2349 connectés
  Boitier
  [Topic Unique] Thermaltake Element S,G,T et V MAJ 05/11/09
 Page :   1  2  3  4  5
Page Précédente
n°6850134
Fssabbagh
Satsui no Hado
Posté le 17-02-2009 à 13:35:21  profilanswer
Le Thermaltake Element S est un boîtier pour les personnes cherchant une très bonne ventilation type Storm Sniper, un grand espace de stockage amortissant les vibrations  grâce à ses 7 slots HDD amortissant les vibrations ainsi que d'un look très classe.
Caractéristiques du Element S
Features:
- Anti-vibration & noise reduction material on side panel
- Stealth Black Interior
- Massive Storage Capability with 7 x 3.5" and 2 x 2.5" HDD bays
- Direction-free HDD cage
- Excellent thermal performance with optimal air flow
- Folding edge design to strengthen structure and prevent cutting
Specs:
Case Type: Mid Tower
Material: SECC
Front Bezel Material: Plastic
Color: Black
Side Panel: Solid
Motherboard Support: Micro ATX, Standard ATX
Motherboard Tray: No
5.25" Drive Bay: 3
Ext. 3.5" Drive Bay: 0
Int. 3.5" Drive Bay: 7
Expansion Slots: 7
Front I/O Ports: USB 2.0 x 2, eSATA & HD Audio ports
Cooling System: - Front (intake) : 120 x 120 x 25 mm TurboFan, 1300 rpm, 17 dBA : 120 x 120 x 25 mm (optional) - Rear (exhaust) : 140 x 140 x 25 mm TurboFan, 1000 rpm, 16 dBA - Top(exhaust) : 230 x 230 x 20 mm red LED fan, 800 rpm, 15 dBA - VGA (exhaust) : Two 60 x 60 mm fan(optional)
Liquid Cooling Capable: No
Liquid Cooling Embedded: No
Power Supply Supported: Standard ATX PSII(optional)
Power Supply Included: No
Dimension (H*W*D): 21.3 x 9.1 x 19.9 in / 505 x 230 x 540 mm
Net Weight: 19.49 lbs / 8.84 kg
Galerie photo
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01063.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01064.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01065.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01066.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01068.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01069.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01070.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01071.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01072.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01073.jpg
Message édité par Fssabbagh le 05-11-2009 à 23:39:46
Messatsu !
n°6850137
Fssabbagh
Satsui no Hado
Posté le 17-02-2009 à 13:37:15  profilanswer
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01074.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01075.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01076.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01091.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01092.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01077.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01078.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01079.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01080.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01081.jpg
Messatsu !
n°6850141
Fssabbagh
Satsui no Hado
Posté le 17-02-2009 à 13:41:23  profilanswer
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01082.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01083.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01084.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01085.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01086.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01088.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01089.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01090.jpg
http://www.3dgameman.com/vr/thermaltake/elements_case/DSC01087.jpg
Tests
Hardware Secrets : http://www.hardwaresecrets.com/article/690
HiTechLegion : http://www.hitechlegion.com/review [...] ttelements
ThinkComputer :http://www.thinkcomputers.org/inde [...] ews&id=929
3d gameman en vidéo : http://www.dailymotion.com/Fssabbagh/video/141481554
tests Français :
http://www.cowcotland.com/articles [...] ltake.html
Message édité par Fssabbagh le 30-03-2009 à 20:09:48
Messatsu !
n°6850384
zaggon
Posté le 17-02-2009 à 16:43:41  profilanswer
entre le 230mm latéral, le 230mm sur le top, le 140mm à l'arrière et les 2 60mm la zone de la cm est parfaitement ventilée c'est clair.
bien vu le cable management ;)
qu'en est-il de la finition chez Thermaltake ?
