1635 connectés
  [Topic Unique] Sapphire Radeon X850 Series
 Page :   1  2  3  4  5
Page Précédente
n°4033110
quechua46
Posté le 25-04-2005 à 18:45:56  profilanswer
/!\ EN CONSTRUCTION /!\
http://quechua.chez.tiscali.fr/images/Sapphire/bandeauB.jpg
Bienvenue sur le topic unique de la gamme Sapphire Radeon X850. Il a pour but de centraliser toutes les informations sur ces cartes afin de constituer une base de données solide, pour les futurs acheteurs comme pour les autres.
http://quechua.chez.tiscali.fr/images/Sapphire/titre.jpg
SoMMAIRE
I. CARACTéRISTIQUES
II. BUNDLE
III. REFROIDISSEMENT
IV. OVERCLOCKING
V. DRIVERS
VI. TESTS
I.CARACTéRISTIQUES
Spécifications Techniques
Sapphire Radeon X850 PRO
Core: 507 MHz
Memory: 520 MHz DDR
    * 256MB of GDDR3 memory
    * 256-bit memory interface
    * 12 parallel pixel pipelines
    * PCI Express x16 lane native support or AGP 8x
    * Dual display support
    * Dual integrated 400MHz DAC's
    * 2048x1536 @ 85Hz Maximum Resolution
    * S-Video TV-out port
    * Full support for DirectX® 9.0 and the latest OpenGL® 2.0 functionality
    * SMARTSHADER™ HD technology
    * SMOOTHVISION™ HD technology
    * 3Dc™ High quality 4:1 Normal Map Compression delivers beautiful scenes without the performance hit.
    * Unique VIDEOSHADER™ HD engine uses programmable pixel shaders to accelerate video processing and provide better-looking visuals
    * HYPER Z™ HD is optimized for performance at high display resolutions, including widescreen HDTV resolutions.
Sapphire Radeon X850 XT
Core: 520 MHz
Memory: 540 MHz DDR
    * 16 parallel pixel pipelines
Sapphire Radeon X850 XT PE
Core: 540 MHz
Memory: 590 MHz DDR
    * 256-bit quad-channel GDDR3 memory interface
    * 6 parallel vertex processing engines
    * Digital DUO™ technology allows for DUAL DVI connections for multiple flat panel use
    * YPrPB component HDTV output
    * VIVO - Video-in/Video-out Capable
    * Full support for DirectX® 9.0 and the latest OpenGL® functionality
    * New SMARTSHADER™ HD technology allows for support for Microsoft® DirectX® 9.0 programmable vertex and pixel shaders in hardware as well as OpenGL® via extensions.
    * SMOOTHVISION™ HD technology provides enhanced image quality by removing jagged edges and bringing out fine texture detail, without compromising performance
Les spécifications suivent les recommandations d'ATi. A savoir que la version XT est disponible avec fonctions VIVO. Seule la sortie TV est présente sur la version de base.
Les versions AGP sont construites autour du R481 qui gère l'AGP en natif. Pas de bridge RIALTO donc.
Tableau comparatif des architectures:
(Source: Clubic)
http://quechua.chez.tiscali.fr/images/Sapphire/tableau.jpg
Photographies
http://quechua.chez.tiscali.fr/images/Sapphire/carte1.jpg
http://quechua.chez.tiscali.fr/images/Sapphire/carte2.jpg
II. BUNDLE
http://quechua.chez.tiscali.fr/images/Sapphire/boites.jpg
http://quechua.chez.tiscali.fr/images/Sapphire/bundle.jpg
Beaucoup de choses dans cette petite boîte  :) :
  • Splinter Cell Pandora Tomorrow
  • Prince of Persia, Sands of Time
  • Power DVD 5
  • Power Director 3DE
  • Drivers Sapphire (soit disant améliorés  :whistle: )
  • Utilitaire RedLine d'o/c et tweaking
  • Cable S-video et composite
  • Cable d'alim PCI-e
  • Cable HDTV
  • Cables VIVO
  • Deux adaptateurs DVI/RVB
  • ET un joli autocollant  :pt1cable:
Message édité par quechua46 le 27-04-2005 à 13:26:42
n°4033111
quechua46
Posté le 25-04-2005 à 18:46:15  profilanswer
http://quechua.chez.tiscali.fr/images/Sapphire/carte_silencer.jpg
Une fois de plus, Sapphire ne se démarque pas du design de référence.
