1226 connectés
  Boitier
  [Boitier] Thermaltake Aguila
n°4904472
fafa_monte​co
Posté le 27-06-2006 à 11:03:39  profilanswer
Bonjour tout le monde
Que pensez vous de ce boitier ? il a l air pas mal et ressemble beaucoup au Tsunami
http://www.thermaltake.com/product/Chassis/midtower/aguila/+agu_image/black/01enlargeviewb.jpghttp://www.thermaltake.com/product/Chassis/midtower/aguila/+agu_image/black/02enlargeviewb.jpghttp://www.thermaltake.com/product/Chassis/midtower/aguila/+agu_image/black/03enlargeviewbw.jpghttp://www.thermaltake.com/product/Chassis/midtower/aguila/+agu_image/black/05enlargeviewbw.jpghttp://www.thermaltake.com/product/Chassis/midtower/aguila/+agu_image/black/07enlargeview.jpg
Site officiel et un test
Les details
Case Type Middle Tower
Side Panel Transparent Window
Net Weight 10.98 kg
Dimension (H*W*D) 478.0 mm x 210.0 mm x 520.0 mm
Cooling System Front (intake) : 120x120x25mm, 1300rpm, 17dBA
Rear (exhaust) 120x120x25mm, 1300rpm, 17dBA, blue LED fan
Drive Bays  5 x 5.25"
2 x 3.5"
4 x 3.5"
Material Chassis : 0.8mm SECC
Front panel Aluminum
Color Black
Expansion Slots 7
Motherboards 12" x 9.6" (ATX) & 9.6" x 9.6" (Micro ATX)
I/O Ports USB 2.0 x 2, IEEE 1394 x 1, Audio & Speaker ports
PSU 400W ATX 12V V2.0
430W ATX 12V V1.3
Container Load 20’-253, 40’-541, 40’HQ-629
Features Middle tower, full aluminum front panel
ATX/BTX compatible (BTX upgrade kit is optional)
Fits up to standard ATX & BTX motherboard
Meshed front grill to maximize ventilation performance
Dual 120mm silent front and rear fan
Liquid cooling system upgradeable
7 5 ¼ drive bays
6 3 ½ bays ( 4 internal 2 external)
Top mount USB 2.0, firewire and headphone and mic
Lockable side panel with large thumb screws
Message édité par fafa_monteco le 27-06-2006 à 13:42:32
n°4966294
stevenj
Posté le 04-08-2006 à 11:23:23  profilanswer
C'est un boitier que j avais remarqué mais selon l'article, il semble qu il n y ait pas trop d espace et assez lourd tout de même pour un boitier en aluminium. Je l'avais choisi pour ma prochaine config...là je ne sais plus, je vais y penser.
n°4967084
C13-Fury
FurySanctuary sur YT
Posté le 04-08-2006 à 16:22:19  profilanswer
Je le trouve superbe et je l'aurai pris pour mon PC2 s'il avait pas été si cher.
Pour le PC1 je suis en Tt Kandalf mais pour la 2 le prix de la Antec PlusviewII suffit largement :p
Pour la comparaison avec le Tsunami, il faut espérer que la tour soit moins "chewing-gum", car à vide elle se tort de douleur facilement :sweat: , une fois remplit c'est bon :sol:
Niveau poids ça va, c'est correct pour une grande tour c'est pas les 18kg de la Kandalf acier :lol:
Pour plus de place il suffit d'aller voir ici ou
Message édité par C13-Fury le 04-08-2006 à 16:27:18
Reviews Jouets et Figurines - Fulguropop, culture pop - Toyzmag, actu' jouets et figurines -
n°4967439
stevenj
Posté le 04-08-2006 à 19:33:08  profilanswer
Hummm plutôt bien l eureka...un choix à considérer.
n°5052817
patichon29
Posté le 13-09-2006 à 04:45:20  profilanswer
Petit UP pour petite précision :
l'aguila noir n'est pas full alu -> seul la facade est un alu alors que la structure est en acier.
l'aguila silver est par contre full alu comme vous pouver le voir sur cette photo :
   http://www.thermaltake.com/product/Chassis/midtower/aguila/+agu_image/silver/03enlargeviewsw.jpg
d'ou la difference de poids... et de prix !