Feed sur mon topic : http://forum.hardware.fr/hfr/Achat [...] 7444_1.htm
n°6850417
nofoger
Posté le 17-02-2009 à 17:11:00  profilanswer
il est beau mais il me semble que les ventilo thermaltake sont a chier...faut voir pour ceux la
d'après le premier test la cage des disque c'est pas le top du top  :whistle:
n°6850443
zaggon
Posté le 17-02-2009 à 17:34:57  profilanswer
c'est un boitier à modder à mon avis.
n°6851050
couillesho​t
Les bouboules et la boubouche
Posté le 18-02-2009 à 02:05:52  profilanswer
alimenter en air un ventilo de 23cm par une petite grille même pas disposée en face c'est ridicule  :heink: (je parle du ventilo latéral)
Message édité par couilleshot le 18-02-2009 à 02:13:27
:o :o :o
n°6851245
Fssabbagh
Satsui no Hado
Posté le 18-02-2009 à 11:25:29  profilanswer
There's space around the door to allow the fan(s) to intake cool air.
d'après Rodney Reynolds :wahoo:
Messatsu !
n°6851352
Alis_70
Posté le 18-02-2009 à 12:16:59  profilanswer
c'est un concurrent du nine hundred ça ... au niveau des façades, ventilo, repartition des cables, etc, c'est un peu foutu pareil.
Par contre le truc très utile que l'on ne retrouve pas sur les nine et twelve hundred, c'est le trou pour pouvoir démonter un rad par derrière sans démonter la carte mère.
n°6851427
couillesho​t
Posté le 18-02-2009 à 12:58:26  profilanswer
Le trou pour le rad ça a été lancé par coolermaster, thermlatake en concurrent direct un peu dépassé suit le mouvement
Désolé mais pour moi c'est clairement mal foutu, autant virer le ventilo latéral, faudrait savoir où se positionne ce boitier : pro et sobre ou ventilé tuning?
Le mélange des deux pourrait être interessant mais le ventilo latéral sert clairement à rien, ou alors faut lui mettre une vrai grille  :heink:
Message édité par couilleshot le 18-02-2009 à 13:01:41
:o :o :o
n°6851496
morgani
Posté le 18-02-2009 à 13:46:56  profilanswer
Y' a pas de filtre sur les ventilos ?
-=Mon topic ventes=-
n°6852599
Fssabbagh
Satsui no Hado
Posté le 19-02-2009 à 10:19:03  profilanswer
si justement :
MAJ du post principal :)
Messatsu !
n°6852640
Fssabbagh
Satsui no Hado
Posté le 19-02-2009 à 10:53:43  profilanswer
edit : tu a accès au backplate du ventirad cpu sans démonter la mobo comme le coolermaster 840 et cerise sur le gâteau le bruit des ventilos thermaltake est raisonnable :hello: la finition est excellente et la qualité de la cage hdd est très propre notamment pour réduire les vibrations
Message édité par Fssabbagh le 19-02-2009 à 10:55:11
Messatsu !
n°6852680
morgani
Posté le 19-02-2009 à 11:29:28  profilanswer
Le raven me faisait envie mais celui la a l'air bien vivement un test FR.
Dans la vidéo on ne voit pas le 23cm latéral il est en option ?
n°6852683
Fssabbagh
Satsui no Hado
Posté le 19-02-2009 à 11:30:52  profilanswer
non il est bien là ;)
Message édité par Fssabbagh le 19-02-2009 à 11:35:20
Messatsu !
n°6852872
Vigorius
Posté le 19-02-2009 à 14:10:24  profilanswer
Une idée de la disponibilité en magasin français?
J'ai lu un test + vu la video sur daily et çà m'a l'air d'etre du tout bon ce boitier.
Je le trouve sobre et avec une bonne finition de quoi faire envie ;)
n°6852893
Fssabbagh
Satsui no Hado
Posté le 19-02-2009 à 14:21:34  profilanswer
+1 Vigorius :love:
Messatsu !
n°6852900
morgani
Posté le 19-02-2009 à 14:26:40  profilanswer
Ouep par contre les deux trous pour les ventilo de 6 cm je voit pas l'intérêt surtout avec un 23 latéral.
n°6852914
Vigorius
Posté le 19-02-2009 à 14:43:58  profilanswer
Ouais surtout qu'avec des 6 cm paye ton bruit aigu :/
Je l'ai trouvé à vendre ici http://fr.shopbot.ca/pp-thermaltak [...] 67699.html
Au canada donc...