Le ventilateur est annoncé comme assez silencieux la plupart du temps mais extrèmement bruyant à pleine vitesse.
Je n'ai donc pas attendu pour commander un ATi silencer 5, dont l'installation sera d'ailleurs détaillée et les résultats comparés au refroidissement d'origine, tant en émision sonore qu'en évolution thermique.
EDIT:
Je viens de recevoir mon ATi Silencer 5 Rev.2   :pt1cable:
Voici les premieres photos de la bête:
http://quechua.chez.tiscali.fr/images/Sapphire/silencer3small.jpg
http://quechua.chez.tiscali.fr/images/Sapphire/silencer2small.jpg http://quechua.chez.tiscali.fr/images/Sapphire/silencer1small.jpg
Premières constatations:
  • La plaque arrière est différente des Silencer 4. Elle forme un angle droit assez imposant (pour quelle raison?  [:spamafote] )
  • Plus besoin de déposer de pâte thermique sur les puces mémoires. Artic Cooling a placé des pads thermiques autocollants aux endroits nécessaires. Conséquence=> plus de problème de mauvais contact entre le rad et les puces.
http://quechua.chez.tiscali.fr/images/Sapphire/carte_silencer2.jpg
Spécifications techniques
http://quechua.chez.tiscali.fr/images/Sapphire/silencerperf.jpg
Pas vraiment de surprise de ce côté là. Notez tout de même la différence importante au niveau du refroidissement des puces mémoires. D'après la brochure d'artic cooling le ventilateur d'origine ne refroidirait pas la mémoire.
A vérifier tout de même.
D'après ce que j'ai compris grâce à mon ami google 1 Sone équivaut à 40dB.
Non en fait c'est pas possible. Le ventilo d'origine émettrait plus de 160 dB et on serait tous sourds comme des poireaux  :pt1cable: .
1 Sone = 40 Phones . Mais 1 Phone ça fait combien ?  [:spamafote]
IV. OVERCLOCKING
Pas encore d'infos pour cette section  [:austinou]   [:spamafote]
Message édité par quechua46 le 27-04-2005 à 18:52:42
n°4033113
quechua46
Posté le 25-04-2005 à 18:46:30  profilanswer
IV. DRIVERS
http://www.ati.com/designpartners/media/images/thumbnails/atilogo_RED_thumb.jpg
Catalyst 5.4 Officiels
Windows 2000/XP avec Control Panel
Windows 2000/XP avec Control Center (Net framework requis)
Windows XP x64
8.12.10
Linux x86
Linux x86_64
VI. TESTS
Bjorn 3D (anglais)
Message édité par quechua46 le 27-04-2005 à 13:58:14
GigaByte Radeon X800 Series
n°4034006
apple13
Posté le 26-04-2005 à 01:00:18  profilanswer
Excellente initiative :)
Justement j'hésite entre le silencer et un zalman tt cuivre.
Pourquoi à tu choisis celui là?
Merci :)
n°4034007
apple13
Posté le 26-04-2005 à 01:01:34  profilanswer
Ah je précise quelque chose. Mon rad n'est pas exactement pareil. J'ai pas l'autocollant sapphire mais la déko tribale :)
Voilà c'est qu'un détail :) (x850xt)
n°4034222
amesis
Posté le 26-04-2005 à 10:21:59  profilanswer
J'ai commandé la sapphire X850XT PE en version AGP chez rueducommerce j'attends de la recevoir  :)   apparement c'est une version OEM j'ai une photo de la bete si tu veux  :jap:
Message édité par amesis le 26-04-2005 à 10:33:07
n°4034241
quechua46
Posté le 26-04-2005 à 10:33:12  profilanswer
Bien sûr, toutes les photos sont bonnes à prendre :D
J'ai pris un ATi silencer 5 car avant ça j'avais un vga silencer sur ma 9800 pro et un ATi silencer sur une x800xt pe. L'évacuation de l'air chaud c'est vraiment un plus comparé à un zalman (enfin à mes yeux).
