755 connectés
  Processeur
  ☑ Problème d'instructions CPU (SSSE3) sur Althon II
n°9870581
Swiss_Knig​ht
600 MeV since 1957.
Posté le 06-07-2016 à 17:18:32  profilanswer
j'ai un soft qui me pose une colle avec mon Athlon II X4 :
Fatal Error: This program was not built to run on the processor in your system.
The allowed processors are: Intel(R) Core(TM) Duo processors and compatible Intel processors with supplemental Streaming SIMD Extensions 3 (SSSE3) instruction support.
Y a-t-il une solution (autre que celle de changer de config, ce qui n'est pas possible pour l'instant) ?
Merci :jap:
Info complémentaires :
$ sudo dmidecode -t 4
# dmidecode 3.0
Getting SMBIOS data from sysfs.
SMBIOS 2.6 present.
Handle 0x0004, DMI type 4, 42 bytes
Processor Information
 Socket Designation: AM3
 Type: Central Processor
 Family: Athlon II
 Manufacturer: AMD
 ID: 53 0F 10 00 FE FB 8B 16
 Signature: Family 16, Model 5, Stepping 3
 Flags:
  FPU (Floating-point unit on-chip)
  VME (Virtual mode extension)
  DE (Debugging extension)
  PSE (Page size extension)
  TSC (Time stamp counter)
  MSR (Model specific registers)
  PAE (Physical address extension)
  MCE (Machine check exception)
  CX8 (CMPXCHG8 instruction supported)
  APIC (On-chip APIC hardware supported)
  SEP (Fast system call)
  MTRR (Memory type range registers)
  PGE (Page global enable)
  MCA (Machine check architecture)
  CMOV (Conditional move instruction supported)
  PAT (Page attribute table)
  PSE-36 (36-bit page size extension)
  CLFSH (CLFLUSH instruction supported)
  MMX (MMX technology supported)
  FXSR (FXSAVE and FXSTOR instructions supported)
  SSE (Streaming SIMD extensions)
  SSE2 (Streaming SIMD extensions 2)
  HTT (Multi-threading)
 Version: AMD Athlon(tm) II X4 640 Processor
 Voltage: 1.4 V
 External Clock: 200 MHz
 Max Speed: 3000 MHz
 Current Speed: 3000 MHz
 Status: Populated, Enabled
 Upgrade: Socket AM3
 L1 Cache Handle: 0x0005
 L2 Cache Handle: 0x0006
 L3 Cache Handle: 0x0007
 Serial Number: To Be Filled By O.E.M.
 Asset Tag: To Be Filled By O.E.M.
 Part Number: To Be Filled By O.E.M.
 Core Count: 4
 Core Enabled: 4
 Thread Count: 4
 Characteristics:
  64-bit capable
Apparemment je suis grillé là... fait ch***r... :/
Message édité par Swiss_Knight le 07-07-2016 à 00:35:48
Hergestellt in der Schweiz.
n°9870614
bruce-will​is
Posté le 06-07-2016 à 17:40:16  profilanswer
Je pense pas qu'il existe une émulation SSSE3 donc t'as pas trop le choix, faut sortir la CB.
Tu peux toujours essayer de chopper un coeur 775 avec un core 2 Duo/Quad d'occaz pour une 40aine d'euros.
n°9871033
atreides59
Posté le 06-07-2016 à 23:00:01  profilanswer
L'athlon 2 x4 a les instructions SSE3.
Que dit cpu-z ?
n°9871036
Andorria
Posté le 06-07-2016 à 23:00:49  profilanswer
Que dit cpu-z ?
Attention, il y SSE3 et SSSE3  ;)
http://img15.hostingpics.net/thumbs/mini_553325Capture.png
Message édité par Andorria le 06-07-2016 à 23:03:35
n°9871045
atreides59
Posté le 06-07-2016 à 23:06:37  profilanswer
Ah oui c'est vrai, merci pour la correction :jap:
C'est parce que son log ne mentionne pas le sse3 alors j'ai pensé que... :pt1cable:
Message édité par atreides59 le 06-07-2016 à 23:07:24
  Processeur
Probleme lancement sli gtx 1080Refroidissement CPU
ASUS sabertooth z170 mark 1 TUF detective problème[Problème au démarrage] A l'allumage, mon PC s'éteint
Problème de son avec une carte son Asus Essence STX IIProblème Affichage, Carte Graphique?
Problème écran tactile tabletteBonne config mais FPS faible... Problème insoluble !
Plus de sujets relatifs à : ☑ Problème d'instructions CPU (SSSE3) sur Althon II
