2008 à 16:04:24
n°6564459
Badtz_maru
ID PSN : badtz76
Posté le 27-08-2008 à 16:06:58  profilanswer
Tu es sur que les core 2 duo peuvent être refroidis passivement sans soucis ???
n°6564471
Posté le 27-08-2008 à 16:15:20  answer
1. Perso même en débranchant tout et en ne laissant que 2Go de Ram, le CPU E7200, je dépasse déjà les 70W en full et je ne suis pas loins des 80W, et qu'en on sait qu'un E8500 ca consomme 10W de plus en charge qu'un E7200 le calcule est vite fait. De même pour l'idle ou je suis loin des 38W... Bref pour moi ces valeurs données dans ce test sont fausses (notons aussi que ce test est fait par un magasin en ligne, ce qui peut expliquer le fait qu'ils aient trafiqué les chiffres....)
2. Passif? Oui c'est possible, le mien est en passif sur un Gemin II, néanmoins il faut absolument un ventilateur à proximité sur le boitier, d'une par pour le rad cpu mais aussi pour le NB et SB, qui chauffe énormément s'il n'y a pas de léger souffle d'air à proximité.
Message édité par Profil supprimé le 27-08-2008 à 16:17:13
n°6564473
Pere_U
Posté le 27-08-2008 à 16:15:48  profilanswer
Salut!
Exist-il une carte comme celle la mais avec un port PCI-E?
n°6564476
Posté le 27-08-2008 à 16:17:53  answer
Pere_U a écrit :
Salut!
Elle a un connecteur PCI-e...  :pt1cable:
Message édité par Profil supprimé le 27-08-2008 à 16:18:19
n°6564489
azubal
Posté le 27-08-2008 à 16:25:09  profilanswer
@soa:
Oui j'ai vu ton post sur le forum US. Tu dis être a 80W en charge et un peut moins en idle. Quand tu dis "en débranchant tout" ? c'est a dire ? Une Pico PSU de 120W devrait quand même suffire non ?
Pour le refroidissement, l'intérêt du HeatSync, c'est que le boitier lui même sert de radiateur (d'ailleurs il ressemble à un gros radiateur :D). Dans mon cas il sera dans un meuble TV avec un espace assez restreint :/
Je ne comprends pas pourquoi Intel n'a pas fait cette mini ITX avec un socket P.
Pour les températures, c'est si grave que ca si ca chauffe ? (60/65 degrés) ? J'ai eu des CPU plus chaud que ça sans jamais avoir eu de soucis.
@Pere_U : cette carte à un port PCI-E (1x :D). Mais sinon, il n'existe pas d'autre Mini ITX a base de G45.
Edit: grilled par soa.
Message édité par azubal le 27-08-2008 à 16:25:45
n°6564499
Posté le 27-08-2008 à 16:31:47  answer
azubal a écrit :
@soa:
Même en débranchant les disque dure (des WD Green Power économe), en désactivant la puce son, les ports série je suis a peu près à 80W en full.
Pour le Pico PSU faut voir. Perso j'ai déjà eu des alim (MCubed) qui était certifié 120W, mais le problème c'est que le bloc alim externe lui n'était certifié que pour max 90W, du coup sur mon ancienne config (pas la miniITX) ca a fait boum au démarrage...
Bref sur ce point je sais pas te dire, j'ai pas de Pico PSU, mais je déconseillerait car elle serait fortement sollicité, sa longévité et fiabilité va en prendre un coup.
Si il y a MSI qui a annoncé une carte-mère MiniItx à base de G45 + Socket P.
Néanmoins si c'est pour un usage HTPC + décodage HD je te déconseille la carte, la qualité de la décompression HD est mauvaise. (T'as du le lire sur le forum US.)
Message édité par Profil supprimé le 27-08-2008 à 16:37:31
n°6564516
azubal
Posté le 27-08-2008 à 16:40:05  profilanswer
Que reste t il d'autre alors en Alim externe qui irait ?
Je vais regarder cette carte mere...