Vivement qu'il arrive en boutique française.
Il est en mid tower en plus donc parfait vu que je n'ai pas une grosse configuration.
n°6852931
Fssabbagh
Satsui no Hado
Posté le 19-02-2009 à 14:54:43  profilanswer
je pense que même si tu a une grosse config le Element S pourra tout caser avec ses 7 slots HDD et son très bon câble management :)
Messatsu !
n°6853093
morgani
Posté le 19-02-2009 à 16:38:47  profilanswer
Dans aucun des trois tests je n'ai vu ni lu qu'il y' avait un 23 latéral.
Message édité par morgani le 19-02-2009 à 16:41:45
n°6853363
morgani
Posté le 19-02-2009 à 19:43:13  profilanswer
Bon je viens de regarder le manuel sur le site de TT et en fait il y' a deux version une avec 23 latéral et une sans, celle avec possède une grille devant le ventilo sur la porte latéral.
http://www.thermaltake.com/db/pictures/modules/PDT/PDT060207001/20091221730753343.jpg
Message édité par morgani le 19-02-2009 à 19:56:03
n°6853568
Vigorius
Posté le 19-02-2009 à 21:49:13  profilanswer
Oki merci pour les informations morgani, reste à voir vers quel prix il sera proposé en france vu qu'on est vers 149$ à l'etranger çà devrait faire du 110-120€ prix français çà non?
Un bon concurrent au 900 V2 de antec et coolermaster 922 qui sortira bientot donc...
n°6853979
Fssabbagh
Satsui no Hado
Posté le 20-02-2009 à 10:40:56  profilanswer
le problème des Antec c'est le très faible espace en hauteur ce qui rend difficile l'installation d'un ventirad assez imposant
Messatsu !
n°6854174
Vigorius
Posté le 20-02-2009 à 12:42:50  profilanswer
Bon y'a du nouveau les loulous.
Version avec ventilo latéral donc de 23 cm
http://www.materiel.net/ctl/Boitie [...] 1W2ZD.html
On s'est encore fait avoir sur le taux de change, du coup pour ce prix j'hésite fortement je m'attendais à 10-20 euros de moins tout de même.
n°6854416
Zenus
Posté le 20-02-2009 à 15:00:00  profilanswer
Je cherchais un boitier qui allie sobriété et ventilation et je l'ai enfin trouvé.
Peut-être mon futur boitier pour remplacer mon antique Antec1040 en 80mn.
Non pour moi le prix à l'air correct, surtout si le boitier est de qualité et que l'on trouve pas mieux chez la concurence dans ce style de boitier.
Le prix sur ce site canadien est de 150$:
http://www.esng.ca/productDetail.p [...] &isid=9820
Et il n'a pas l'air de posseder de ventilateur latéral.
Sur matériel.net il y a bien le ventilateur latéral donc c'est la version la plus chère.
De plus il y à des questions de TVA en France, et la conversion €=>$ est moins favorable en ce moment.
Par contre avant ma décision d'achat, j'attend d'abord de lire un test FR.
Parce que là il est dispo dans 14 jours en France et j'hésite à précommandé.
Message édité par Zenus le 20-02-2009 à 15:03:15
n°6854473
Fssabbagh
Satsui no Hado
Posté le 20-02-2009 à 15:24:47  profilanswer
ta bien raison
Messatsu !
n°6854513
Zenus
Posté le 20-02-2009 à 15:40:56  profilanswer
Plus j'y pense et puis je me dit que c'est le boitier que j'ai toujours voulu avoir.
Nouveau test en anglais :
http://www.pureoverclock.com/revie [...] 713&page=1
Note finale :
http://www.pureoverclock.com/images/review/cases/thermaltake_elements/thermaltake_elements_summary.jpg
Ce boitier à l'air excellent.
