3814 connectés
 Page :   1  2  3  4  5  ..  240  241  242  ..  305  306  307  308  309  310
[Topic Unik] Le Guide d'achat des meilleurs DVD vierges
n°4859763
bitonio6
La HDTV = Arnaque Du Siècle!
Posté le 03-06-2006 à 09:29:56  profilanswer
Justement j'ai choisi à fond, donc je devrais avoir plus d'erreur non?
Sinon j'ai trouvé cela sur le net concernant les NEC et Nero CD-DVD Speed
I haven't been able to test this myself but it seems that NEC fixed a bug with the scanning interval.
To change the scanning interval with Nero CD-DVD Speed the following registry value can be added:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\ahead\Nero Toolkit\CD Speed\CD Quality]
"Scanning Interval"=dword:0000008 for 8ECC or =dword:0000001 for 1ECC
To compare with other drives following intervals can be used:
8 ECC (to compare with BenQ/Philips/QSI/Pioneer)
1 ECC (to compare with LiteOn/BTC/Plextor)
32 ECC (to compare with AOpen)
The colored backgrounds and quality score are changed accordingly.
Apparemment il y aurait le lecteur DVD Plextor 130A qui serait compatible avec Nero CD-DVD Speed
Enfin, tout ça pour dire, bof mouaif ces tests!
--> Tu veux comprendre comment on sauvegarde un film DVD <--
n°4859794
bitonio6
Posté le 03-06-2006 à 09:58:13  profilanswer
Non mais vous avez vu ça???
Voici la procédure préconisée par nec pour la mise à jour d'un firmware
procédure pas du tout contraignante!  :ouch:  :pfff:
Please note following instructions for update procedure:
Connect drive to secondary IDE channel as Master
Disconnect all slave hardware from IDE secondary Master
Use standard UDMA-2 IDE cable
Update in Windows "Safe Mode"
Under Windows 2000 & XP login as administrator
Update without DMA mode, under Windows XP & 2000 in the device manager - "IDE ATA/ ATAPI controllers", you can switch from DMA to PIO mode
Disconnect all external USB/ FireWire devices.
Deactivate virusscanners, active desktop programs and packetwriting agents
Do not turn off power during the updating process.
Voilà pour la procédure
Cerise sur le gateau
Note: Warranty will be lost during false updating procedure, especially unofficial modified firmwares were used before.
In such cases we could not offer you a solution any more. You have to repair it by cost then.
Y'a pas à dire y sont sympas chez nec!
Et on sent le bon matos qui ne tombe jamais en panne,
tellement ils n'ont pas peur de faire une mise à jour de firmware  [:willone]
Heureusement qu'il y des gens qui proposent de bonnes mises à jour de firmware un peu plus sérieuse!
Comme ici par exemple pour les NEC --> http://liggydee.cdfreaks.com/
n°4859804
defdef21
Posté le 03-06-2006 à 10:06:37  profilanswer
salut,
c'est quoi le meilleur a votre avis chez verbatim :
Verbatim DVD-R 8x RITEK G05  ou Verbatim DVD-R 16x MCC 03RG20 ??
n°4859809
bitonio6
Posté le 03-06-2006 à 10:09:38  profilanswer
MCC car c'est leur production ;)
n°4859873
haxel
Posté le 03-06-2006 à 10:52:10  profilanswer
Ca t'a échappé mais skander14 disait que le NEC n'envoie JAMAIS d'info sur le Jitter (comme les Liteon et les Pioneer entre autres)
Par ailleurs, ta démonstration de l'inutilité des tests est pleine de trous. Ce serait plus convaincant si tu maîtrisais mieux l'outil.