Celà dit mon expérience zalman sur GForce 4 Ti 4400 ne m'a pas non plus déplut.
n°4034248
amesis
Posté le 26-04-2005 à 10:36:23  profilanswer
J'ai envoyé la tof sur l'email de ton profil  :jap:
n°4037236
quechua46
Posté le 27-04-2005 à 11:46:23  profilanswer
J'ai reçu ma carte :)
J'en ai profité pourfaire de nouvelles photos et édité le topic.
J'attends toujours ma DFI de la commande groupée Nokytech :(
(allez kaillou :) )
n°4039799
quechua46
Posté le 28-04-2005 à 12:10:06  profilanswer
n°4057083
quechua46
Posté le 06-05-2005 à 17:22:27  profilanswer
Je devrais recevoir ma carte mère dans la semaine à venir. Bientôt les premiers essais du Silencer 5 rev 2.0  :D
n°4057671
jblover
ID PSN: JBLover
Posté le 06-05-2005 à 22:53:59  profilanswer
moi je suis un monteur de PC dans un magasin d'informatique.
j'ai eu que la "chance" de toucher des X850XT de chez power color :(
pour ma part le ventirad de la Saphire et de la power color sont identiques mais il y a un petit hic!!!la mémoire est bien ventilé (plutot il y a des petits coussinets dessus)avec le ventilateur d'origine, mais comme à dit "quechua46" la mémoire chauffe énormément avec celui d'origine.Etrange tout de meme!!!
C'est vrai que le bruit du ventilateur est térriblement bruyant,je voudrais savoir avoir avec qu'elle sonde tu l'as fait ou sinon sur qu'elle site as tu trouvé ces caractéristiques car moi je voudrais ou j'essayerai de faire un test et je vous le passerai.
je vous dis bon courage pour la suite de ce topic :jap:
n°4058754
quechua46
Posté le 07-05-2005 à 14:43:04  profilanswer
Les mesures données sont celles que tu peux trouver au dos du package du ATi silencer 5, vitesse du ventilo au maximum.
n°4059831
amesis
Posté le 08-05-2005 à 10:12:40  profilanswer
J'ai enfin reçus la mienne X850XT PE  :love:  j'aurais du commander un ATI silencer 5 avec parce que le bruit  :ouch: elle a pas l'air de chauffer beaucoup  35° en idle et 50/51° apres 2h de jeux donc je me demande si on peux reduire la vitesse du ventilo ?
n°4059899
quechua46
Posté le 08-05-2005 à 10:52:14  profilanswer
En bidouilant tu peux l'adapter sur un rheobus
n°4059901
jblover
ID PSN: JBLover
Posté le 08-05-2005 à 10:52:26  profilanswer
oui tu peux réduir le bruit mais c'est pas hardware mais software.
voici le nom du logiciel et le liens: ati tray tool, http://www.radeonthetop.com/t/down [...] rroir=url1
Message édité par jblover le 08-05-2005 à 10:58:15
n°4059944
amesis
Posté le 08-05-2005 à 11:16:38  profilanswer
Merci ca marche  ;)
n°4059969
jblover
ID PSN: JBLover
Posté le 08-05-2005 à 11:28:09  profilanswer
amesis a écrit :
Merci ca marche  ;)
de rien on est là pour ça ;)
n°4102966
quechua46
Posté le 29-05-2005 à 12:26:39  profilanswer
Apparemment ça s'overclocke assez facilement.