Message édité par Zenus le 20-02-2009 à 15:42:05
n°6854578
Fssabbagh
Satsui no Hado
Posté le 20-02-2009 à 16:14:24  profilanswer
:love:
Messatsu !
n°6854642
shum94
Posté le 20-02-2009 à 16:49:16  profilanswer
Chu interessé  :)
Par contre dans le meme delire y a deux boitiers, un à 100 € et l'autre à 180 €
http://www.materiel.net/live/45887.jpg
http://www.materiel.net/ctl/Boitie [...] 01W2Z.html
http://www.dailymotion.com/video/x [...] -le-t_tech
test fr : http://www.revioo.com/articles/a11923_5.html
http://www.materiel.net/live/47810.jpg
http://www.dailymotion.com/video/x [...] ition_tech
Message édité par shum94 le 20-02-2009 à 17:26:50
n°6854644
Fssabbagh
Satsui no Hado
Posté le 20-02-2009 à 16:52:15  profilanswer
les tests de ces 2 boîtiers sont là :
http://www.dailymotion.com/search/ [...] -le-t_tech
http://www.dailymotion.com/search/ [...] ition_tech
Messatsu !
n°6854664
Zenus
Posté le 20-02-2009 à 17:02:54  profilanswer
Pour ceux qui souhaiterais un boitier parfaitement sobre et qui n'aimerais pas la bande rouge de la porte avant,
il me semble que d'après les photos du haut de ce topic que c'est partie soit détachable mais c'est à confirmer.
Puis il faudrait voir ce que ça donne sans.
Sinon un coup de pinceau (ou de l'adhesif renforcé noir) et le tour est joué.
Mais moi je l'aime déjà bien comme ça  :love:
Message édité par Zenus le 20-02-2009 à 17:05:27
n°6854667
Fssabbagh
Satsui no Hado
Posté le 20-02-2009 à 17:05:34  profilanswer
déjà rien que les 7 baies HDD :)
Messatsu !
n°6857709
shum94
Posté le 22-02-2009 à 20:24:07  profilanswer
Hum apres voir vu le cooler master ats 840, je dois dire que plus rien d'autres m'interesse.
n°6858065
morgani
Posté le 23-02-2009 à 08:10:04  profilanswer
C'est pas le même prix hein.
n°6858218
Fssabbagh
Satsui no Hado
Posté le 23-02-2009 à 11:32:45  profilanswer
en comparant le spedo au 840, le spedo sépare les composants ce que le 840 ne fait pas mais la finition est peut-être un peu meilleure :)
Messatsu !
n°6859404
zaggon
Posté le 24-02-2009 à 02:32:54  profilanswer
le Element S est la réponse au Haf 932...
n°6859515
couillesho​t
Posté le 24-02-2009 à 09:15:28  profilanswer
à mettre en face du Sniper plutôt ou du Nine hundred 2, moi j'aime l'allure et les fonctions mais pas le plastique, dommage   :kaola: :(
le même avec extérieur alu serait trop classe  :o
Message édité par couilleshot le 24-02-2009 à 09:17:06
:o :o :o
n°6859961
Fssabbagh
Satsui no Hado
Posté le 24-02-2009 à 15:20:38  profilanswer
oui mais le prix  [:tinostar]
Messatsu !
n°6860011
zaggon
Posté le 24-02-2009 à 16:00:05  profilanswer
le Element S et le HAF sont vraiment comparables tant pour les prix que pour l'architecture interne des boitiers, le principe de circulation de l'air est quasi identique sauf que c'est le choix des ventilos qui diffère et l'ajout d'un pseudo compartiment.
ce sont 2 boitiers très proches mais pensé autrement...
 Page :   1  2  3  4  5
Page Précédente
  Boitier
Config pour Hyper-V VmWare etcCarte Mere Asus M3A79-T AM2+ qui plante
P5N-T deluxe probleme avec ram pc2-8500 (1066mhz)Boitier Thermaltake aguila et HD Samsung
S.O.S Mon PC ne reconnait plus mon disque durConfig' µATX+Phenom 9950+G.Skill 4Go correcte pour la retouche photo ?
MAJ Config Jeux pour 600-650€Problème T° sur CF HD4870 ou pas !?
Comment régler le contraste sur un Vaio FZ21 S ???
Plus de sujets relatifs à : [Topic Unique] Thermaltake Element S,G,T et V MAJ 05/11/09
