Bonjour tout le monde alors j'explique j'ai un probleme de son je ne sais pas si ca vient de la carte son ou si c'est plutot software! Donc mon problee c'est que le son est pourri des parasites qui s'accentuent quand l'ordi est fatigué!
A l'aide!
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.100427-1636)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 09/13/07 11:13:56 Ver: 08.00.12
Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 4400+, MMX, 3DNow (2 CPUs), ~2.3GHz
Memory: 2048MB RAM
Page File: 748MB used, 3191MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.5512 32bit Unicode
Sound Devices
Description: SoundMAX HD Audio
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_11D4&DEV_1988&SUBSYS_10438241&REV_1004
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: ADIHdAud.sys
Driver Version: 5.10.0001.6110 (English)
Driver Attributes: Final Retail
WHQL Logo'd: Yes
Date and Size: 1/16/2007 03:09:06, 293888 bytes
Other Files:
Driver Provider: AnalogDevices
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 100, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): Yes
Registry: OK
Sound Test Result: The tests were cancelled before completing.
Message édité par salafi38 le 15-10-2010 à 16:29:40
