885 connectés
  probleme copie de dvd
n°5001323
jeje2006
Posté le 20-08-2006 à 18:15:14  profilanswer
salut.
j'ai un probleme pour fait une copie de dvd
j'ai un pc lifetec airxl
j'utilise dvdshrink_3.2.0.16 et Nero.v6.6.1.4
lorsque je lance dvd shrink il encode le dvd
puis a la fin de l'encodage au momment de la gravure il affiche
ERREUR DE GRAVURE
"error:\ncannot connect trf
1A23-0809-9130-2375-9529-1341
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 02/11/2004 12:54:32
NT-SPTI used
Nero API version: 6.6.1.4
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 1, 4d
Recorder:             <PIONEER DVD RW  DVR-108> Version: 1.14 - HA 1 TA 0 - 6.6.1.4
 Adapter driver:      <IDE>                     HA 1
 Drive buffer  :      2000kB
 Bus Type      :      default (0) -> ATAPI, detected: ?
=== Scsi-Device-Map ===
CdRomPeripheral      : PIONEER DVD RW  DVR-108          atapi Port 0 ID 0  DMA: On
CdRomPeripheral      : IDE DVD-ROM 16X                  atapi Port 0 ID 1  DMA: On
DiskPeripheral       : WDC WD2500JD-00HBB0              atapi Port 1 ID 0  DMA: On
=== CDRom-Device-Map ===
PIONEER DVD RW  DVR-108    I:   CDRom0
IDE DVD-ROM 16X            J:   CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE           : 0
Physical memory     : 511MB (523756kB)
Free physical memory: 198MB (202984kB)
Memory in use       : 61 %
Uncached PFiles: 0x0
Use Inquiry    : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
20.8.2006
NeroAPI
18:03:18 #1 Phase 112 File APIProgress.cpp, Line 275
 DVD-Video files reallocation started
18:03:18 #2 Phase 114 File APIProgress.cpp, Line 275
 DVD-Video files reallocation completed (no file modified)
18:03:18 #3 Phase 111 File APIProgress.cpp, Line 275
 DVD-Video files sorted
18:03:18 #4 NEROAPI 7 File Burncd.cpp, Line 3095
 Error:\nCannot connect TRF.
18:03:18 #5 Text 0 File AudioCompilationImpl.cpp, Line 867
 DRM: DRM burn session terminated.
18:03:18 #6 Text 0 File AudioCompilationImpl.cpp, Line 896
 DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\PXHELP20.SYS': Ver=2.03.32a, size=20640 bytes, created 17/11/2005 18:19:28 (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option) [/#ff1c00]"[/#ff1c00]
d'ou vient le probleme : logiciel ,materiel ??????
n°5001769
darkry54
ITService :: IT Director
Posté le 20-08-2006 à 21:09:32  profilanswer
Thermaltake Xaser VI :: Asus P5N-e SLi - Intel Core 2 Duo E8600 3.33Ghz - 4 Go DDR2 PC-800 Corsair TwinX - Disques : WD500Go SATA + WD500Go SATA + WD500Go SATA + WD320Go + WD320Go IDE - HIS HD4870 ICEQ4+ Turbo 1go - Asus HD3450 256 Mo - Ecrans : 3 x ACER
Probleme copie dvd pioneer 106-d avec nero 7Probleme de copie des fichiers SATA
Probleme copie DVD avec neroProbleme pixelisation sur copie de DVD
problème avec la copie de dvdProbleme avec copie de partitions
probleme win xp lors de copie de fichierProbleme pour une copie de partition
Problème de copie de fichier sur une nouvelle configprobleme copie backup DVD ps2
Plus de sujets relatifs à : probleme copie de dvd
