973 connectés
  topic des ventilos 70mm 70 mm ventilateur fan silent
n°7325615
whyjuan
HATE ETERNAL
Posté le 12-02-2010 à 11:05:06  profilanswer
D'apres ce que je vois les ventilos de 70*70 ne sont pas super courant
Ventilateur 070 mm - 016 CFM - 25 dBA - PAPST 712F/2L
http://www.pc-look.com/boutik/Prod [...] 55_fr.html
mais bon, ils font 15mm et pas 25mm...
Taille : 70 mm x 70 mm x 15 mm
Débit d'Air : 16.5 CFM
Vitesse de rotation : 3300 tr/min (RPM)
Emissions Sonores : 25 dB(A) SEULEMENT !!!
Consommation : 0.6 Watt (0.05 A)
Tension de démarrage : 8V
Remontée de la vitesse de rotation : Oui
Modèle : 712F/2L
sinon il y a un EVERCOOL
Evercool Fan 70x70x25 EL Bearing (3400 RPM
http://www.dekada.com/catalog/fan- [...] p-353.html
Dimensions:     70 x 70 x 25mm
Rated Fan Speed:     3400 RPM
Air Flow:     34.78 CFM
Noise Level:     <28 dBA
Power Consumption:     12 V, 0.19 Amp.
Watt:     2.28
Bearing:     EL Bearing
Connector     3 Pin Molex
Life /Hours/:     40000
un NEXUS
Nexus 70mm Real Silent Case Fan with 3-pin Motherboard Connector
Dimensions  70 x 70 x 25 mm
http://www.endpcnoise.com/cgi-bin/ [...] m_case_fan
Weight  85 grams
Oper. Voltage  10.2-13.8 Volts
Input Current  0.33 Amp
Input Power  3.96 Watts Max
Rotation Speed  2400 RPM
Acoustic Noise  19.8 dB(A)
Airflow  21.1 CFM
Warranty  3 years
n°7325617
whyjuan
HATE ETERNAL
Posté le 12-02-2010 à 11:06:37  profilanswer
et un Acousti Products Dust Proof 70mm Quiet Computer Fan
Fan Start at 5V DC? Yes
Connector Type 3-pin (from m'board), OR 4-pin (from PSU)
using 3-Speed Fan Cable
Life Expectancy (at 25°C) 60,000hrs (6.85yrs)
Included Accessories 3-Speed Fan Cable, 4 x Tie Wraps & 4 x Screws
Full Speed (12VDC)
Air Volume Throughput CFM ±10% 21.9
Acoustic Performance (DIN45635 @1m) dBA 20.0
Fan Speed RPM** ±10% 2,500
Medium Speed (approx. 7.5VDC)
Air Volume Throughput CFM ±10% 14.0
Acoustic Performance (DIN45635 @1m) dBA 10.5
Fan Speed RPM** ±10% 1,750
Low Speed (5VDC)
Air Volume Throughput CFM ±10% 9.1
Fan Speed RPM** ±10% 1,150
http://www.acousticpc.com/acoustip [...] f_fan.html
ou la
http://www.acoustiproducts.com/en/ [...] tproof.asp
ce dernier me semble etre le mieux
n°7325706
whyjuan
HATE ETERNAL
Posté le 12-02-2010 à 12:23:40  profilanswer
pour ceux qui veulent ce dernier ventilo faut commander la
http://www.svc.com/
sur tous les autres sites c'est en rupture
ou sinon y a 80 usd de frais de ports..
n°7325728
dduckof62
C'est mieux qu'si c'était pire
Posté le 12-02-2010 à 12:41:33  profilanswer
çà fait bien cher je trouve.
Feed Ventes
n°7713703
GIlGil
Posté le 23-12-2010 à 00:22:57  profilanswer
Remplacer le ventilateur d'une alimentation ?erreur:le ventilateur du système est défectueux
ventilateur 60mm 60 mm ventilos silencieux silence dbVentilateur de PC Portable HS
ventilateur processeur Pentiul IVAide : Fixation ventilateur processeur
Bon ventilateur pour GA-EP35C-DS3Rbranchement ventilateur boitier
Plus de sujets relatifs à : topic des ventilos 70mm 70 mm ventilateur fan silent
Hit-Parade