Vu le prix d'une HIS avec Silencer d'origine, mieux vaut le monter soit même et garder toutes les pièces d'origines avec précaution en cas de renvoi sav
n°4104160
quechua46
Posté le 29-05-2005 à 22:15:12  profilanswer
Dans les 560€ je dirais.
Tu peux t'en sortir à moins en trouvant une carte moins chere. Passé un moment Dabs proposait des gigabytes sur commande à 499€.
n°4104517
quechua46
Posté le 30-05-2005 à 09:21:25  profilanswer
bah dans les 20-30€ le silencer
n°4104528
jblover
ID PSN: JBLover
Posté le 30-05-2005 à 09:52:07  profilanswer
dans les grosses cartes de ce jour, c'est laquelle qui consomme le moins?
n°4106480
quechua46
Posté le 31-05-2005 à 11:19:28  profilanswer
avec un ati silencer tu peux monter à plus de 600 pour le core et un peu moins de 600 pour la mémoire
n°4160002
kickvegeta
Vieux et jeune en même temps
Posté le 24-06-2005 à 19:27:16  profilanswer
:hello: Pas mal la solution de refroidissement je pense que si mon SAv me renvoie une carte qui chauffe encore autant,je vais etre tenter de faire la meme chose +1 :love:
Message édité par kickvegeta le 24-06-2005 à 19:28:30
n°4163875
kickvegeta
Posté le 26-06-2005 à 20:49:15  profilanswer
Voila une page qui montre des conclusions du ATI SILENCER 5 et si vous regardez bien sur cette page les chaleurs dégagez par ma carte en origine sont tyout a fais normal regardez-->>http://www.3dxtreme.net/index.php?id=arcticcoolingatisilencer5rev24 . Donc en bref il semblerais bien que sa épateras tout le monde mais les températures qui monte a 92° sont tout a fais normal,meme si je trouve sa ahurrissant
n°4163908
Infosactua​lite
Macintosh vs. Windows
Posté le 26-06-2005 à 21:13:54  profilanswer
[:drapo]
n°4163971
kickvegeta
Posté le 26-06-2005 à 21:44:04  profilanswer
Y'as t'il quelqu'un qui a déja monté ce ventilo sur une ASUS SLI??
n°4164021
kickvegeta
Posté le 26-06-2005 à 22:14:20  profilanswer
Heu non le ati silencer n'est pas monté...LOL Si tu regarde 92 en charge sans le ATI 5 avec le Ati 5 62 ° interessant non?
n°4164108
alpa
Posté le 26-06-2005 à 23:00:00  profilanswer
Le ventilo de base est vraiment une grosse merde avec l'été je ne peux plus jouer j'ai des alertes températures sans arrêt je vais devoir investir dans un VGA silencer, le problème c'est qu'il ne sont pas vraiment silencieux :(
n°4164126
kickvegeta
Posté le 26-06-2005 à 23:06:22  profilanswer
Ouais mais est ce qu'il se monte sur ASUS sli??Par rapport a la mémoire...Je l'ai commandé ,mais j'ai les jetons que sa passe pas va falloir que je le coupe lol.
n°4164128
alpa
Posté le 26-06-2005 à 23:07:15  profilanswer
Désolé mais j'avais un VGA silencer sur mon ancienne config alors je sais de quoi je parle dans une config normale on ne l'entend pas mais si tu l'installe dans un PC silencieux je peux t'assurer que tu va entendre le bruit du ventilo
 Page :   1  2  3  4  5
Page Précédente
[9800 Pro] Powercolor ou SapphireRadeon 9600Xt 256mb
Problème carte ATI Radeon 9800 ProProblème avec ma radeon 9600 pro
Radeon 9800pro de sapphireRedémarage du a RADEON 9200
carte radeon mobility x700 portableProbleme ATI Mobility Radeon 9700 : VPU Recover
Compatibilités Mobo AA8XE et CG Radeon X800
Plus de sujets relatifs à : [Topic Unique] Sapphire Radeon X850 Series