Je me tate a prendre le silver pour une prochaine config car je trouve la facade vraiment réussie, mais j'ai un doute sur la cage hdd : silencieuse ou non ?
n°5090071
stevenj
Posté le 04-10-2006 à 13:20:44  profilanswer
tu as des photos ?
n°5090556
fafa_monte​co
Posté le 04-10-2006 à 16:34:46  profilanswer
et autrement est il vraiment etroit ce boitier ?
n°5117872
jdaou
Posté le 20-10-2006 à 20:04:14  profilanswer
non, il est pas si etroit que ca.
Par contre en vrai il rends pas du tout comme sur les photos, faut aimer l'estetique un peu particulière du boitier
n°5136217
gary971
>>d(-_-)b<<
Posté le 30-10-2006 à 16:45:14  profilanswer
Le AGUILA en silver va avec des lecteurs noir  ou sa fait tache sachant qu'il n'y a pas de graveur gris?
n°5136223
tQku1
Posté le 30-10-2006 à 16:47:57  profilanswer
Bah si y'a des graveur gris :o
Mon plextor avait 2 facades, une noire, et une blanche/grise, qui s'intègre parfaitement avec ma Kandalf silver
J'aime bien la facade plexi de celui la, celle du Kandalf est moins bien, c'est a pein la moitié en plexi :/ tandis que la c'est 80/90% je dirais
Message édité par tQku1 le 30-10-2006 à 16:49:17
n°5136298
C13-Fury
Posté le 30-10-2006 à 17:44:08  profilanswer
C'est tout simplement la porte du Tsnuami, vive la recycle chez Tt.
J'aime pas trop ça forme, je préfère celle du Kandalf, mais +1 pour mieux y voir.
Oui ça rend mal les lecteurs noirs avec du silver mais il reste le coup de peinture, en une après midi c'est fait (2/3 couches) et ça coute moins cher.
Message édité par C13-Fury le 30-10-2006 à 17:44:28
n°5137287
gary971
>>d(-_-)b<<
Posté le 31-10-2006 à 03:54:03  profilanswer
Je crois que je prenderait le noir juste pour la difficulté de trouver des graveurs gris.
n°5251362
oliviermdv​y
Posté le 28-12-2006 à 19:47:24  profilanswer
Quelques tests ici:
http://www.anandtech.com/casecooli [...] i=2815&p=8
http://www.hexus.net/content/item. [...] 979&page=1
si vous connaissez d'autres sites l'ayant testé n'hésitez pas, mais évitez ces pauvres sites qui ne testent rien, ils ne montent même pas de matos à l'intérieur ! J'appelle pas ça un test...
Sinon y'a t'il des possesseurs de ce boitier ? Que l'on ait leur avis niveau bruit et température, merci.
Message édité par oliviermdvy le 28-12-2006 à 20:17:43
n°5251385
william95
Avançons à reculons
Posté le 28-12-2006 à 19:53:36  profilanswer
pas mal
MY FEEDBACK HERE
n°5252582
C13-Fury
Posté le 29-12-2006 à 11:46:40  profilanswer
Contribution au topic ;)
Vu chez vtr-hardware
Votre boîtier peut-il accepter une 8800 GTX ?
L'aguila y est référencé.
Message édité par C13-Fury le 29-12-2006 à 11:47:01
n°5252638
oliviermdv​y
Posté le 29-12-2006 à 12:03:42  profilanswer
Visiblement une 8800GTX n'entre pas... pas glop  :(
le lien ici: http://s41.photobucket.com/albums/ [...] ?start=all
Message édité par oliviermdvy le 29-12-2006 à 12:04:02
  Boitier
Boitier pour graveur DVD internecherche alim + boitier pour 120E!!
Choix d'une alimentation + BoitierQuel boitier ?
Quel boitier HDD externe ?quel boitier ??
Que choisir Boitier ou barbone??Carte Mère ne marche qu'en dehors du boitier?! avez vous une solution
Boitier externe pour DD SCSI Seagate Elite st410800nliens pour acheter boitier lian li pc-g7 (et non le pc-g70) please
Plus de sujets relatifs à : [Boitier] Thermaltake Aguila