Je pense que ta gravure de Philips est bonne mais que le format du disque n'est pas accepté par ta console (+R) mais évidemment ce n'est qu'une supposition car tu n'as pas répondu.
n°4859919
ArthurB
Posté le 03-06-2006 à 11:18:52  profilanswer
ArthurB a écrit :
C'est quoi les meilleurs DVD+RW ? Verbatim ?
n°4860000
haxel
Posté le 03-06-2006 à 11:55:48  profilanswer
Ricoh W11 en 4X et Ricoh W21 8X
En -RW les Verbatim 6X
n°4860202
bitonio6
Posté le 03-06-2006 à 13:55:39  profilanswer
Non la console accepte sans problème les + et les -R, mais cette gravure génére des erreurs c'est tout!
Maîtriser mieux l'outil... Genre t'as deux boutons à cliquer, mais il faut apprendre à mieux les maîtriser!
Je vais devoir changer de souris pendant que tu y es, histoire que je puisse mieux cliquer sur le quelques choix que propose cet onglet!?  :sarcastic:
Enfin, ce que l'on voit surtout dans le monde de la gravure, c'est que tout le monde y va de son idée
et que les fabricants veulent tellement se démarquer qu'ils font n'importe quoi!
Ces histoires de bitesetting ça m'énerve vraiment!
Aller chercher des firwmares ailleurs que chez le fabricant, car lui ne sait même pas bien exploiter son graveur!
Enfin, je vais arrêter là, parce que ça ne sert à rien d'en parler plus que ça...
ça n'empèchera pas les gens de tomber sur n'importe quoi et les fabricants de mieux travailler!
 :pfff:
n°4860361
Aschrack
Vive Pen²
Posté le 03-06-2006 à 16:07:29  profilanswer
pour finir, à conseiller les plextor TY ou non?
http://www.cdrvierge.com/main_fram [...] ba3a44ea8b
 Plextor DVD+R 16X (50pcs)
Prix/pièce  : € 24,91
Prix/4  : € 24,50
Prix/8  : € 24,00
Vitesse  :  16X
Emballage  :  Cakebox 50pcs
étiquette  :  Oui
ATIP  :  YUDEN000T03
Je viens d'apprendre que les ventes de voitures ont encore baissé de 7% en France. Y'en a marre de ces pirates qui téléchargent les voitures sur internet ! (antp était prems et est admin) - "Le travail est l'opium du peuple et je ne veux pas mourir dr
n°4860936
bitonio6
Posté le 03-06-2006 à 22:34:35  profilanswer
Si ils sont bien fabriqués, ça vaut le coup!
n°4861444
defdef21
Posté le 04-06-2006 à 10:48:53  profilanswer
Est ce que quelqu'un a deja commandé chez shop.cdfreaks.com ?
n°4861544
pancamo
Leave the gun.Take the cannoli
Posté le 04-06-2006 à 11:56:16  profilanswer
Salut, j'habite a quelques kilometres du magasin mmd (www.mmd.lu) et j'aimerais savoir quels sont les meilleurs media dispo sur ce site. J'ai commence a chercher par moi meme, mais vu la taille du topic
Ils n'indiquent toujours pas les mediacodes, dommage...Je sais qu'a une epoque les DVD Maxell (les 4X) etaient reputes tres bons, mais qu'apres ils etaient rentres dans la norme.
Je pensais a du TDK, ils sont toujours aussi excellents ? (plutot en +R vu kil parait que c mieux ) Mais pas donnes donnes :(
A moins que les Maxell soient bons aussi ?
Les Sony valent quoi ?
C'est pour graver des data, occasionnelement quelques films, pas d'overburning etc, du vraiment standard, quoi.
Merci de votre aide, desole que ce genre de questions revienne regulierement, mais quand on n'a pas suivi l'evolution depuis plusieurs mois et qu'on est en rtc, c'est long de se remettre a la page :(
n°4861595
bitonio6
Posté le 04-06-2006 à 12:20:34  profilanswer
Si tu prends du Verbatim 16x +R en boite individuelle, tu es quasi sûr d'avoir de la bonne qualité!
n°4863042
defdef21
Posté le 05-06-2006 à 01:45:48  profilanswer
des VERBATIM DVD-R BRANDED ''TAIYO YUDEN'' 16X c'est quoi comme mediacode , TYG03 ?  est-ce mieux que les plextor TYG03 ?