J'ai vu que le chipset ne donnait pas de supers résultats mais je me dis qu'intel corrigera ça avec des drivers moins degueu, que ma TV devrait etre capable de rattraper le truc (Philips 42PFL9703H).
Et de toute manière, que reste il comme solutions (compact) à base de CPU intel capable de décoder hardwarement de la HD ?! :/
Tien petite questions, a tu essayé la carte en HDMI ? Si oui, est ce que tu a bien le transport du son avec l'HDMI ?
n°6564553
Pere_U
Posté le 27-08-2008 à 16:59:06  profilanswer
Donc pour le moment pas de PCI-e x16?
Et dans le futur?
n°6564615
Posté le 27-08-2008 à 17:29:39  answer
Pourquoi tu veux absolument un port 16x?
n°6564634
fndo
Posté le 27-08-2008 à 17:40:34  profilanswer
Et dans le futur?
 :hello: salut,
voilà le futur mini-itx 2.0 avec ton port 16x.
...enfin, c' est pas encore dans les bacs.
Super site à mettre dans tes favoris... jette un oeil sur les boîtiers home-made, c' est pas mal....
Message édité par fndo le 27-08-2008 à 18:00:13
n°6565064
azubal
Posté le 27-08-2008 à 20:46:02  profilanswer
@soa : je ne trouve aucune trace de ta MSI ?! à tu un lien à me donner
Edit: ah bah je viens de trouver (en plus on avait deja discuté autour de la news sur homemedia.fr)
Message édité par azubal le 27-08-2008 à 22:26:19
n°6571840
alb_22fr
Posté le 31-08-2008 à 20:11:21  profilanswer
Hello all,
Une question...
Pourquoi vous parlez d'une conso de 80w en charge pour le E7200...alors que les tests parlent de 22w en charge ??
http://www.hardware.fr/articles/71 [...] e7200.html
Même en ajoutant, un dd 2,5", un graveur DVD..ça monte pas très haut...
Dans ce cas, une alim de 80w (même en pointe) est suffisante ? non ?
Merci d'avance...
n°6571889
Posté le 31-08-2008 à 20:42:15  answer
Relie le test...
C'est 22W en charge que pour le CPU... t'oublies la carte-mère.
Un disque dure ne fait que peu de différence.
n°6571955
alb_22fr
Posté le 31-08-2008 à 21:16:49  profilanswer
Ok merci ;-), apparement sur un forum, certain font tourner la config que je suis en train de monter avec une alim 80w.
- DG45fc
- E7200
- 2 x 1go ddr2
- graveur DVD
Je vais tester et je mettrai ici les résultats.
Message édité par alb_22fr le 31-08-2008 à 21:17:05
n°6571992
Posté le 31-08-2008 à 21:29:09  answer
N'oublie pas une chose.
Une alim qui tourne à plus de 80% de ses capacités et régulièrement à 100% ne tiendra pas longtemps. Pire une alim qui claque a la facheuse tendance à ne vouloir franchir le mur seule et entraîne certain composant avec...
Et si le cas d'utilisation de cette alim ne fût que pour un test, ben il est évident que ce faible temps écoulé n'est pas du tout représentatif de ce que l'alim devra endurer...
n°6572033
alb_22fr
Posté le 31-08-2008 à 21:48:03  profilanswer
Ouaip c'est pas faux...
merci pour la remarque, je vais quand même essayer d'en trouver une 120w, surement plus prudent.
n°6572042
azubal
Posté le 31-08-2008 à 21:51:41  profilanswer
Pour ma part, je suis revenu en arrière sur l'achat de l'aopen MP45-DR
 Page :   1  2  3  4  5
Page Précédente
mini pc HDChoix de CG : Upgrader ma config en shader 3.0
Config pour mini-PCproc quel socket ?
Saccades dans les jeux ATI HD3850 Intel E6600 2Go DDR2 sous Vista SP1Recherche mini PC fanless
Hésite entre le mini p 180, lancool K7 et autresConfig Shuttle - AMD ou Intel ?
carte mere socket 775 pour extreme overcloking?
Plus de sujets relatifs à : INTEL DG45FC Flying Creek Socket 775 G45 Mini-Itx