Message édité par defdef21 le 05-06-2006 à 02:00:48
n°4863161
bitonio6
Posté le 05-06-2006 à 09:27:48  profilanswer
J'aimerais bien connaitre leur part number à ceux là!
Parce qu'il m'avait semblé qu'il n'y avait eu que les pastels qui étaient en tayo yuden...
n°4863275
defdef21
Posté le 05-06-2006 à 10:26:07  profilanswer
moi aussi ! mais il sont affichés chez digitalpromo sous la reference :
VERBATIM DVD-R BRANDED ''TAIYO YUDEN'' 16x (apparement ce sont des 43522).
n°4863317
bitonio6
Posté le 05-06-2006 à 10:46:15  profilanswer
Si tu veux prendre le risque ;)
n°4864301
septicore
Posté le 05-06-2006 à 16:04:05  profilanswer
qui peut m'en dire plus au sujet des Taiyo Yuden de chez CDRvierges.com
Taiyo Yuden DVD-R 8X (100pcs)... TYG02...... 49.90€
n°4864311
sidney4
Posté le 05-06-2006 à 16:07:44  profilanswer
Rien à dire, ils sont excellents.
n°4864325
septicore
Posté le 05-06-2006 à 16:11:30  profilanswer
merci ;)
compatibles avec un vieux Nec3500 je suppose
n°4864532
bitonio6
Posté le 05-06-2006 à 17:33:53  profilanswer
n°4864976
-heat-
Posté le 05-06-2006 à 20:49:31  profilanswer
J'ai une petite question pour les experts de la gravure. Etant donné que je suis très attentif à la qualité de mes gravures (je fais pas mal de gravures qui contiennent photos ou vidéos et que je n'aimerais pas perdre au bout de quelques années...), pensez-vous que ca vaut le coup de changer mon bon vieux graveur de DVD ? Il s'agit d'un Nec 2500a @ 2510a (firmware 2F8 Mad Dog), que je possède depuis plusieurs années. En gros, est ce que les graveurs sortis après peuvent se vanter de faire des gravures de meilleure qualité ? La vitesse de gravure m'importe peu, d'ailleurs je grave la plupart du temps en 4x (malgré que j'utilise un graveur et des supports 8x), toujours dans un souci de qualité de gravure... D'ailleurs est ce fondé  comme approche ? (le fait de graver en 4x sur des supports 8x donne t'il un résultat de meilleure qualité ?)
Pour info j'utilise essentiellement du Taiyo Yunden comme supports. Merci d'avance à celui qui répondra à mes interrogations ;)
Message édité par -heat- le 05-06-2006 à 20:50:05
n°4865117
ingorang
Posté le 05-06-2006 à 21:49:48  profilanswer
salut posseseur successif d'un plextor 708a d'un pioneer 107 d'un nec 3500 ; d'un benq 1620 puis d'un benq 1640 et maintenant d'un benq1655 je ne peux que te conseiller la marque benq de toute facon avec les tayo yuden c'est quand meme le top
le sondage qui tue sur un forum de specialiste :
http://club.cdfreaks.com/showthread.php?t=135828
et toujours sur ce forum qui est une mine de renseignements un post pour toi
Best media for sensitive backups?
http://club.cdfreaks.com/showthread.php?t=180627
tayo grave sur benq 1655
http://img454.imageshack.us/img454/1047/gravure99r3ka.jpg
Message édité par ingorang le 06-06-2006 à 08:05:38
n°4865149
-heat-
Posté le 05-06-2006 à 22:02:35  profilanswer
ingorang a écrit :
salut posseseur successif d'un plextor 708a d'un pioneer 107 d'un nec 3500 ; d'un benq 1620 et maintenant d'un benq1655 je ne peux que te conseiller la marque benq de toute facon avec les tayo yuden c'est quand meme le top
http://img454.imageshack.us/img454 [...] 99r3ka.jpg
Ok Benq ca a l'air d'etre le top, mais la différence de qualité de gravure vaut elle le coup que je change mon bon vieux nec 2500 ? A l'époque c'était le top niveau qualité de gravure, vous pensez qu'il se situe ou par rapport aux nouveaux graveurs ? et toujours ma question concernant le fait de graver en 4x des supports 8x, cela améliore t'il la qualité ?
Merci pour tes liens, je vais y jeter un oeil ;)
n°4865800
bitonio6
Posté le 06-06-2006 à 12:14:40  profilanswer
ça vaut le coup oui et non...
il faut savoir qu'un graveur à une certaine durée de vie..
Mais si tu trouves et utilises toujours les mêmes médias, alors pas besoin de changer de graveur pour le moment! ;)
n°4866040
pancamo
Posté le 06-06-2006 à 13:55:59  profilanswer
Merci de ta reponse :)
Mais en prenant en spindle, c'est quand meme pas forcement la cata,si ?
Genre ca : http://www.mmd.lu/.ProduitImage?ID=163&Type=1
18.9 € les 50.
n°4866107
bitonio6
Posté le 06-06-2006 à 14:31:03  profilanswer
Ben mon expèrience me fait dire que "cake box = déchet obligatoire"
Très franchement je ne demenderais que ça si j'étais sûr de ne pas avoir de souci, mais j'en ai marre de jeter des media à la poubelle!
n°4866189
pancamo
Posté le 06-06-2006 à 15:18:37  profilanswer
Meme en tapant dans du media repute (tdk, maxell) ?  :??:
J'en ai pas grave beaucoup, c'est sur, mais quelques dizaines quand meme, notamment des maxell a l'epoque ou ils avaient ete chaudement recommandes ici meme, et j'en ai pas jete un seul.
En plus de l'aspect economique (spindle moins cher que a l'unite !), ca me fait un peu iech d'acheter des media en boitier individuel alors que 80% de ceux ci iront directos a la poubelle :(
n°4866401
Posté le 06-06-2006 à 16:53:41  answer
j'achète que des spindles depuis des années, mais seulement de la marque, j'ai jamais eu un seul problème.
n°4867414
bitonio6
Posté le 06-06-2006 à 23:27:55  profilanswer
Y'aura toujours des gens uniques et exceptionnels sur cette planète!
Si vous n'ouvrez pas les yeux et que vous gravez juste en pensant que si c'est gravé c'est que c'est bon, ben vous rêvez tout simplement!
Un média doit être exempt de toute marque, rayure, griffure, micro-griffure, tâche, etc...
Et je peux vous garantir que de nos jours le premier et le dernier media d'un cake boxe aura quelques unes de ces marques!
Maintenant si vous gravez du jetable, alors ce n'est pas grave, ce n'est pas mon cas, désolé!
Sony, Plextor, TDK, Memorex, Verbatim, etc...
Ils sont tous logé à la même enseigne
avec un mauvais point à plextor qui ne met même pas un anneau de mousse pour maintenir les medias en place pour les empècher de bouger! :(
J'ai reçu 4 cakes box de l'entier de la production plextor en DVD vierge, ils ont tous emballés pareil, sans le petit anneau de mousse!
C'est scandaleux!
n°4867552
skander14
Posté le 07-06-2006 à 01:08:05  profilanswer
Oui surtout que Plextor est souvent plus cher, et si on ne peut même plus citer les Tontons Flingueurs en se disant que "le prix s'oublie mais la qualité reste " où va-t-on ?  :D
Je me suis fait avoir une fois avec des TYG03 tachés de qualité douteuse, on ne m'y reprendra plus.  :pt1cable:
A+
Message édité par skander14 le 07-06-2006 à 01:08:25
n°4867571
bitonio6
Posté le 07-06-2006 à 01:27:56  profilanswer
c'était également des plextor? Des + ou -R, printable ou non printable?
n°4867573
skander14
Posté le 07-06-2006 à 01:30:28  profilanswer
C'était des Plextor R- (TYG03) jaune doré
Je n'avais jamais eu de problème avec les CDR Plextor qui ont toujours été au-dessus du lot !
A+
Message édité par skander14 le 07-06-2006 à 01:31:51
n°4867574
skander14
Posté le 07-06-2006 à 01:35:03  profilanswer
skander14 a écrit :
C'était des Plextor R- (TYG03) jaune doré avec GH000125 inscrit sur l'anneau interne
A+
Ouuups! une erreur mais la correction est bonne
Message édité par skander14 le 07-06-2006 à 01:36:15
n°4867582
bitonio6
Posté le 07-06-2006 à 01:59:35  profilanswer
Les CD-R sont toujours top même en cake box de 50pièces!
Les -R 16x sont les pires que j'ai vu, alors que les 8x étaient impeccable dans leur boite individuelle!
Les +R 16x sont devenu meilleurs, peut-être est-ce juste une jeunesse de fabrication!
Plextor m'a renvoyé les 4 packs cake box représentant l'entier de leur production actuel
je ne me gênerais pas de leur renvoyer des médias tâchés, et cette fois en marquant avec un stylo indélébile, là où se trouveront les tâches, griffures, rayures perçues!
n°4867615
defdef21
Posté le 07-06-2006 à 03:28:12  profilanswer
quel test de nero speed permet de determiner la qualité d'une gravure ? comment interpreter la courbe ?
n°4867640
ingorang
Posté le 07-06-2006 à 06:56:59  profilanswer
il faut deja un graveur compatible et ensuite tu lis ca : http://www.gravure-news.com/html/arts/17/page01.php
n°4867894
defdef21
Posté le 07-06-2006 à 11:04:33  profilanswer
Merci.
n°4871946
defdef21
Posté le 09-06-2006 à 10:26:22  profilanswer
j'ai fait un test PI/PO avec Plextools d'1 gravure sur VERBATIM 16X DVD-R TYG03  sur un PLEXTOR 716 avec plextools a 4X.
J'obtiens une courbe qui se situe en moyenne autour de 100 dont une partie non négligeable autour de 120/130.
C'est pas beaucoup ???
n°4872330
Talisker
Pouet pouet badaboom
Posté le 09-06-2006 à 13:45:07  profilanswer
Bonjour a tous
j'ai acheté des TY unbranded
le seul pbm c'est que je n'arrive pas a les graver sur mon graveur principal (un nec 3540) il me foire la gravure a tous les coup
quand je passe des philips ou des TDK il n'y a pas de pbm
je suis obligé de gravé avec mon graveur de pc portable et c'est bien la galere
a votre avis de quoi cela peu venir ??
merci par avance
-= Que Dieu bénisse St Patrick, Le moine évangélisateur le plus célébre d'Irlande et d'Ecosse. Ceci grace à ca fabuleuse et merveilleuse découverte qu'est l'Uisge Beatha =-Feedback http://forum.hardware.fr/forum2.ph [...] &post=8848
n°4872511
bitonio6
Posté le 09-06-2006 à 14:55:31  profilanswer
Talisker a écrit :
Bonjour a tous
merci par avance
Problème de firmware!
Achat nouvelle CMCompatibilité Graveur DVD (+R/-R) avec platine DVD Salon
[Topic Officiel] HIS IceQ 9800 Pro (+ Vga Silencer)Achat P4PE ou P4P800 ?
Graveur de DVD, quelle config minimum?Pb graveur DVD BTC DVDRW IDE1004IM
Quelles lecteur de DVD de Salon??????Impossible de lire mon DVD gravé ! Why ??
celeron 667Mhz assez puissant pour lecteur de DVD ?[Topic Officiel] Graveur DVD NEC ND-1300 A
Plus de sujets relatifs à : [Topic Unik] Le Guide d'achat des meilleurs DVD vierges
